查看: 7751|回复: 7
[讨论] 关于DDR2的IP(altera)生成
发表于 2012-4-24 17:51:58 | 显示全部楼层 |阅读模式
1.一般大家生成的IP都选择哪个DDR2 SDRAM Controller还是DDR2 SDRAM Controller with UniPHY 或DDR2 SDRAM Controller with ALTMEMPHY ,有什么区别?;
2.quartus II v11.1针对stratix III 为什么只能选择DDR2 SDRAM Controller with UniPHY 或DDR2 SDRAM Controller with ALTMEMPHY ;(我是选择DDR2 SDRAM Controller with UniPHY );
3.大家针对具体内存(需要自己定义参数的时候),设置的参数是否一定要与选用的ddr2内存参数完全一致。
4.大家针对IP中的PLL和DLL是怎么处理的,是连带一起生成还是另行生成的?
我是新人,有些问题问的不对还请包涵。
发表于 2012-4-24 18:24:54 | 显示全部楼层
Altera has two PHY offerings, ALTMEMPHY, for low-power applications, and
UniPHY, for high-performance applications where UniPHY provides half the latency
of ALTMEMPHY. Some new features have been added to UniPHY to support the
needs of high-performance applications, including PLL and DLL sharing, support for
QDR II/II+ and RLDRAM II, and a new smart-calibration algorithm. In addition to
the new features, UniPHY has been architected to reduce the latency through the
PHY
发表于 2012-4-24 18:29:21 | 显示全部楼层
LZ可以去ALTERA官网上找下IP资料,上面关于存储器接口的资料很全。IP生成的例子工程可以直接仿真,PLL和DLL都有
 楼主| 发表于 2012-4-24 19:19:28 | 显示全部楼层
谢谢,资料今天也稍微下了点,比如论坛上提到的external memory interface handbook,DDR SDRAM Controller UG等,你使用的资料大概有哪些,能否把名字列下,谢谢。
发表于 2012-4-24 19:41:39 | 显示全部楼层
差不多这些就够了吧,我隐约记得那个handbook就有几百页吧。只要稍微了解DDR的协议,结合IP的例子工程仿真,应该很快就能用起来吧,有问题再去查那个PDF
发表于 2012-4-24 23:19:32 | 显示全部楼层
DING,支持
发表于 2014-2-20 09:49:27 | 显示全部楼层
兄台,你用IP核的时候有没有遇到如下问题?
Error: I/O atom "ddr2_dqs[1]" has port DQSUPDATEEN that must be connected to the dqsupdate output of a DLL because the dqs_ctrl_latches_enable parameter is set to true
发表于 2014-12-15 16:15:35 | 显示全部楼层
同样在做这个,遇到很多问题,感觉难以下手
GMT+8, 2025-9-19 19:45 , Processed in 0.015559 second(s), 3 queries , Gzip On, Redis On.
