查看: 8510|回复: 22
[资料] NOC经典书籍及论文(1)!
发表于 2012-11-21 18:20:49 | 显示全部楼层 |阅读模式
06-Wattch-Hotspot-Hotleakage[1].pdf (1.5 MB , 下载次数: 39 )
A 5-GHz mesh interconnect for a teraflops processor..pdf (1.06 MB , 下载次数: 55 )
abbr_a43c3d6b12e1d202ed9fc9470553dae8.pdf (283.38 KB , 下载次数: 19 )
A Low-Radix and Low-Diameter 3D Interconnection Network Design..pdf (620.7 KB , 下载次数: 42 )
A Novel Dimensionally-Decomposed Router for On-Chip Communication in 3D Architectures.PDF (286.33 KB , 下载次数: 29 )
A Practical Approach to Exploiting Coarse-Grained Pipeline Parallelism in C Programs..pdf (499.72 KB , 下载次数: 22 )
abbr_59b47029c5e426fb44f82d966f35fe60.pdf (244.16 KB , 下载次数: 22 )
A System-Level Exploration Flow for Optical Network on Chip (ONoC) in 3D MPSoC..pdf (448.11 KB , 下载次数: 27 )
abbr_6589f53921783c4fd93d9a1c29b294b6.pdf (350.29 KB , 下载次数: 18 )
An Intra-Chip Free-Space Optical Interconnect..pdf (441.54 KB , 下载次数: 24 )
Analytical Thermal Model for Multilevel VLSI Interconnects Incorporating Via Effect..pdf (84.21 KB , 下载次数: 23 )
abbr_f919a80542aab7f9f51f2a61237f2aed.pdf (259.96 KB , 下载次数: 19 )
Application-Specific 3D Network-on-Chip Design Using Simulated Allocation..pdf (160.67 KB , 下载次数: 24 )
Approximation algorithm for the temperature-aware scheduling problem..pdf (415.25 KB , 下载次数: 18 )
De Bruijn Graph based 3D Network on Chip Architecture Design.PDF (6.23 MB , 下载次数: 36 )
Demystifying 3D ICs The pros and cons of going vertical-.PDF (590.89 KB , 下载次数: 20 )
Design and Management of 3D Chip Multiprocessors Using Network-in-Memory.PDF (511.57 KB , 下载次数: 24 )
Design of Application-Specific 3D Networks-on-Chip Architectures.PDF (659.63 KB , 下载次数: 23 )
Die Stacking (3D) Microarchitecture..pdf (365.77 KB , 下载次数: 22 )
Distributed Task Migration for Thermal Management in Many-core Systems..pdf (335.21 KB , 下载次数: 23 )
Dynamic Thermal Management in 3D Multicore Architectures..pdf (224.63 KB , 下载次数: 25 )
abbr_426c6d1203b0d3dc05a96862512ee0a6.pdf (467.27 KB , 下载次数: 21 )
Energy-Optimal Software Partitioning in Heterogeneous Multiprocessor Embedded Systems..pdf (353.28 KB , 下载次数: 23 )
 楼主| 发表于 2012-11-22 09:11:31 | 显示全部楼层
回复 2# pcb68
    不用感谢  你下载吧~~~!
 楼主| 发表于 2012-12-13 21:37:46 | 显示全部楼层
key to success
 楼主| 发表于 2012-12-19 15:19:50 | 显示全部楼层
回复 2# pcb68
    key to success
发表于 2013-1-15 10:45:53 | 显示全部楼层
你是搞NOC的吗?
 楼主| 发表于 2013-1-15 11:04:17 | 显示全部楼层
回复 7# 咫尺天涯1124
    yes
发表于 2014-5-27 16:14:09 | 显示全部楼层
找到要用论文了,十分感谢
 楼主| 发表于 2014-5-28 21:10:22 | 显示全部楼层
回复 8# 叔叔111
   tnmflwlmf
发表于 2014-8-3 19:11:21 | 显示全部楼层
有点多,集中到一个压缩包里就好了
 楼主| 发表于 2014-8-6 10:39:51 | 显示全部楼层
回复 10# 华水某某
   not at all
GMT+8, 2025-11-18 08:44 , Processed in 0.025585 second(s), 6 queries , Gzip On, Redis On.
