查看: 2519|回复: 5
[求助] how to remove undriven cells in design
发表于 2011-10-8 01:02:49 | 显示全部楼层 |阅读模式
how to remove undriven cells and floating inputs from a design using design compiler
what command should i use....
for my design i've more undriven cells and floating inputs, for this getting more leakage power than dynamic power in mW.....
please help me in this regard....
thanks in advance........
发表于 2011-10-11 10:05:23 | 显示全部楼层
put you underiven cells to VCC or Ground
 楼主| 发表于 2011-10-11 11:32:17 | 显示全部楼层
回复 2# danielz29
thank u, but how to connect them to Ground/Vdd in synthesis,what is the command for this in design compiler
发表于 2011-10-17 02:21:19 | 显示全部楼层
remove_unconnected_ports -blast_buses [find -hierarchy cell {"*"}]
remove_unconnected_ports [find -hierarchy cell {"*"}]
 楼主| 发表于 2011-10-17 02:42:48 | 显示全部楼层
回复 4# issvlsipd
   thank you
 楼主| 发表于 2011-10-17 02:43:36 | 显示全部楼层
thanks
GMT+8, 2025-11-22 12:42 , Processed in 0.014735 second(s), 3 queries , Gzip On, Redis On.
