查看: 3688|回复: 10
VCS DVE 运行一会出错
发表于 2012-1-25 14:59:54 | 显示全部楼层 |阅读模式
VCS DVE ERROR
VCS DVE ERROR
VCS DVE 运行一会出错
发表于 2012-1-25 15:48:55 | 显示全部楼层
The detail output ?
发表于 2012-1-25 15:50:19 | 显示全部楼层
Give more information !
 楼主| 发表于 2012-1-25 20:46:27 | 显示全部楼层
终端上显示如下信息:
The tool has just detected a severe internal error:
SEGV exception handled in internal functions.
If you encountered this severe error when using the most recent
Synopsys release, submit this stack trace and a test case that
reproduces the problem to the Synopsys Support Center by using
Enter A Call at http://solvnet.synopsys.com/EnterACall.
* For information about the latest software releases, go to the Synopsys
  SolvNet Release Library at http://solvnet.synopsys.com/ReleaseLibrary.
* For information about required Operating System patches, go to
  http://www.synopsys.com/qrsc.
* For instructions for creating, packaging, and sending a test case, go to
  http://www.synopsys.com/testcase.
Release = 'C-2009.06'  Architecture = 'linux'  Program = 'DVE'
'155065768 7878920 155552829 155303556 165764999 2271937 2270232 2349593 2354322 2354692 2349667 3768227 165667287 165752921 142236964 166121588 166121272 166063043 143003143 142739799 141368274 7802339'
发表于 2012-1-26 02:37:46 | 显示全部楼层
Did you "patch" the execution code ?
 楼主| 发表于 2012-1-26 10:36:27 | 显示全部楼层
《"patch" the execution code》是什么意思能说得详细点
发表于 2012-1-27 02:58:44 | 显示全部楼层
Did you "PJ" DVE by modified the execution code of DVE ?
发表于 2013-8-28 12:17:51 | 显示全部楼层
我也遇到一样的问题  有谁能指导一下么
发表于 2015-10-24 17:33:13 | 显示全部楼层
回复 1# liangheng 同学,你这个问题最后解决没?
发表于 2015-10-24 22:31:55 | 显示全部楼层
回帖赚分
GMT+8, 2025-12-19 08:36 , Processed in 0.021103 second(s), 5 queries , Gzip On, Redis On.
