查看: 11988|回复: 15
ic610安装后,画原理图看不到元件库。哪里装错了?请指教!谢谢
发表于 2012-4-20 08:16:23 | 显示全部楼层 |阅读模式
系统版本。虚拟机REHL4先前一段时间曾在服务器上成功安装了ic610.没有出现问题。
现在安装的过程同上一次一样。安装中没有报错。
在终端输入lmli回车icfb&回车后。ic610能够启动。但启动的框里显示有error和warning
具体如下
PYRIGHT © 1992-2006  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
          © 1992-2006  UNIX SYSTEMS Laboratories INC.,
                         Reproduced with permission.
This Cadence Design Systems program and online documentation are
proprietary/confidential information and may be disclosed/used only
as authorized in a license agreement controlling such use and disclosure.
          RESTRICTED RIGHTS NOTICE (SHORT FORM)
Use/reproduction/disclosure is subject to restriction
set forth at FAR 1252.227-19 or its equivalent.
Program:
@(#)$CDS: virtuoso.exe version 6.1.0 10/10/2006 14:09 (cds126047) $
Sub version:
sub-version IC6.1.0.243 (32-bit addresses)
Loading geView.cxt
Loading LVS.cxt
Loading layerProc.cxt
Loading xlUI.cxt
Loading auCore.cxt
Loading schView.cxt
Loading selectSv.cxt
Loading vhdl.cxt
Loading seismic.cxt
Loading ams.cxt
Loading NCSU CDK 1.5.1 customizations...
loading vars from /home/pdk/ncsu/cdssetup/cdsenv for tool adle
loading vars from /home/pdk/ncsu/cdssetup/cdsenv for tool asimenv
loading vars from /home/pdk/ncsu/cdssetup/cdsenv for tool ddserv
loading vars from /home/pdk/ncsu/cdssetup/cdsenv for tool layout
loading vars from /home/pdk/ncsu/cdssetup/cdsenv for tool schematic
loading vars from /home/pdk/ncsu/cdssetup/cdsenv for tool ui
*WARNING* Cannot find /home/eda/ic610/tools.lnx86/dfII/etc/tools/cdsSpice directory to load environment variables
loading vars from /home/pdk/ncsu/cdssetup/cdsenv for tool mmsimenv
loading vars from ~/.cdsenv for tool mmsimenv
loading vars from ~/.cdsenv for tool asimenv
loading vars from /home/pdk/ncsu/cdssetup/cdsenv for tool spectre
loading vars from ~/.cdsenv for tool spectre
loading vars from /home/pdk/ncsu/cdssetup/cdsenv for tool ams
loading vars from ~/.cdsenv for tool ams
Loading awv.cxt
*WARNING* There were no system .cdsplotinit files found.
Loading NCSU SKILL routines...
Loading oasis.cxt
ERROR (ADE-5066): Tool 'spectreS' has not been registered.
ERROR (ADE-5067): Unable to initialize tool 'spectreS'; either tool class is not
        defined or tool is not registered.
*Error* The default SKILL generic function has not been defined for the function "asiEnvGetVar". Ensure that this function is called with the correct argument(s) (tool partition name).
//  Calibre Skill Interface * (v2009.2_36.21) *
//                 Copyright Mentor Graphics Corporation 2005
//                             All Rights Reserved.
//         THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
//            WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION
//              OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.
因为出现了这个error。在画原理图的时候,点添加元件。根本看不到元件。而且原理图底色是一片黑。正常应该是有点点的。
请问是我安装的问题?还是设置的问题????
这个问题是我上次没有遇到过的。。还有这个虚拟机的系统中已经安装了ic5141,synopsys等一系列的有关工具。会不会有什么冲突?
请高手解答。很着急。谢谢
 楼主| 发表于 2012-4-20 08:40:48 | 显示全部楼层
着急啊着急。。。。。。老师再催~~~~~~~~~~~~~~~~~~~~~~~~~~大侠快出现把!~
 楼主| 发表于 2012-4-20 09:21:42 | 显示全部楼层
有个问题我一直不解。启动的里面显示的/home/pdk……我在服务器上安装的时候没有出现过这个问题。ic610本身就自带库文件?还是要手工添加的呢?那个pdk的库是老师在虚拟机上安装的。用于ic5141.现在ic610直接读取了ic5141的库。问题是不是就在这里?怎么设置或解决ic610的库的问题?!!!着急啊~
发表于 2012-4-20 10:00:48 | 显示全部楼层
610不能读5141的pdk啊  要转的
 楼主| 发表于 2012-4-20 13:47:03 | 显示全部楼层
回复 4# leefuture50
请问具体怎么转呢。另外我以前装ic610的时候。其自带库文件的啊。这次为什么会被已有的ic5141的pdk影响呢。我在安装的时候也没设置的啊?????多谢!
发表于 2012-4-20 15:38:31 | 显示全部楼层
IC5141和IC610(及以上)采用不同的线程,IC5141USR6是唯一同时支持两种线程的工具,楼主应该没有用到这个版本,直接转格式,IC5141的数据转到IC610,可以在网上搜ic5141到ic610的OA格式转换,这里有个视频可作参考:http://video.sina.com.cn/v/b/24032370-1189619741.html。
    另外,如果不想造成数据混乱,最好改账户下的cds.lib文件,相关链接指向IC5141或IC610的库文件,不要混用;.cshrc(或.bashrc)的配置最好也区分开IC5141或IC610。
发表于 2012-4-23 21:43:08 | 显示全部楼层
回复 6# bingled
谢谢!学到了真东西!
发表于 2012-8-22 11:17:02 | 显示全部楼层
好东西!
发表于 2012-11-1 15:47:30 | 显示全部楼层
装好了IC610和MMSIM61后是不是还得再装库啊···
 楼主| 发表于 2012-11-2 11:28:39 | 显示全部楼层
回复 9# 武也锋
   我以前安装时是用学校购买的正版盘。你说的那两个按照安装教程安设置好环境,那么其中的库都有了。也不需要特别安装。但如果你需要别的非自带的库。则需要在安装好610后安装库。祝你成功~
GMT+8, 2025-9-15 14:14 , Processed in 0.029405 second(s), 4 queries , Gzip On, Redis On.
