查看: 12960|回复: 20
[求助] IC615启动警告,求助,谢谢啊
发表于 2013-4-16 07:25:54 | 显示全部楼层 |阅读模式
*WARNING* envSetVal: Can't set the value of variable 'devType',
        in tool[.partition] 'layout' - it has not been registered.
*WARNING* envSetVal: Can't set the value of variable 'cdsViaLayer1Direction',
*WARNING* envSetVal: Can't set the value of variable 'contactWidth',
*WARNING* envSetVal: Can't set the value of variable 'pinInstLibName',
*WARNING* envSetVal: Can't set the value of variable 'matchWireWidth',
*WARNING* envSetVal: Can't set the value of variable 'routeSpec',
*WARNING* envSetVal: Can't set the value of variable 'pinsAreSymbolic',
*WARNING* envSetVal: Can't set the value of variable 'autoContact',
*WARNING* envSetVal: Can't set the value of variable 'cdsViaLayer1YEnclosure',
*WARNING* envSetVal: Can't set the value of variable 'matchPinWidth',
*WARNING* envSetVal: Can't set the value of variable 'autoInstPin',
*WARNING* envSetVal: Can't set the value of variable 'contactRows',
*WARNING* envSetVal: Can't set the value of variable 'useDefaultVia',
*WARNING* envCyclicStringToIndex: could not find variable 'routeStatus'
*WARNING* envSetVal: Can't set the value of variable 'routeStatus',
*WARNING* envCyclicStringToIndex: could not find variable 'routeTopology'
*WARNING* envSetVal: Can't set the value of variable 'routeTopology',
*WARNING* envSetVal: Can't set the value of variable 'contactDelX',
*WARNING* envSetVal: Can't set the value of variable 'userVia',
*WARNING* envSetVal: Can't set the value of variable 'gatherBusWires',
*WARNING* envSetVal: Can't set the value of variable 'routePurpose',
*WARNING* envCyclicStringToIndex: could not find variable 'matchPinWidthValue'
*WARNING* envSetVal: Can't set the value of variable 'matchPinWidthValue',
*WARNING* envSetVal: Can't set the value of variable 'contactColumns',
*WARNING* envSetVal: Can't set the value of variable 'alignApplySpacings',
*WARNING* envSetVal: Can't set the value of variable 'devClass',
*WARNING* envCyclicStringToIndex: could not find variable 'contactJustify'
*WARNING* envSetVal: Can't set the value of variable 'contactJustify',
*WARNING* envSetVal: Can't set the value of variable 'contactLength',
*WARNING* envSetVal: Can't set the value of variable 'cdsViaLayer2YEnclosure',
*WARNING* envSetVal: Can't set the value of variable 'alignSeparation',
*WARNING* envSetVal: Can't set the value of variable 'contactDelY',
*WARNING* envSetVal: type mismatch for variable 'alignMethod'
        in tool[.partition] 'layout'.
*WARNING* envSetVal: Can't set the value of variable 'routeType',
*WARNING* envSetVal: cyclic value for variable 'viaPattern'
        is out of the choice range 0..8.
*WARNING* envSetVal: Can't set the value of variable 'pinType',
*WARNING* envSetVal: Can't set the value of variable 'cdsViaXcutSpacing',
*WARNING* envSetVal: Can't set the value of variable 'enableBusRouting',
*WARNING* envSetVal: Can't set the value of variable 'cdsViaLayer2XEnclosure',
*WARNING* envSetVal: Can't set the value of variable 'contactInstLibName',
*WARNING* envSetVal: Can't set the value of variable 'cdsViaStackedVias',
*WARNING* envSetVal: cyclic value for variable 'busWireSpacingType'
        is out of the choice range 0..4.
*WARNING* envSetVal: Can't set the value of variable 'contactName',
*WARNING* envSetVal: Can't set the value of variable 'alignApplySeparation',
*WARNING* envSetVal: Can't set the value of variable 'alignSelectionMode',
*WARNING* envSetVal: Can't set the value of variable 'pinLength',
*WARNING* envSetVal: Can't set the value of variable 'cdsViaLayer1XEnclosure',
*WARNING* envSetVal: Can't set the value of variable 'cdsViaLayer2Direction',
*WARNING* envSetVal: Can't set the value of variable 'checkOldIgnoredParamsProps',
        in tool[.partition] 'layoutXL' - it has not been registered.
*WARNING* envSetVal: Can't set the value of variable 'compTypeRefLibs',
*WARNING* envSetVal: cyclic value for variable 'showFixedMenu'
        is out of the choice range 0..3.
已经设置过license、环境变量,能启动软件,并且有打过补丁,求好心网友解决,谢谢!
发表于 2013-4-16 08:54:03 | 显示全部楼层
这是沿用了含有Patition工具的Cadence的.cdsenv文件所造成的结果。你可以直接在~/.cdsenv文件中把那些不能识别的工具, 特别是tool.partition相关的删除掉。
 楼主| 发表于 2013-4-16 08:57:56 | 显示全部楼层
回复 2# amodaman
  谢谢您的回答
但是我的启动路径下面没有.cdsenv文件啊(我已经让linux显示隐藏文件了)
您能不能再详细点呢?谢谢
能不能加下您qq,谢谢!
 楼主| 发表于 2013-4-16 09:05:54 | 显示全部楼层
回复 2# amodaman
    我的启动路径下,没有.cdsenv文件啊,这该怎么办呢?
 楼主| 发表于 2013-4-16 09:07:02 | 显示全部楼层
发表于 2013-4-16 21:48:48 | 显示全部楼层
回复 4# appleyuchi2
    .cdsenv文件一般在你的$HOME目录下,如果不在就在装载目录的搜索路径下了。
发表于 2013-4-16 23:06:33 | 显示全部楼层
读研的时候学了好久cadence的安装,看到.cdsenv,$HOME这些符号有一种莫名的感觉
 楼主| 发表于 2013-4-17 20:19:55 | 显示全部楼层
感谢leo前辈!
哪位网友碰到这个问题的话,把红色标记处
四个选项每个都选择“Save to”一下即可
有提示是否OverWrite的强行覆盖即可!
 楼主| 发表于 2013-4-17 20:20:51 | 显示全部楼层
回复 2# amodaman
    谢谢,我已经在另一位前辈指点下解决!
发表于 2013-4-17 22:08:03 | 显示全部楼层
回复 7# zhiwei0
对$HOME符号的认识不足不是EDA工具的问题,而是UNIX操作系统常识的问题,属于IT范畴。作为IC设计业者,这点小问题也可以豁免了,不过积累一下总是有帮助的。
GMT+8, 2025-11-6 05:41 , Processed in 0.022572 second(s), 6 queries , Gzip On, Redis On.
