查看: 20333|回复: 27
[求助] design compiler is not enable
发表于 2011-12-28 09:45:06 | 显示全部楼层 |阅读模式
在虚拟机上安装DC时,运行bin下的dc_shell-t时出现design compiler is not enable,运行design_vision时候又会提示cann‘t communicate with the license server,弄了一天了,不知道什么原因,请大侠指点!谢谢
 楼主| 发表于 2011-12-28 18:27:50 | 显示全部楼层
回复 2# zhq415758192
    license应该没有问题,我用lmgrd监测license的时候,log文件如下
1:09:00 (lmgrd) -----------------------------------------------
1:09:00 (lmgrd)   Please Note:
1:09:00 (lmgrd)
1:09:00 (lmgrd)   This log is intended for debug purposes only.
1:09:00 (lmgrd)   In order to capture accurate license
1:09:00 (lmgrd)   usage data into an organized repository,
1:09:00 (lmgrd)   please enable report logging. Use Macrovision's
1:09:00 (lmgrd)   software license administration  solution,
1:09:00 (lmgrd)   FLEXnet Manager, to  readily gain visibility
1:09:00 (lmgrd)   into license usage data and to create
1:09:00 (lmgrd)   insightful reports on critical information like
1:09:00 (lmgrd)   license availability and usage. FLEXnet Manager
1:09:00 (lmgrd)   can be fully automated to run these reports on
1:09:00 (lmgrd)   schedule and can be used to track license
1:09:00 (lmgrd)   servers and usage across a heterogeneous
1:09:00 (lmgrd)   network of servers including Windows NT, Linux
1:09:00 (lmgrd)   and UNIX. Contact Macrovision at
1:09:00 (lmgrd)   www.macrovision.com for more details on how to
1:09:00 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
1:09:00 (lmgrd)   for your enterprise.
1:09:00 (lmgrd)
1:09:00 (lmgrd)
1:09:00 (lmgrd)
1:09:01 (lmgrd) FLEXnet Licensing (v10.8.5.0 build 31891 i86_re3) started on abc123 (linux) (12/28/2011)
1:09:01 (lmgrd) Copyright (c) 1988-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
1:09:01 (lmgrd) US Patents 5,390,297 and 5,671,412.
1:09:01 (lmgrd) World Wide Web:  http://www.macrovision.com
1:09:01 (lmgrd) License file(s): /home/liulei/tools/synopsys/license/synopsys.dat
1:09:01 (lmgrd) lmgrd tcp-port 27001
1:09:01 (lmgrd) Starting vendor daemons ...
1:09:01 (lmgrd) Started snpslmd (internet tcp_port 33051 pid 9623)
1:09:01 (snpslmd) FLEXnet Licensing version v10.8.5.3 build 59306 i86_re3
01:09:29 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_10.9.3
1:09:31 (snpslmd) Server started on abc123 for:        SSS
1:09:31 (snpslmd) nanochar        hspice_pack        cosmos_other
1:09:31 (snpslmd) cxp                Synopsys_VCS_cmv Design-Expert
1:09:31 (snpslmd) him_mm_pi        CXp_GUI                CXp_Analysis
1:09:31 (snpslmd) CXp_CircuitEnvironment COSMOS_SCOPE        COSMOS_SCOPE
1:09:31 (snpslmd) CmMonitor        VCSiRuntimeLimited_Node VCSiRuntimeLimited_Net
1:09:31 (snpslmd) VMCCompiler_Node VMCRuntime_Node VMCEvaluation_Node
1:09:31 (snpslmd) VMCGeneratorUnlocked_Node VMCExpress_Compiler_Node VMCCompiler_Net
1:09:31 (snpslmd) VMCRuntime_Net        VMCEvaluation_Net VMCGeneratorUnlocked_Net
1:09:31 (snpslmd) VMCExpress_Compiler_Net LMCSwift_Node        SNPS-Assertions
1:09:31 (snpslmd) VT_SystemVerilog VCSMXRunTime_Net VCSMXiRunTime_Net
1:09:31 (snpslmd) Magellan-Sim        VT_SVAssertions VT_SVTestbench
1:09:31 (snpslmd) VT_NativeTestbench VT_DVE                VT_UCLI
1:09:31 (snpslmd) VT_LCA_Testbench PVCSCompiler_Net PVCSRuntime_Net
1:09:31 (snpslmd) VT_VCS_Power_Management VT_VCS_Checker        VT_VCS_Echo
1:09:31 (snpslmd) RMAN_RUN        VT_VCS_NTBE        XVVCDebugger
1:09:31 (snpslmd) VT_UnifiedCoverage VT_64Bit        VT_OtherTechnology
1:09:31 (snpslmd) VT_NativeTBDebuggerGui VT_CBUG                VT_SVAssertionCompiler
1:09:31 (snpslmd) VT_SDebug        VT_DVENTB        VT_Pioneer
1:09:31 (snpslmd) VT_SYSTEMC21        VT_LCA_Coverage VT_LCA_DEBUG
1:09:31 (snpslmd) VT_LCA_Assertions VT_LCA_MixedSignal VT_DVE_COV
1:09:31 (snpslmd) VT_VCS_Advanced_Features VT_VCS_BETA_Program VT_PVCSCompiler_Net
1:09:31 (snpslmd) DesignWare-ETHERNET DesignWare-ETHERNET Primepower
1:09:31 (snpslmd) Primepower        Primepower_gui        Primepower_gui
1:09:31 (snpslmd) fpc_foundation        fpc_pna                fpc_utils
1:09:31 (snpslmd) fpc_special1        fpc_special2        fpc_special3
1:09:31 (snpslmd) Test-Validate        Test-Accelerate-Max chiparch_migrate
1:09:31 (snpslmd) planet_migrate        DesignWare-ARMCORES-tlm DesignWare-AMBA-tlm
1:09:31 (snpslmd) Test-LBIST-Integration VHDL-Compiler-Presto primepower_vcd
1:09:31 (snpslmd) Test-Beta-7        Test-Beta-8        Test-Beta-9
1:09:31 (snpslmd) Test-STDVR        Test-MBIST-Integration HDL-Compiler-SystemVerilog
1:09:31 (snpslmd) primepower_beta MV-Opt                PhysOpt-VH
1:09:31 (snpslmd) Formality-TX        Formality-Distributed PhysOpt-Integration
1:09:31 (snpslmd) PhysOpt-Beta-Milkyway PhysOpt-Beta-SI PhysOpt-Beta-CTS
1:09:31 (snpslmd) PhysOpt-Beta-Route Test-Fault-Max        PAW
1:09:31 (snpslmd) PsynGui-ChipMap Formality-ESP        PhysOpt-XG
1:09:31 (snpslmd) PsynGui-AARender Test-Compression-ATPG Test-Compression-Synthesis
1:09:31 (snpslmd) HDL-Compiler-Old VHDL-Compiler-Old Test-Mbist-Program
1:09:31 (snpslmd) Test-Mbist-Bitstream Galileo                Galileo-PSYN
1:09:31 (snpslmd) Galileo-PnR        Galileo-GUI        NanoTime
1:09:31 (snpslmd) NanoTime-PathMill-Shared Galileo-Internal-Only PhysOpt-MV
1:09:31 (snpslmd) Astro-MV        Galaxy-GUI-PSYN Galaxy-GUI-PNR
1:09:31 (snpslmd) Galaxy-Beta        Galaxy-Internal-Only PrimeTime-New-Technology
1:09:31 (snpslmd) PrimeRail        Power-Optimization-Beta1 Power-Optimization-Beta2
1:09:31 (snpslmd) Formality-Beta1 Formality-Beta2 Galaxy-MCMM
1:09:31 (snpslmd) PrimeTime-PX        DB-Mode                DC-Topographical
1:09:31 (snpslmd) snps_fs_nwave        Pathmill-migrate Pathmill-plus-migrate
1:09:31 (snpslmd) NanoTime-ultra        Galaxy-CCS        Galaxy_FP_Beta
1:09:31 (snpslmd) Galaxy_MultiRoute4 Galaxy_MultiRoute8 PrimeTime-VX
1:09:31 (snpslmd) Galaxy-AdvRules Galaxy-FlipChip Galaxy-FP-Hier
1:09:31 (snpslmd) Test-SDD-Timing Galaxy-AdvOpt        Galaxy-CTMesh
1:09:31 (snpslmd) Galaxy-Zroute        Test-Power        Test-Physical
1:09:31 (snpslmd) DCT-Congestion        DCT-GUI                DC-Extension
1:09:31 (snpslmd) Galaxy-FP-MV        Galaxy-FP-AdvCTS Galaxy-FP-AdvTech
1:09:31 (snpslmd) NCX                Galaxy-SPG        PrimeTime-PX-Statistical
1:09:31 (snpslmd) PrimeTime-PX-New-Technology PrimeRail-New-Technology PrimeRail-static
1:09:31 (snpslmd) PrimeRail-adv        Test-CompressionPlus-Syn Test-CompressionPlus-ATPG
1:09:31 (snpslmd) NCX-addon        HERCULES_DEBUGGER HERCULES_DEBUGGER
1:09:31 (snpslmd) HERCULES_DEVICE HERCULES_DEVICE HERCULES_DRC
1:09:31 (snpslmd) HERCULES_DRC        HERCULES_ERC        HERCULES_ERC
1:09:31 (snpslmd) HERCULES_HLPE        HERCULES_HLPE        HERCULES_LVS
1:09:31 (snpslmd) HERCULES_LVS        HERCULES_MANAGER HERCULES_MANAGER
1:09:31 (snpslmd) HERCULES_MASK        HERCULES_MASK        HERCULES_RCE
1:09:31 (snpslmd) HERCULES_RCE        HERCULES_VUE        HERCULES_VUE
1:09:31 (snpslmd) LTL-100_GDS        LTL-100_GDS        LTL-100_NDW
1:09:31 (snpslmd) LTL-100_NDW        MDataPrep        MDataPrep
1:09:31 (snpslmd) MDynLink        MDynLink        MVerilog
1:09:31 (snpslmd) MVerilog        Milkyway        Milkyway
1:09:31 (snpslmd) NET-TRAN        NET-TRAN        STAR-ASCII
1:09:31 (snpslmd) STAR-ASCII        STAR-CR                STAR-CR
1:09:31 (snpslmd) STAR-EX                STAR-EX                STAR-EX_ERC
1:09:31 (snpslmd) STAR-EX_ERC        STAR-FILTER        STAR-FILTER
1:09:31 (snpslmd) STAR-GAZER        STAR-GAZER        STAR-LD2LTL
1:09:31 (snpslmd) STAR-LD2LTL        STAR-R                STAR-R
1:09:31 (snpslmd) STAR-RC2        STAR-RC2        STAR-RC2-AEO
1:09:31 (snpslmd) STAR-RC2-AEO        STAR-RC2-DB        STAR-RC2-DB
1:09:31 (snpslmd) STAR-RC2-DISTRIB10 STAR-RC2-DISTRIB10 STAR-RC2-NETLIST
1:09:31 (snpslmd) STAR-RC2-NETLIST STAR-RC2-PROBER STAR-RC2-PROBER
1:09:31 (snpslmd) STAR-RC2-TCAD        STAR-RC2-TCAD        STAR-RC2-VIEWER
1:09:31 (snpslmd) STAR-RC2-VIEWER STAR-RC2-XSTOR1 STAR-RC2-XSTOR1
1:09:31 (snpslmd) STAR-RC2-XSTOR2 STAR-RC2-XSTOR2 STAR-RC2-XTR-AEO
1:09:31 (snpslmd) STAR-RC2-XTR-AEO STAR-RC2-XTRACT STAR-RC2-XTRACT
1:09:31 (snpslmd) STAR-RC2_MANAGER STAR-RC2_MANAGER STAR-SYN2STAR
1:09:31 (snpslmd) STAR-SYN2STAR        STAR-TCAD        STAR-TCAD
1:09:31 (snpslmd) STAR-XREF        STAR-XREF        SynopsysCustomICCLink
1:09:31 (snpslmd) SynopsysCustomLayout SynopsysCustomSAE SynopsysCustomSAEBatch
1:09:31 (snpslmd) SynopsysCustomSDL SynopsysCustomSchematic cdsaawaves
1:09:31 (snpslmd) cdsaawaves        encrypt                encrypt
1:09:31 (snpslmd) fullhspice        hspice                hspice
1:09:31 (snpslmd) hspice3des        hspice3des        hspicecmidev
1:09:31 (snpslmd) hspicecmidev        hspicecmirt        hspicecmirt
1:09:31 (snpslmd) hspicerf        hspicerf        hspiceva
1:09:31 (snpslmd) hspiceva        metaencrypt3des metaencrypt3des
1:09:31 (snpslmd) nanosim                nanosim                ace_cosim
1:09:31 (snpslmd) simif                simif                simif
1:09:31 (snpslmd) spice_parser        spice_parser        sx_wva
1:09:31 (snpslmd) sx_wva                xsim                COSMOS_VO
1:09:31 (snpslmd) COSMOS_VO        CPI-100                CPI-100
1:09:31 (snpslmd) EV-ACCESS        EV-ACCESS        EV-ACCESS_UTIL
1:09:31 (snpslmd) EV-ACCESS_UTIL        Enterprise_VO        Enterprise_VO
1:09:31 (snpslmd) HERCULES-CRYPT_XREF_DATA HERCULES-CRYPT_XREF_DATA HERCULES-DP_MT
1:09:31 (snpslmd) HERCULES-DP_MT        HERCULES-EXPLORER_DRC HERCULES-EXPLORER_DRC
1:09:31 (snpslmd) HERCULES-EXPLORER_FILTERS HERCULES-EXPLORER_FILTERS HERCULES-EXPLORER_LVS
1:09:31 (snpslmd) HERCULES-EXPLORER_LVS HERCULES-NETLIST HERCULES-NETLIST
1:09:31 (snpslmd) HERCULES-RUN_TRAN HERCULES-RUN_TRAN DC-FPGA-Add-On-to-DC
1:09:31 (snpslmd) DC-FPGA-Add-On-to-DC DESIGNWARE-AMBA-VIP DESIGNWARE-AMBA-VIP
1:09:31 (snpslmd) DESIGNWARE-I2C-VIP DESIGNWARE-I2C-VIP DESIGNWARE-REGRESSION
1:09:31 (snpslmd) DESIGNWARE-REGRESSION DESIGNWARE-SIO-VIP DESIGNWARE-SIO-VIP
1:09:31 (snpslmd) DESIGNWARE-VERIFICATION DESIGNWARE-VERIFICATION DWC-AHB-ICTL-Source
1:09:31 (snpslmd) DWC-AHB-ICTL-Source DWC-AHB-Source        DWC-AHB-Source
1:09:31 (snpslmd) DWC-AMBA-Fabric-Source DWC-AMBA-Fabric-Source DWC-APB-Advanced-Source
1:09:31 (snpslmd) DWC-APB-Advanced-Source DWC-APB-ICTL-Source DWC-APB-ICTL-Source
1:09:31 (snpslmd) DWC-APB-Periph-Source DWC-APB-Periph-Source DWC-DMA-Controller-Source
1:09:31 (snpslmd) DWC-DMA-Controller-Source DWC-DMAC-Source DWC-DMAC-Source
1:09:31 (snpslmd) DWC-GPIO-Source DWC-GPIO-Source DWC-I2C-Source
1:09:31 (snpslmd) DWC-I2C-Source        DWC-INTC-CNTL-Source DWC-INTC-CNTL-Source
1:09:31 (snpslmd) DWC-MEMCTL-Source DWC-MEMCTL-Source DWC-RAP-Source
1:09:31 (snpslmd) DWC-RAP-Source        DWC-RTC-Source        DWC-RTC-Source
1:09:31 (snpslmd) DWC-SSI-Source        DWC-SSI-Source        DWC-TIMERS-Source
1:09:31 (snpslmd) DWC-TIMERS-Source DWC-UART-SRC        DWC-UART-SRC
1:09:31 (snpslmd) DWC-UART-Source DWC-UART-Source DWC-WDT-Source
1:09:31 (snpslmd) DWC-WDT-Source        DesignWare-MEMCTL-Source DesignWare-MEMCTL-Source
1:09:31 (snpslmd) JupiterXT_VF        JupiterXT_VF        SABER_GUIDE
1:09:31 (snpslmd) SABER_GUIDE        VT_LCA_Language VT_LCA_Language
1:09:31 (snpslmd) VT_NTB                VT_NTB                VT_SVDesign
1:09:31 (snpslmd) VT_SVDesign        aPrv                aPrv
1:09:31 (snpslmd) aPrv                sharp                sharp
1:09:31 (snpslmd) VHDLAMS_TAURILI VHDLAMS_TAURI        MODPEX_AWB
1:09:31 (snpslmd) MODPEX_CTC        MODPEX_ELDO        MODPEX_MARELLI
1:09:31 (snpslmd) MODPEX_NOPOWER        MODPEX_PTFT        MODPEX_SABER
1:09:31 (snpslmd) MODPEX_STATIS        MODPEX_TVS        MONTE_CARLO
1:09:31 (snpslmd) MONTE_CARLO_MEMSSE MOS_TOOL        MOS_TOOL_MEMSSE
1:09:31 (snpslmd) MOTOR_DCPM_TOOL MOTOR_DCPM_TOOL_MEMSSE OPT_TEMPLATE_LIB_MEMSSE
1:09:31 (snpslmd) PLACEHOLDER        PNET_LIBRARY        PNEUM_HYD_PRG1
1:09:31 (snpslmd) PNEU_HYD_LIBRARY POLARIS_SCOPE        POLARIS_X
1:09:31 (snpslmd) POWER_EXPRESS        SABER_SKETCH_NETLISTER SABER_SKETCH_NETLISTER_MEMSSE
1:09:31 (snpslmd) SABER_TSP        SABER_VERILOG_MM SABER_VERILOG_MM_MEMSSE
1:09:31 (snpslmd) SABER_VHDLAMS        SABER_VHDLAMS_MEMSSE SABER_VIEWSIM_MM
1:09:31 (snpslmd) SABER_VIEWSIM_MM_MEMSSE SCAN_TOOL        SCAN_TOOL_MEMSSE
1:09:31 (snpslmd) SENSITIVITY        SENSITIVITY_MEMSSE SJCL_LIBRARY
1:09:31 (snpslmd) SPECTRAL        SPECTRAL_MEMSSE STATEBENCH
1:09:31 (snpslmd) STRESS                STRESS_MEMSSE        SYMLIB
1:09:31 (snpslmd) SYMLIB_JAPANESE SYMLIB_JAPANESE_MEMSSE SYMLIB_MEMSSE
1:09:31 (snpslmd) SYMLIB_PLUS        SYMLIB_PLUS_MEMSSE SABERRT_ADI
1:09:31 (snpslmd) SABERRT_ADI_MEMSSE SABERRT_AP2633        SABERRT_FE
1:09:31 (snpslmd) SABERRT_FE_MEMSSE SABERRT_HIL        SABERRT_HIL_MEMSSE
1:09:31 (snpslmd) SABER_DEV_MM        SABER_GUIDE_MEMSSE SABER_INTERFACE_MEMSSE
1:09:31 (snpslmd) SABER_LEAPFROG_MM SABER_MODELSIM_MM SABER_MODELSIM_MM_MEMSSE
1:09:31 (snpslmd) SABER_MODELSIM_PLUS_MM SABER_MODELSIM_PLUS_MM_MEMSSE SABER_MODELSIM_VHDL_MM
1:09:31 (snpslmd) SABER_MODELSIM_VHDL_MM_MEMSSE SABER_MODELSIM_VLOG_MM SABER_PLUGNSIM_MM
1:09:31 (snpslmd) SABER_QSIM_MM        SABER_QVSPRO_MM SABER_RT_MM
1:09:31 (snpslmd) SABER_RT_MM_MEMSSE SABER_RUNTIME        SABER_SCOPE_MEMSSE
1:09:31 (snpslmd) SABER_SIMMATRIX_MM SABER_SIMULATOR_MEMSSE SABER_SKETCH_MEMSSE
1:09:31 (snpslmd) SYMLIB_POWER        SYMLIB_POWER_MEMSSE TESTIFY
1:09:31 (snpslmd) TESTIFY_MEMSSE        TESTIFY_NETLISTER_MEMSSE THERM_TOOL
1:09:31 (snpslmd) THERM_TOOL_MEMSSE TLU_TOOL        TLU_TOOL_MEMSSE
1:09:31 (snpslmd) TR_ANALYSIS        TR_ANALYSIS_MEMSSE VEHICLE_ELECTRIC_LIB_MEMSSE
1:09:31 (snpslmd) VENDOR_LIBRARY        VENDOR_LIBRARY_MEMSSE VERIAS_HSPICE_COMPILER
1:09:31 (snpslmd) VERIAS_SIMULATOR VIEWLOGIC_FRAMEWAY VIEWLOGIC_FRAMEWAY_MEMSSE
1:09:31 (snpslmd) VIEWLOGIC_NET_MEMSSE WF_API_HSPICE        WF_API_HSPICE_MEMSSE
1:09:31 (snpslmd) WF_API_MEMSSE        WF_API_STARSIM        WF_API_STARSIM_MEMSSE
1:09:31 (snpslmd) EDIF_NETLISTER        EDIF_NETLISTER_MEMSSE EXPT_EDITOR
1:09:31 (snpslmd) MAST_COMPILER        MEASURE                MEASURE_MEMSSE
1:09:31 (snpslmd) MEMS                MENTOR_FRAMEWAY MENTOR_FRAMEWAY_MEMSSE
1:09:31 (snpslmd) MENTOR_NETLISTER MENTOR_NETLISTER_MEMSSE MICROCOSM_LIB
1:09:31 (snpslmd) MICROCOSM_LIB2        MICROCOSM_LIB2_MEMSSE MICROCOSM_LIB3
1:09:31 (snpslmd) MICROCOSM_LIB3_MEMSSE MICROCOSM_LIB4        MICROCOSM_LIB4_MEMSSE
1:09:31 (snpslmd) MICROCOSM_LIB5        MICROCOSM_LIB5_MEMSSE MICROCOSM_LIB6
1:09:31 (snpslmd) MICROCOSM_LIB6_MEMSSE MICROCOSM_LIB7        MICROCOSM_LIB7_MEMSSE
1:09:31 (snpslmd) MICROCOSM_LIB_MEMSSE MODEL_ARCHITECT MODEL_ENCRYPTION_MEMSSE
1:09:31 (snpslmd) MODEL_SYNTHESIS_MEMSSE MODPEX                MODPEX_AQUEDUCT
1:09:31 (snpslmd) MODPEX_ASIM        MODPEX_ATFT        HARNESS_CATIA
1:09:31 (snpslmd) HARNESS_MCADREAD HARNESS_PROCABLE HARNESS_UNIGRAPHICS
1:09:31 (snpslmd) HSPICE_MODEL_LIBRARY_MEMSSE IC_DESIGN_LIB        IMECH_LIBRARY
1:09:31 (snpslmd) IQBUS_AUTHOR_MEMSSE IQBUS_DESIGNER        IQBUS_LIB_MEMSSE
1:09:31 (snpslmd) LINK_MATLAB        LINK_MATLAB_MEMSSE LINK_XMATH
1:09:31 (snpslmd) LOAD_TOOL        LOAD_TOOL_MEMSSE LSA_MEMSSE
1:09:31 (snpslmd) LSA                LTX_LIBRARY        COVENTOR_LIB10
1:09:31 (snpslmd) COVENTOR_LIB10_MEMSSE COVENTOR_LIB11        COVENTOR_LIB11_MEMSSE
1:09:31 (snpslmd) COVENTOR_LIB12        COVENTOR_LIB12_MEMSSE COVENTOR_LIB13
1:09:31 (snpslmd) COVENTOR_LIB13_MEMSSE COVENTOR_LIB14        COVENTOR_LIB14_MEMSSE
1:09:31 (snpslmd) COVENTOR_LIB15        COVENTOR_LIB15_MEMSSE COVENTOR_LIB8
1:09:31 (snpslmd) COVENTOR_LIB8_MEMSSE COVENTOR_LIB9        COVENTOR_LIB9_MEMSSE
1:09:31 (snpslmd) DESIGNSTAR        DESIGNSTAR_NET        DIODE_TOOL
1:09:31 (snpslmd) DIODE_TOOL_MEMSSE DRCYCLE_TOOL        DRCYCLE_TOOL_MEMSSE
1:09:31 (snpslmd) ABB_CHCRC_LIBRARY AIM_DEBUG_MEMSSE AIM_DEVELOPER_MEMSSE
1:09:31 (snpslmd) AUT_NUMBER_MAJOR_PACKAGES BASIC_ANALYSES        BASIC_ANALYSES_MEMSSE
1:09:31 (snpslmd) BATCH_MEASURE        BATCH_MEASURE_MEMSSE BATT_TOOL
1:09:31 (snpslmd) BATT_TOOL_MEMSSE BETA_LIBRARY        BUILD_DATE
1:09:31 (snpslmd) BUILD_NUMBER        BUNDLE_MCAD_PROJECTION CADENCE_DIVA_NETLISTER
1:09:31 (snpslmd) CADENCE_FRAMEWAY CADENCE_FRAMEWAY_MEMSSE CADENCE_NETLISTER
1:09:31 (snpslmd) CADENCE_NETLISTER_MEMSSE COMPONENT_LIBRARY_MEMSSE CONCEPT_FRAMEWAY
1:09:31 (snpslmd) CONCEPT_NETLISTER CORENL_CHAR        CORENL_CHAR_MEMSSE
1:09:31 (snpslmd) COSMOS_GUIDE        COSMOS_SKETCH        COSMOS_SKETCH_BACK_ANN
1:09:31 (snpslmd) COSMOS_SKETCH_NETLISTER EXPT_EDITOR_MEMSSE EXPT_EDITOR_PLUS
1:09:31 (snpslmd) EXPT_EDITOR_PLUS_MEMSSE FAILURE_MODE        FAILURE_MODE_MEMSSE
1:09:31 (snpslmd) FASTPARTS        FUSE_CHAR        FUSE_CHAR_MEMSSE
1:09:31 (snpslmd) XC4000E                XC4000EX        XC4000L
1:09:31 (snpslmd) XC4000XL        XC4000XLA        XC4000XV
1:09:31 (snpslmd) XC5200                XC9500                XC9500XL
1:09:31 (snpslmd) XC9500XV        xp                XVCSDebugger
1:09:31 (snpslmd) XVCSiDebugger        VSS-CompiledSim VSS-Debugger
1:09:31 (snpslmd) VSS-Falcon-Interface VSS-GateSim        VSS-LAI-Models
1:09:31 (snpslmd) VSS-Lib-Tools        VSS-LMSI        VSS-Model-Developer
1:09:31 (snpslmd) VSS-NEC-Tran        VSS-SDF-Interface VSS-SGE-Tool
1:09:31 (snpslmd) VSS-Simulator        VSS-SmartModels VSS-SPC
1:09:31 (snpslmd) VSS-Tran        VSS-Utilities        VSS-Verilog-PLI
1:09:31 (snpslmd) VSS-VIP-Interface VSS-Wave-Display VSS-XP-Accelerator
1:09:31 (snpslmd) VT_AssertionIP        VT_Assertions        VT_AssertionsRuntime
1:09:31 (snpslmd) VT_Coverage        VT_CoverageRuntime VT_CoverageURG
1:09:31 (snpslmd) VT_Testbench        VT_TestbenchRuntime VT_VCS_BETA_Features
1:09:31 (snpslmd) VT_VCS_LCA_Features VT_Visual        vtran
1:09:31 (snpslmd) WhatIfAnalysis        WRITE                XC3000
1:09:31 (snpslmd) XC4000                VIRTEXE                VIRTEXEA
1:09:31 (snpslmd) Vivace-Code-Generator Vivace-Core        Vivace-Debug
1:09:31 (snpslmd) Vivace-Elaborator Vivace-Expert        Vivace-Express
1:09:31 (snpslmd) Vivace-GUI        Vivace-HDL-Analyzer Vivace-Model-Compiler
1:09:31 (snpslmd) Vivace-Pro        Vivace-Simulator Vivace-VHDL-Analyzer
1:09:31 (snpslmd) vlog_epic_pif        vlog2e                vlsi2000
1:09:31 (snpslmd) vlsi500                VMCCompiler        VMCCore
1:09:31 (snpslmd) VMCEvaluation        VMCExpress_Compiler VMCGeneratorUnlocked
1:09:31 (snpslmd) VMCRuntime        VPC                vsea-calib_all
1:09:31 (snpslmd) VSP_DRIVER        VSS-Analyzer        VSS-Backplane
1:09:31 (snpslmd) VSS-Cadence-Interface VSS-CLI                vera_comp
1:09:31 (snpslmd) vera_debug        vera_ip                vera_rtime
1:09:31 (snpslmd) Verdi                Verification-Token Verilog
1:09:31 (snpslmd) verilog_writer        Verilog-Netlist-Writer Verilog-Parser
1:09:31 (snpslmd) Verilog-To-BE        Verilog-VirSim        vertue
1:09:31 (snpslmd) vhdl_compiler        VHDL-Analyzer        VHDL-Compiler
1:09:31 (snpslmd) VHDL-Cycle-Sim        VHDL-Elaborator VHDL-Event-Sim
1:09:31 (snpslmd) VHDLi-Elaborator VHDLi-Event-Sim VHDL-Netlist-Writer
1:09:31 (snpslmd) VHDL-ScSim        VHDL-To-BE        VHDL-Tools
1:09:31 (snpslmd) VHDL-VirSim        VHMC-Eval        VHMC-GenUnlocked
1:09:31 (snpslmd) VHMC-Runtime        viewlogic        viewlogic_epic
1:09:31 (snpslmd) VIEWLOGIC_NET        VirSim                VIRTEX
1:09:31 (snpslmd) VIRTEX2                VIRTEX2P        VCSNativeCode
1:09:31 (snpslmd) VCSNativeCode_Net VCSNativeCode_Node VCSOldPostProcDebugger_Net
1:09:31 (snpslmd) VCSOldPostProcDebugger_Node VCSParallelCompiler VCSParallelCompiler_Net
1:09:31 (snpslmd) VCSParallelCompiler_Node VCSParallelRuntime VCSParallelRuntime_Net
1:09:31 (snpslmd) VCSParallelRuntime_Node VCSParallelThread VCSParallelThread_Net
1:09:31 (snpslmd) VCSParallelThread_Node VCSPostProcDebugger VCSPostProcDebugger_Net
1:09:31 (snpslmd) VCSPostProcDebugger_Node VCSRuntime        VCSRuntime_Net
1:09:31 (snpslmd) VCSRuntime_Node VCSRuntimeLimited VCSRuntimeLimited_Net
1:09:31 (snpslmd) VCSRuntimeLimited_Node VCSStd                VCSStd_Net
1:09:31 (snpslmd) VCSStd_Node        VCSTools        VCSTools_Net
1:09:31 (snpslmd) VCSTools_Node        VDesktop-Debug        VDesktop-GUI
1:09:31 (snpslmd) VDesktop-VCDTrans VDesktop-Verilog VDesktop-VHDL
1:09:31 (snpslmd) VEHICLE_ELECTRIC_LIB Vera                Ultra37000
1:09:31 (snpslmd) VANTIS                vcd2e                vcsace
1:09:31 (snpslmd) VCSAMSCompiler        VCSAMSCompiler_Net VCSAMSRuntime
1:09:31 (snpslmd) VCSAMSRuntime_Net VCSCompile        VCSCompile_Net
1:09:31 (snpslmd) VCSCompile_Node VCSCompiler        VCSCompiler_Net
1:09:31 (snpslmd) VCSCompiler_Node VCSDebugger        VCSDebugger_Net
1:09:31 (snpslmd) VCSDebugger_Node VCS-Express-Compile VCS-Express-Runtime
1:09:31 (snpslmd) VCSiCompile        VCSiCompile_Net VCSiCompile_Node
1:09:31 (snpslmd) VCSiCompiler        VCSiCompiler_Net VCSiCompiler_Node
1:09:31 (snpslmd) VCSiDebugger        VCSiDebugger_Net VCSiDebugger_Node
1:09:31 (snpslmd) VCSiRuntime        VCSiRuntime_Net VCSiRuntime_Net(3)
1:09:31 (snpslmd) VCSiRuntime_Node VCSiRuntimeLimited VCSlm_Hm
1:09:31 (snpslmd) VCSlm_Hm_Net        VCSlm_Hm_Node        Test-Mbist-Algorithm
1:09:31 (snpslmd) Test-Mbist-CAM        Test-Mbist-Diagnosis Test-Mbist-DRAM
1:09:31 (snpslmd) Test-Mbist-FLASH Test-Mbist-Multiport Test-PR-1
1:09:31 (snpslmd) Test-PR-2        Test-PR-3        Test-PR-4
1:09:31 (snpslmd) Test-RTL-Check        Test-RTL-Tristate Test-ScanRoute
1:09:31 (snpslmd) TestSim                TestVE                tfm
1:09:31 (snpslmd) timemill        timemill/ace        timemill/av
1:09:31 (snpslmd) timemill/bcx        timemill/bdc        timemill/beta_status
1:09:31 (snpslmd) timemill/btm        timemill/csx        timemill/internal_use
1:09:31 (snpslmd) timemill/msx        timemill/nsaddon TimingAnalysis
1:09:31 (snpslmd) TLM_Synthesis        TRUE                tSchema
1:09:31 (snpslmd) turboSchema        turboState        turboTracer
1:09:31 (snpslmd) TurboWave        turbowave_epic        Test-BIST
1:09:31 (snpslmd) Test-BSDL        Test-CA                Test-CA-2
1:09:31 (snpslmd) Test-CA-3        Test-CA-4        Test-Compile
1:09:31 (snpslmd) Test-Compile-Max Test-Compiler        Test-Compile-Remodel
1:09:31 (snpslmd) Test-Compiler-Plus Test-Compiler-Remodel Test-Compile-Share
1:09:31 (snpslmd) Test-Core-Integration Test-Core-Wrapper Test-CTL-Model
1:09:31 (snpslmd) Test-Custom-Protocols Test-Delay        TestDesignCorrelation
1:09:31 (snpslmd) Test-DFTC-TMAX        Test-DFT-Top        Test-Diagnosis
1:09:31 (snpslmd) Test-Eval        Test-Faultsim        Test-Faultsim-8L
1:09:31 (snpslmd) Test-Format        Test-IDDQ        Test-IEEE-Std-1149-1
1:09:31 (snpslmd) TESTIFY_NETLISTER testing                Test-LBIST-ATPG
1:09:31 (snpslmd) Test-LBIST-Synthesis Test-Library        TestManager
1:09:31 (snpslmd) Test-Map        Test-Mbist        SynLib-Seq
1:09:31 (snpslmd) SynLib-VerilogSimMdl SynLib-VHDLSimMdl Synopsys
1:09:31 (snpslmd) Synopsys-Queue        Synopsys-Release TBM-Manager-UI
1:09:31 (snpslmd) TBM-VSS-Check        TBS                TC-Beta
1:09:31 (snpslmd) TDL-Interface        TDL-Reader        TDL-Writer
1:09:31 (snpslmd) Tdx_all                techviewer        Tecplot_all
1:09:31 (snpslmd) TecplotSmall_all Ted_all                TedSmall_all
1:09:31 (snpslmd) Test-Accelerator Test-Analysis        Test-Analysis-GUI
1:09:31 (snpslmd) Test-Analysis-RTL Test-ATPG        Test-ATPG-30
1:09:31 (snpslmd) Test-ATPG-Limited Test-ATPG-Max        Test-ATPG-PRO
1:09:31 (snpslmd) Test-ATPG-Ultra Test-ATPG-XP        Test-Beta
1:09:31 (snpslmd) Test-Beta-2        Test-Beta-3        Test-Beta-4
1:09:31 (snpslmd) Test-Beta-5        Test-Beta-6        stars_aryred
1:09:31 (snpslmd) stars_cmi        stars_csdf        stars_hsplnk
1:09:31 (snpslmd) stars_ish        stars_linred        stars_mr
1:09:31 (snpslmd) stars_wsf        starsim                starsimxt
1:09:31 (snpslmd) start_aed        start_analysis        start_bin
1:09:31 (snpslmd) startime        StarXtract        sup2lig_all
1:09:31 (snpslmd) swb_all                swb-advanced_all sx_cdslink
1:09:31 (snpslmd) sx_chip                sx_daiclink        sx_drc
1:09:31 (snpslmd) Sxtract_all        SYNARIO                SynLib-AdvMath
1:09:31 (snpslmd) SynLib-ALU        SynLib-Control        SynLib-DSPFIR
1:09:31 (snpslmd) SynLib-Eval        SynLib-FltTol        SynLib-PCIbasic
1:09:31 (snpslmd) Syn-Library-Compiler sprocessmpp_all sprocess-parallel_all
1:09:31 (snpslmd) sprocess-parallel4_all sptopography2d_all ST_LIBRARY
1:09:31 (snpslmd) Stamp-Compiler        STAR-DC                STAR-RC
1:09:31 (snpslmd) STAR-RC2-ANAL        STAR-RC2-ASCII        STAR-RC2-CLOCK
1:09:31 (snpslmd) STAR-RC2-GUI        STAR-RC-GUI        STAR-R-GUI
1:09:31 (snpslmd) stars_analog        SGE-Tool        SGE-Verilog-Interface
1:09:31 (snpslmd) SGE-VHDL-Interface ShortCut-DC-Expert ShortCut-DC-Pro
1:09:31 (snpslmd) Shortcut-FPGA        Siloti                Siloti_fe
1:09:31 (snpslmd) Siloti_o2        SilVE                SimVE
1:09:31 (snpslmd) simwave                simwave_epic        SKDB_Import
1:09:31 (snpslmd) SNPS-CSL        SNPS-Keygen        SNPS-MOTIVE
1:09:31 (snpslmd) SolarGAII        SolarII                sparallel_all
1:09:31 (snpslmd) SPARTAN                SPARTAN2        SPARTAN2E
1:09:31 (snpslmd) SPARTANXL        spcmcalib_all        spcmstd_all
1:09:31 (snpslmd) spice_explorer        sprocess_all        sprocess2d_all
1:09:31 (snpslmd) sprocess2dmc_all sprocess3d_all        sprocess3dmc_all
1:09:31 (snpslmd) sprocess-an-imp3d_all sprocesskmc_all sprocessmc_all
1:09:31 (snpslmd) SC-HLS                scratch                SC-RTL
1:09:31 (snpslmd) sda                sde_all                sde3d_all
1:09:31 (snpslmd) sdevcie-laser_all sdevice_all        sdevice-3d_all
1:09:31 (snpslmd) sdevice-densitygrad_all sdevice-ferro_all sdevice-floatinggate_all
1:09:31 (snpslmd) sdevice-gateleakage_all sdevice-hetero_all sdevice-hydro_all
1:09:31 (snpslmd) sdevice-kpgain_all sdevice-laser_all sdevice-led_all
1:09:31 (snpslmd) sdevice-mixedmode_all sdevicemonosemicond_all sdevice-montecarlo_all
1:09:31 (snpslmd) sdevice-noise_all sdevice-optic_all sdevice-parallel_all
1:09:31 (snpslmd) sdevice-parallel4_all sdevice-pmi_all sdevice-radiation_all
1:09:31 (snpslmd) sdevice-reliability_all sdevice-schroedinger_all sdevice-sige_all
1:09:31 (snpslmd) sdevice-thermo_all sdevice-traps_all sdevice-vectoroptic_all
1:09:31 (snpslmd) SEU                SGE-DC-Interface SGE-EDIF-Interface
1:09:31 (snpslmd) railmill/gbx        railmill/internal_use railmill/msx
1:09:31 (snpslmd) railmill/power        railmill/rvfp        railmill/snx
1:09:31 (snpslmd) railmill/spnx        railmill/ssnx        RCXTEO
1:09:31 (snpslmd) Reusner                rm_eee                route66
1:09:31 (snpslmd) RouteCompiler        rslv3d                rslv3dviewer
1:09:31 (snpslmd) RT54SXS                RTL-Analyzer        RTL-Analyzer-DAP
1:09:31 (snpslmd) RTL-Analyzer-Shell RTL-Analyzer-Shell-DAP RtlGateCorrelation
1:09:31 (snpslmd) RTL-Power-Analysis SABER_BUNDLE        SABER_DEV_MMP
1:09:31 (snpslmd) SABER_HARNESS        SABER_HARNESS_NETLISTER SABER_IF
1:09:31 (snpslmd) SABER_INTERFACE SABER_SCOPE        SABER_SCOPE_NETLIST
1:09:31 (snpslmd) SABER_SIMULATOR SABER_SKETCH        SABER_SKETCH_NETLIST
1:09:31 (snpslmd) SC-BC                SC-COSIM        SC-FPGA
1:09:31 (snpslmd) PPPRT                PrimeTime        PrimeTime_gui
1:09:31 (snpslmd) PrimeTime-Plus        PrimeTime-SI        prmspx_visual_all
1:09:31 (snpslmd) Prolyt_all        ProMA-L1        ProMA-L2
1:09:31 (snpslmd) ProMA-LD        ProMA-P1        ProMA-P2
1:09:31 (snpslmd) ProMA-PD        Protocol-Compiler-Analysis Protocol-Compiler-COutput
1:09:31 (snpslmd) Protocol-Compiler-FML Protocol-Compiler-Synth Protocol-Compiler-UI
1:09:31 (snpslmd) provhdl_checker PS_CTS                PS_Extraction
1:09:31 (snpslmd) PS_Noise_Optimization psf                PSG-SDE
1:09:31 (snpslmd) pwga                QLOGIC                Quantum38k
1:09:31 (snpslmd) rad                RailMacro        railmill
1:09:31 (snpslmd) railmill/ace        railmill/av        railmill/bcx
1:09:31 (snpslmd) railmill/beta_status PhysOpt-Extraction PhysOpt-GUI
1:09:31 (snpslmd) PhysOpt-Hierarchy PhysOpt-Onroute PhysOpt-Parallel
1:09:31 (snpslmd) PhysOpt-Route        PhysOpt-Route-TD PhysOpt-Routing
1:09:31 (snpslmd) PhysOpt-SI        PhysOpt-Ultra        PlanetPL
1:09:31 (snpslmd) PlanetRTL        pmga                polaris-cbs
1:09:31 (snpslmd) polaris-com        polaris-int        polaris-mt
1:09:31 (snpslmd) polaris-signalscan Power-Analysis        powerarc
1:09:31 (snpslmd) powergate        Power-Optimization Power-Optimization-Upgrade
1:09:31 (snpslmd) primerail_hsim        powrmill        powrmill/ace
1:09:31 (snpslmd) powrmill/av        powrmill/bcx        powrmill/beta_status
1:09:31 (snpslmd) powrmill/btm        powrmill/csx        powrmill/internal_use
1:09:31 (snpslmd) powrmill/msx        powrmill/nsaddon powrmill/power
1:09:31 (snpslmd) powrmill/svcz        powrmill/vlog_a nProp
1:09:31 (snpslmd) nSC                nSchema                nSchemaOnly
1:09:31 (snpslmd) nState                nTE                nTiming
1:09:31 (snpslmd) nTrace                nTree                nTX
1:09:31 (snpslmd) nWave                OPT_TEMPLATE_LIB OptimISE-DOE_all
1:09:31 (snpslmd) OptimISE-Iterative_all OptimISE-RSMOpt_all OptimISE-Statistical_all
1:09:31 (snpslmd) ORCA2A                ORCA2TB                ORCA3C
1:09:31 (snpslmd) ORCA3FPSC        ORCA3L                ORCA4E
1:09:31 (snpslmd) ParDiSo_all        Parse-Tree-Translator pathfinder
1:09:31 (snpslmd) pathmill        pathmill/cso        pathmill/ctx
1:09:31 (snpslmd) pathmill/dsx        pathmill/pfx        pathmill/sfx
1:09:31 (snpslmd) pathmill_plus        PC-Expert        PhysOpt
1:09:31 (snpslmd) PhysOpt-Beta        PhysOpt-ClockTree MWAPIaccess
1:09:31 (snpslmd) MWAPIdev        nAnalyzer        nanosim/ace
1:09:31 (snpslmd) nanosim/ace_cosim nanosim/av        nanosim/bcx
1:09:31 (snpslmd) nanosim/bdc        nanosim/beta_status nanosim/btm
1:09:31 (snpslmd) nanosim/gui        nanosim/internal_use nanosim/msx
1:09:31 (snpslmd) nanosim/postlayout_har nanosim/power        nanosim/vlog_a
1:09:31 (snpslmd) nBench                nClock                nCompare
1:09:31 (snpslmd) nECO                nESL                nlcc
1:09:31 (snpslmd) nLint                nLint_either        nLint_mixed
1:09:31 (snpslmd) nLint_sv        nLint_verilog        nLint_vhdl
1:09:31 (snpslmd) nMonitor        Noffset-2D_all        Noffset-3D_all
1:09:31 (snpslmd) Nova-ExploreRTL-Verilog npi                MC-Pro-RP
1:09:31 (snpslmd) MC-Retime        MDataCheck        MEMPRO
1:09:31 (snpslmd) MEMPRO-LIB        mentor/f        Mentor-Interface
1:09:31 (snpslmd) MERCURY                Mesh1D_all        Mesh2D_all
1:09:31 (snpslmd) Mesh3D_all        metawaves        metawaveswin
1:09:31 (snpslmd) mg_falcon_epic        MIF-Reader        MIF-Writer
1:09:31 (snpslmd) Milkyway-Interface Millennium-ATPG-EE Millennium-ATPG-STD
1:09:31 (snpslmd) Millennium-Beta Millennium-DRC        Millennium-Eval
1:09:31 (snpslmd) Millennium-FS        milltools        misc
1:09:31 (snpslmd) Mixed-Language        Mixed-Paradigm        MODEL_ENCRYPTION
1:09:31 (snpslmd) MODEL_SYNTHESIS MOTIVE-PrimeTime mti_epic
1:09:31 (snpslmd) MV-Astro-Opt        LigamentFE_all        LINYE
1:09:31 (snpslmd) LMCSwift        LMCSwift_Net        LSI-Interface
1:09:31 (snpslmd) lsim_parser        LSS4E                LTL-100
1:09:31 (snpslmd) LTL-100_CIF        MACH1                MACH2
1:09:31 (snpslmd) MACH4                MACH5                MAdv
1:09:31 (snpslmd) Mars                MAX3000A        MAX7000
1:09:31 (snpslmd) MAX7000A        MAX7000AE        MAX7000B
1:09:31 (snpslmd) MAX7000E        MAX7000S        MAX9000
1:09:31 (snpslmd) MCD                MCE                MCE-Base
1:09:31 (snpslmd) MCE-Eval        MCE-Lib-ALU        MCE-Lib-Arith1
1:09:31 (snpslmd) MCE-Lib-Arith2        MCE-Lib-Arith3        MCE-Lib-Logic
1:09:31 (snpslmd) MC-Pro                ispLSI5K        ispLSI6K
1:09:31 (snpslmd) ispLSI8K        ispMACH4000        JUAdvOptA
1:09:31 (snpslmd) JUAdvOptB        JUAOPAS                JUAPlan
1:09:31 (snpslmd) JUATime                JUAUD                JUClock
1:09:31 (snpslmd) JUDP                JUOPAS                Jupiter
1:09:31 (snpslmd) JupiterXT        JUPlan                JUTime
1:09:31 (snpslmd) JUUD                JUVS                Key-Generator
1:09:31 (snpslmd) Laker_AMS        Laker_iDRC        Laker_iLVS
1:09:31 (snpslmd) Laker_L1        Laker_L2        Laker_L3
1:09:31 (snpslmd) Laker_T1        Laker_T1_LE        Laker_Viewer
1:09:31 (snpslmd) Leakage-Power        leda_checker        leda_mx
1:09:31 (snpslmd) leda-mx                libarc                Library-Compiler
1:09:31 (snpslmd) Ligament_all        HLS-FPGA-SystemC HLS-SystemC
1:09:31 (snpslmd) hsim                hsim-cosim        hsim-xl
1:09:31 (snpslmd) hspice_adv        hspice_cosim        hspice_gui
1:09:31 (snpslmd) HSPICE_MODEL_LIBRARY hspice_mt        hspice_rf
1:09:31 (snpslmd) hspice_rf_char        hspicemt        hspicewin
1:09:31 (snpslmd) hspice-XO        hspicext        hsptest
1:09:31 (snpslmd) hspui                Hsp-vacomp        ICInteractive
1:09:31 (snpslmd) Inspect_all        Interface-Shell Interfise_all
1:09:31 (snpslmd) IQBUS_AUTHOR        IQBUS_LIB        IROI
1:09:31 (snpslmd) ISExtract_all        ispLSI1K        ispLSI2K
1:09:31 (snpslmd) ispLSI2KE        ispLSI3K        ispLSI5000S
1:09:31 (snpslmd) ispLSI5000SE        HERCULES_HLVS        HERCULES_HLVS-DEBUG
1:09:31 (snpslmd) HERCULES_HLVS-HTML HERCULES-DISTRIBUTED HERCULES-DISTRIBUTED-2
1:09:31 (snpslmd) HERCULES-DISTRIBUTED-24 HERCULES-DISTRIBUTED-24/2000.4 HERCULES-DISTRIBUTED-4
1:09:31 (snpslmd) HERCULES-FINDSHORT hicdr_test        hicdr_test/test1
1:09:31 (snpslmd) hicdr_test/test2 hicdr_test/test3 hicdr_test/test4
1:09:31 (snpslmd) hicdr_test/test5 hicdr_test/test6 hicdr_test/test7
1:09:31 (snpslmd) hicdr_test/test8 HighLevel-Power-Analysis HighLevel-Power-Optimization
1:09:31 (snpslmd) him_mb                him_mb_dsml        him_mod
1:09:31 (snpslmd) him_sml                Gsim_framework_basic Gsim_snapshot
1:09:31 (snpslmd) Gsim_wave        GuidedTraceAnalysis hd_foundation
1:09:31 (snpslmd) hd_pna                hd_special1        hd_special2
1:09:31 (snpslmd) hd_special3        hd_utils        HDL
1:09:31 (snpslmd) HDL2SC_mixed        HDL2SC_verilog        HDL2SC_vhdl
1:09:31 (snpslmd) HDL-Advisor        HDL-Advisor-Estimator HDL-Advisor-Estimator-Package
1:09:31 (snpslmd) HDL-Advisor-Package HDL-Advisor-Shell HDL-Advisor-Shell-Estimator
1:09:31 (snpslmd) HDL-Advisor-Shell-Estm-Package HDL-Advisor-Shell-Package HDL-Compiler
1:09:31 (snpslmd) hdlin                hdlin_mixed        hdlin_verilog
1:09:31 (snpslmd) hdlin_vhdl        HERCULES_HDRC        HERCULES_HDRC-HTML
1:09:31 (snpslmd) HERCULES_HERC-ADV HERCULES_HERC-BASIC FPGA-Library-Compiler
1:09:31 (snpslmd) FPGA-Option        FPGA-VHDL-Bundle FPPRT
1:09:31 (snpslmd) FPTA                FPTime                Fridge-GUI
1:09:31 (snpslmd) Fridge-Interpolator Fridge-Simulation FSM-Reader
1:09:31 (snpslmd) FSM-Writer        FusionVantageLmcInterface Gaia
1:09:31 (snpslmd) Galaxy-AdvCTS        Galaxy-AdvTech        Galaxy-Common
1:09:31 (snpslmd) Galaxy-DFT        Galaxy-DFY        Galaxy-FP
1:09:31 (snpslmd) Galaxy-ICC        Galaxy-IU        Galaxy-MV
1:09:31 (snpslmd) Galaxy-PNR        Galaxy-Power        Galaxy-Prototype
1:09:31 (snpslmd) Galaxy-PSYN        Gate2LayoutCorrelation Gate2RTLCorrelation
1:09:31 (snpslmd) gemini_hspice        GENERICVSP        GENESISe_all
1:09:31 (snpslmd) gentech                GRAPHICS_INTERFACE Gsim_dump_advance
1:09:31 (snpslmd) Gsim_dump_basic Gsim_framework_advance FPGA-Express-A42MX-Optimizer
1:09:31 (snpslmd) FPGA-Express-A54SX-Optimizer FPGA-Express-APEX2-Optimizer FPGA-Express-APROA-Optimizer
1:09:31 (snpslmd) FPGA-Express-Constraint-Mgr FPGA-Express-EP20k-Optimizer FPGA-Express-EPF10k-Optimizer
1:09:31 (snpslmd) FPGA-Express-EPF6k-Optimizer FPGA-Express-EPF8k-Optimizer FPGA-Express-EPM7k-Optimizer
1:09:31 (snpslmd) FPGA-Express-EPM9k-Optimizer FPGA-Express-GAT FPGA-Express-isp1K-Optimizer
1:09:31 (snpslmd) FPGA-Express-isp2K-Optimizer FPGA-Express-isp3K-Optimizer FPGA-Express-ISP4000-Optimizer
1:09:31 (snpslmd) FPGA-Express-isp4K-Optimizer FPGA-Express-ISP5000-Optimizer FPGA-Express-isp5K-Optimizer
1:09:31 (snpslmd) FPGA-Express-isp6K-Optimizer FPGA-Express-isp7K-Optimizer FPGA-Express-isp8K-Optimizer
1:09:31 (snpslmd) FPGA-Express-MERCURY-Optimizer FPGA-Express-Open-Optimizer FPGA-Express-ORCA2-Optimizer
1:09:31 (snpslmd) FPGA-Express-ORCA3-Optimizer FPGA-Express-Synario-Optimizer FPGA-Express-VHDL-Base
1:09:31 (snpslmd) FPGA-Express-VHDL-Training FPGA-Express-VIRTEX-Optimizer FPGA-Express-VLOG-Base
1:09:31 (snpslmd) FPGA-Express-XC3k-Optimizer FPGA-Express-XC4k-Optimizer FPGA-Express-XC5k-Optimizer
1:09:31 (snpslmd) FPGA-Express-XC9k-Optimizer FPGA-HDL-Bundle ficdr_test/tio
1:09:31 (snpslmd) FL_cosim_run        FL_ice_run        FL_multichip_partition
1:09:31 (snpslmd) FL_recalc        Flash370i        FLE_main
1:09:31 (snpslmd) FLEX10K                FLEX10KA        FLEX10KB
1:09:31 (snpslmd) FLEX10KE        FLEX6000        FLEX8000
1:09:31 (snpslmd) Floops-1D_all        Floops-1D-MC_all Floops-2D_all
1:09:31 (snpslmd) Floops-2D-MC_all Floops-3D_all        Floops-3D-MC_all
1:09:31 (snpslmd) Floops-Parallel_all Floops-Parallel4_all Floorplan-Management
1:09:31 (snpslmd) Formality        Formality-DV        Formality-E1
1:09:31 (snpslmd) Formality-TransForm Formality-Transit FPABP
1:09:31 (snpslmd) FPDP                FPGA_Express-APROA-Optimizer FPGA-Compiler
1:09:31 (snpslmd) FPGA-Express        FPGA-Express-32OODx-Optimizer FPGA-Express-A1200XL-Optimizer
1:09:31 (snpslmd) FPGA-Express-A1400-Optimizer FPGA-Express-A3200DX-Optimizer emw-uniform-2d_all
1:09:31 (snpslmd) emw-uniform-3d_all ENACE                ENACS
1:09:31 (snpslmd) encore                Enterprise        Equation-Reader
1:09:31 (snpslmd) Equation-Writer Espresso-Reader Espresso-Writer
1:09:31 (snpslmd) EssentialSignalAnalysis Estm-HDL-Advisor Estm-HDL-Advisor-Package
1:09:31 (snpslmd) etran                Eview                eX
1:09:31 (snpslmd) example_feature EXCALIBUR_ARM        EXCALIBUR_MIPS
1:09:31 (snpslmd) Extraction        FCII-Altera-Edition FCO
1:09:31 (snpslmd) features        ficdr_test        ficdr_test/gds
1:09:31 (snpslmd) ficdr_test/goa        ficdr_test/io        ficdr_test/nc
1:09:31 (snpslmd) ficdr_test/poly ficdr_test/size ficdr_test/sizeOr
1:09:31 (snpslmd) ficdr_test/stmp DW-IP-Consultant DW-IP-DEBUG
1:09:31 (snpslmd) DW-IP-Developer E5                E502
1:09:31 (snpslmd) E505                E520                Early-Access-Technology
1:09:31 (snpslmd) ECL-Compiler        ECO-Compiler        edif2e
1:09:31 (snpslmd) EDIF-Netlist-Read-DC EDIF-Netlist-Write-DC EDIF-Netlist-Writer
1:09:31 (snpslmd) EDIF-Reader        EDIF-Schematic-Writer electromigration_drc
1:09:31 (snpslmd) ELGRECO_Davis        ELGRECO_DesignCenter ELGRECO_Simulator
1:09:31 (snpslmd) Emlab_all        Emlab-Dessis_all Emlab-Farfield_all
1:09:31 (snpslmd) Emlab-Nonuniform-2D_all Emlab-Nonuniform-3D_all Emlab-Static_all
1:09:31 (snpslmd) Emlab-Thermal_all Emlab-Uniform-2D_all Emlab-Uniform-3D_all
1:09:31 (snpslmd) emw_all                emw-farfield_all emw-nonuniform-2d_all
1:09:31 (snpslmd) emw-nonuniform-3d_all emw-sdevice_all emw-static_all
1:09:31 (snpslmd) emw-thermal_all Dessis-Optic_all Dessis-Parallel_all
1:09:31 (snpslmd) Dessis-Parallel4_all Dessis-PMI_all        Dessis-Radiation_all
1:09:31 (snpslmd) Dessis-Reliability_all Dessis-Schroedinger_all Dessis-SiGe_all
1:09:31 (snpslmd) Dessis-Thermo_all Dessis-Traps_all Dessis-VectorOptic_all
1:09:31 (snpslmd) Devise_all        Devise-3D_all        Dfisetools_all
1:09:31 (snpslmd) Dfisetools-Topo_all Dios_all        Dios-3D_all
1:09:31 (snpslmd) Dios-MC_all        Dios-PDEF_all        Dios-SDO_all
1:09:31 (snpslmd) DiosSmall_all        Dip_all                DIRECTMEM
1:09:31 (snpslmd) DS-Schem-Gen        DS-Schem-Gen-Estimator-Pa DS-Schem-Gen-Estimator-Package
1:09:31 (snpslmd) DS-Schem-Gen-Package DS-Verinet        DS-Verinet-Estimator-Pack
1:09:31 (snpslmd) DS-Verinet-Estimator-Package DS-Verinet-Package DS-Vhdlnet
1:09:31 (snpslmd) DS-Vhdlnet-Estimator-Pack DS-Vhdlnet-Estimator-Package DS-Vhdlnet-Package
1:09:31 (snpslmd) DW-Developer        DesignWare-MPEG2 DesignWare-MPEG2-Source
1:09:31 (snpslmd) DesignWare-MPEG2-VDEC DesignWare-MPEG2-VDEC-Source DesignWare-MPEG-Source
1:09:31 (snpslmd) DesignWare-Package DesignWare-PCI        DesignWare-PCIbasic
1:09:31 (snpslmd) DesignWare-PCI-Source DesignWare-PCI-X DesignWare-PCI-X-Source
1:09:31 (snpslmd) DesignWare-SystemIO DesignWare-SystemIO-Source DesignWare-TCA
1:09:31 (snpslmd) DesignWare-TCA-Source DesignWare-USB        DesignWare-USB2
1:09:31 (snpslmd) DesignWare-USB2-Source DesignWare-USB-Source DesignWare-VERA
1:09:31 (snpslmd) Dessis_all        Dessis-3D_all        Dessis-BONSIM_all
1:09:31 (snpslmd) Dessis-DensityGrad_all Dessis-Ferro_all Dessis-FloatingGate_all
1:09:31 (snpslmd) Dessis-GateLeakage_all Dessis-Hetero_all Dessis-Hydro_all
1:09:31 (snpslmd) Dessis-kpGain_all Dessis-Laser_all Dessis-LED_all
1:09:31 (snpslmd) Dessis-MixedMode_all Dessis-Mono-Semicond_all Dessis-MonteCarlo_all
1:09:31 (snpslmd) Dessis-Noise_all Design-Budgeting Design-Compiler
1:09:31 (snpslmd) Design-Estimator Design-Estimator-FPI DesignSource
1:09:31 (snpslmd) DesignSource-Estimator-Package DesignSource-Package DesignTime
1:09:31 (snpslmd) Design-Vision        DesignWare        DesignWare-1394
1:09:31 (snpslmd) DesignWare-1394-Source DesignWare-6811-Source DesignWare-8051
1:09:31 (snpslmd) DesignWare-8051MCU DesignWare-8051-Source Designware-Basic
1:09:31 (snpslmd) DesignWare-BIST DesignWare-BIST-Source DesignWare-Cardbus
1:09:31 (snpslmd) Designware-Developer DesignWare-Developer-MGI DesignWare-ETHERNET-Source
1:09:31 (snpslmd) DesignWare-FloatingPoint DesignWare-Foundation DesignWare-Foundation-Exp
1:09:31 (snpslmd) DesignWare-Foundation-Expert DesignWare-Foundation-Power DesignWare-Foundation-Ultra
1:09:31 (snpslmd) Designware-FPGA-Basic DesignWare-ISA-PnP DesignWare-MemoryBist
1:09:31 (snpslmd) DesignWare-MemoryBist-Source DesignWare-MGI        DesignWare-MPEG
1:09:31 (snpslmd) Cyclone-Elaborator Cyclone-GUI        Cyclone-HDL-Analyzer
1:09:31 (snpslmd) Cyclone-Simulator Cyclone-VHDL-Analyzer CYPRESS
1:09:31 (snpslmd) DataExpansion        DataExpansionCoverage DataExpansionSim
1:09:31 (snpslmd) DATAIO                DataReplay        DataReplaySim
1:09:31 (snpslmd) DC64                DC-Beta                DC-Cadence-Interface
1:09:31 (snpslmd) DC-Expert        DCExpert-PrimeTime DC-Falcon-Interface
1:09:31 (snpslmd) DC-FPGA-Accelerator DC-FPGA-Add-On        DC-FPGA-Features
1:09:31 (snpslmd) DC-Layout-Interface DCM-Delay-Calculation DC-Min-Area-Retime
1:09:31 (snpslmd) DC-SDF-Interface DC-Ultra        DC-Ultra-Features
1:09:31 (snpslmd) DC-Ultra-Opt        DC-XG                Debussy
1:09:31 (snpslmd) Debussy_shared        delaymill        Delta39k
1:09:31 (snpslmd) DEMO                Design-Analyzer Design-Analyzer-DAP
1:09:31 (snpslmd) COSSAP_matlab        COSSAP_mfd        COSSAP_mpeg2
1:09:31 (snpslmd) COSSAP_pdc        COSSAP_qed        COSSAP_sds
1:09:31 (snpslmd) COSSAP_srcfd        COSSAP_vcg_generic COSSAP_vcg_synopsys
1:09:31 (snpslmd) COSSAP_vcg_vantage COSSAP_vdefcg        COSSAP_vdefcg_vlgxl
1:09:31 (snpslmd) COSSAP_vsiccg        COSSAP_vsiccg_cyc COSSAP_vsiccg_mti
1:09:31 (snpslmd) COSSAP_vsiccg_mtivlg COSSAP_vsiccg_vcs COSSAP_vsiccg_vlgxl
1:09:31 (snpslmd) COSSAP_vsivcg        COSSAP_vsivcg_vlgxl COSSAP_xdcg
1:09:31 (snpslmd) COSSAP_xvcg        COSSAP_xvsi        CoverMeter
1:09:31 (snpslmd) CoverMeterOBC        CoverMeterOBCVCSAMSCompiler CRS_COVERMETER
1:09:31 (snpslmd) CRS_VCM                CRS_VCS                CRS_VCSi
1:09:31 (snpslmd) CTV-Interface        CUSTOM_LIB        Cyclone-Code-Generator
1:09:31 (snpslmd) Cyclone-Core        Cyclone-cosim        COSSAP_cw_filter_sds
1:09:31 (snpslmd) COSSAP_dab        COSSAP_dcg_ad21020 COSSAP_dcg_ansic
1:09:31 (snpslmd) COSSAP_dcg_ariel32c COSSAP_dcg_fe        COSSAP_dcg_gc
1:09:31 (snpslmd) COSSAP_dcg_krc        COSSAP_dcg_lsic30s COSSAP_dcg_m96000
1:09:31 (snpslmd) COSSAP_dcg_mp        COSSAP_ddk_arm        COSSAP_ddk_devlp
1:09:31 (snpslmd) COSSAP_ddk_dsp16000 COSSAP_ddk_dsp1610 COSSAP_ddk_hawk
1:09:31 (snpslmd) COSSAP_ddk_nec        COSSAP_ddk_oak        COSSAP_ddk_pine
1:09:31 (snpslmd) COSSAP_ddk_ssp16xx COSSAP_ddk_tic5x COSSAP_ddk_tic5xx
1:09:31 (snpslmd) COSSAP_dect        COSSAP_dvb        COSSAP_ecc
1:09:31 (snpslmd) COSSAP_gsmdve        COSSAP_gsmdve_utils COSSAP_gsmefrsc
1:09:31 (snpslmd) COSSAP_gsmeq        COSSAP_gsmfrcc        COSSAP_gsmfrsc
1:09:31 (snpslmd) COSSAP_gsmhrcc        COSSAP_gsmhrsc        COSSAP_gsmphy
1:09:31 (snpslmd) COSSAP_is136        COSSAP_is95        CoCentric-SYS-Davis
1:09:31 (snpslmd) CoCentric-SYS-DesignCenter CoCentric-SYS-HWflow CoCentric-SYS-HWSimIF
1:09:31 (snpslmd) CoCentric-SYS-RDK-adsl CoCentric-SYS-RDK-cdma2000 CoCentric-SYS-RDK-docsis
1:09:31 (snpslmd) CoCentric-SYS-Simulator Columbia        ColumbiaTE
1:09:31 (snpslmd) COMPONENT_LIBRARY Constraint_Translation Converter
1:09:31 (snpslmd) COOLRUNNER        COOLRUNNER2        coreAssembler
1:09:31 (snpslmd) coreBuilder        coreConsultant        coremill
1:09:31 (snpslmd) coreSynthesis        COSIM-LFG        COSIM-MTI
1:09:31 (snpslmd) COSIM-NCV        COSIM-SRO        COSIM-VCS
1:09:31 (snpslmd) COSIM-VXL        COSSAP_adpcm        COSSAP_adsl
1:09:31 (snpslmd) COSSAP_amr        COSSAP_arm        COSSAP_bde
1:09:31 (snpslmd) COSSAP_celp        COSSAP_chart        COSSAP_cw_filter_hdl
1:09:31 (snpslmd) CBA-Logical-MA        CBA-Physical-DS CBA-Physical-MA
1:09:31 (snpslmd) CBA-Transport        CD-Compiled-Lib-Gen CD-Compiled-Sys-Gen
1:09:31 (snpslmd) CD-GDI                CD-GDII-Link        CD-Model-Developer
1:09:31 (snpslmd) CD-MSSC-Cross-Probe CD-MSSC-Netlist CD-Present-Builder
1:09:31 (snpslmd) CD-Present-Layer-Gen CD-REX                cdsaavmx
1:09:31 (snpslmd) cdsmetalib        cdsnet                CD-Vhdlgen-Gen
1:09:31 (snpslmd) CD-Vhdlgen-GUI        chipviewer        cmod
1:09:31 (snpslmd) cmod/ax                cmod/cbx        cmod/drc
1:09:31 (snpslmd) cmod/gx                cmod/gxadv        cmod/hdrc
1:09:31 (snpslmd) cmod/hlvs        cmod/ipc        cmod/lvs
1:09:31 (snpslmd) cmod/viewer        CmView                CoCentric-FXD-GUI
1:09:31 (snpslmd) CoCentric-FXD-Interpolator CoCentric-FXD-Simulation avanwaveswin
1:09:31 (snpslmd) awe_rcr                BC-FPGA                BC-FPGA-HDL
1:09:31 (snpslmd) BC-FPGA-VHDL        BC-HDL                BC-Schedule
1:09:31 (snpslmd) BC-VHDL                Behavioral-Analyzer Behavioral-Compiler
1:09:31 (snpslmd) BOA-BRT                c_exe_ax        c_exe_cbx
1:09:31 (snpslmd) c_exe_drc        c_exe_gx        c_exe_ipc
1:09:31 (snpslmd) c_exe_lvs        CA-Chip-Edit        CA-CP-Advanced
1:09:31 (snpslmd) CA-CP-Basic        CA-CP-Standard        cadence
1:09:31 (snpslmd) cadence_epic        CA-Foundation        CA-Frame
1:09:31 (snpslmd) CA-Hier-Timer        CA-Optimization CA-Timer
1:09:31 (snpslmd) CA-Utils        CBA-ApolloGA-Interface CBA-Blk-Export
1:09:31 (snpslmd) CBA-Blk-Import        CBA-CadenceSE-Interface CBA-DS-Beta
1:09:31 (snpslmd) CBA-Frame        CBA-Logical-DS        arc/ppx
1:09:31 (snpslmd) arc/pro                arc/r3x                arc1
1:09:31 (snpslmd) arc2                arcexpert        arcfc
1:09:31 (snpslmd) arcviewer        arcviewer/raph        arcxl
1:09:31 (snpslmd) ARKOS-A                ARKOS-B                ARKOS-C
1:09:31 (snpslmd) ARKOS-D                ARKOS-E                ARKOS-Ice
1:09:31 (snpslmd) ARKOS-Mcomp        ARKOS-Rtlcomp        ARKOS-Scomp
1:09:31 (snpslmd) ARKOS-Simul        ARM7TDMI        Astro
1:09:31 (snpslmd) AstroBeta        AstroExp        Astro-Express
1:09:31 (snpslmd) AstroGA                AstroRail        Astro-Rail
1:09:31 (snpslmd) AstroRailSA        AstroSpecialBeta AstroXtalk
1:09:31 (snpslmd) Astro-Xtalk        ATMEL                ATMWB_ATMLAYER
1:09:31 (snpslmd) ATMWB_UTOPIA        avanwaves        APACM
1:09:31 (snpslmd) APATD                APCS                APDP
1:09:31 (snpslmd) APEX20K                APEX20KC        APEX20KE
1:09:31 (snpslmd) APEXII                APGA4AP                APGACS
1:09:31 (snpslmd) APGADP                APGAHPO                APGApwr
1:09:31 (snpslmd) APGASolar        APGASolarII        APGATime
1:09:31 (snpslmd) APHPO                Apollo                ApolloGA
1:09:31 (snpslmd) APPower                APpwr                APSolar
1:09:31 (snpslmd) APSolarII        APTime                APXtalk
1:09:31 (snpslmd) arc                arc/bcx                arc/c2x
1:09:31 (snpslmd) arc/c3x                arc/cns                arc/dnx
1:09:31 (snpslmd) arc/dpx                arc/gds2        arc/giper
1:09:31 (snpslmd) arc/lefdef        A3200DX                A42MX
1:09:31 (snpslmd) A500K                A54SX                A54SXA
1:09:31 (snpslmd) A7                AARKOS-A        ace_core
1:09:31 (snpslmd) acega                acehdl                acehdl/beta_status
1:09:31 (snpslmd) acehdl/internal_use acehdl_beta        acehdl_gui
1:09:31 (snpslmd) ACEX1K                ACS                ACT2-1200XL
1:09:31 (snpslmd) ACT3                AdvanceCalibration_all AdvancedCalibration_all
1:09:31 (snpslmd) AIM_DEBUG        AIM_DECRYPT        AIM_DEVELOPER
1:09:31 (snpslmd) AIM_ENCRYPT        aiu_foundation        alien2lig_all
1:09:31 (snpslmd) ALTGEN1                ALTGEN2                amat-calib_all
1:09:31 (snpslmd) amga                amps                amps/cso
1:09:31 (snpslmd) amps/pfx        amps/tr                AN-Impl3D_all
1:09:31 (snpslmd) any_technology
1:09:31 (snpslmd)
1:09:31 (snpslmd) Licenses are case sensitive for TE_CATS
1:09:31 (snpslmd)
1:09:31 (snpslmd) EXTERNAL FILTERS are OFF
1:09:31 (lmgrd) snpslmd using TCP-port 33051
1:09:31 (snpslmd) Serving features for the following vendor names:
snpslmd  CADABRA  EPIC  ISE-TCADd  TE_CATS  adalmd  anagram  archprod  avantd  chrysalisd  everest  hscd  innologd  la_dmon  leda  metasoftd  nassd  numeritchd  saber_dmn  sandwork  sigmacd  slat  snpsOEM1  snpsOEM2  snpsOEM3  snpsOEM4  snpsOEM5  snpsOEM6  snpsOEM7  snpsOEM8  snpsOEM9  ssilmd  synopsysd  tmald  vcsd
01:09:33 (snpslmd) ------------------------------------------------------------------
01:09:33 (snpslmd) Checking the integrity of the license file....
01:09:33 (snpslmd) Valid SSS feature found.
01:09:33 (snpslmd) The feature is needed to enable the other keys in your license file.
1:09:35 (snpslmd) TCP_NODELAY NOT enabled
1:23:09 (lmgrd) lmgrd will now shut down all the vendor daemons
1:23:09 (lmgrd) Shutting down snpslmd pid=9623 because of signal 15
1:23:09 (lmgrd) Shut down FLEXnet snpslmd license server system on machine abc123
1:23:09 (lmgrd) EXITING DUE TO SIGNAL 15
1:23:09 (snpslmd) Shutdown requested from liulei@abc123 IP=127.0.0.1
1:23:09 (snpslmd) daemon shutdown requested - shutting down
应该是环境变量出错了哦,但是找了好多方法都没有解决,麻烦帮我看看这个log
 楼主| 发表于 2011-12-29 08:55:12 | 显示全部楼层
回复 4# zhq415758192
   可能是环境变量没有设置正确,软件启动不了,所以license server关闭了
发表于 2011-12-29 10:18:02 | 显示全部楼层
licence里面的hostname,mac地址是否正确?
发表于 2011-12-30 15:24:19 | 显示全部楼层
似乎说MAC要在超级用户下产生的才行,估计是这个问题把,试一下。。。我也为license纠结了好久,我同学说要在超级用户地下生成MAC,他们生成的是行了。。。。
 楼主| 发表于 2012-1-5 09:01:34 | 显示全部楼层
回复 7# magic14
    全都核对过,正确的
只是修改过hostname
 楼主| 发表于 2012-1-5 09:02:50 | 显示全部楼层
回复 8# 白兰地
    我是在虚拟机中安装的软件,也是按照网上的方法获取的虚拟机的MAC,这个应该没有问题吧
 楼主| 发表于 2012-1-5 09:14:26 | 显示全部楼层
回复 6# zhq415758192
    我用的是cshrc,基本配置如下
alias lmli2 "/home/ll/tools/synopsys/scl/linux/bin/lmgrd -c /home/liulei/tools/synopsys/scl/admin/license/synopsys.dat -l /home/ll/syn_license.log"
#SNPSLMD_LICENSE_FILE
setenv SNPSLMD_LICENSE_FILE 27001@abc123
setenv LM_LICENSE_FILE   /home/ll/tools/synopsys/scl/admin/license/synopsys.dat
#setenv SYNOPSYS /home/ll/tools/synopsys
#Design Compiler
setenv DC /home/ll/tools/synopsys/dc/dc04/linux/syn/
set path=($path $DC/bin $path)
#alias
alias dc "dc_shell"
alias dv "design_vision"
发表于 2012-1-5 09:20:49 | 显示全部楼层
回复 10# SKILLER
    恩,那是不是放的位置问题呀,后来是放在icc/admin/license里面,我还把上面的那个hostname那两行删了,也行。不过我下了很多个license生成器,有的就不行。。
 楼主| 发表于 2012-1-5 09:26:17 | 显示全部楼层
回复 12# 白兰地
    应该和放置的位置没有问题吧,因为最后都是有路径链接的
我觉得是这几句有问题,但是我目前还不太懂:
17:15:39 (snpslmd) ------------------------------------------------------------------
17:15:39 (snpslmd) Checking the integrity of the license file....
17:15:39 (snpslmd) Valid SSS feature found.
17:15:39 (snpslmd) The feature is needed to enable the other keys in your license file.
17:15:41 (snpslmd) TCP_NODELAY NOT enabled
GMT+8, 2025-6-29 11:10 , Processed in 0.026707 second(s), 7 queries , Gzip On, MemCached On.
