查看: 43015|回复: 204
LNA-ESD Co-Design for Fully Integrated CMOS Wireless Receivers
发表于 2007-11-1 11:06:56 | 显示全部楼层 |阅读模式
by
Paul Leroux
KU Leuven,
Belgium
and
Michiel Steyaert
KU Leuven,
Belgium
Contents
Abstract
List of Symbols and Abbreviations
1 Introduction 1
1.1 The Growth of the Wireless Communication Market . . . . . . . . . . . . . . . . 1
1.2 Evolution to CMOS RF . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
1.3 CMOS, RF and ESD . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5
1.4 Outline of this Book . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
2 Low-Noise Amplifiers in CMOS Wireless Receivers 9
2.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
2.2 Some Important RF Concepts . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
2.2.1 Quality Factor of Reactive Elements and Series-Parallel Transformation . 9
2.2.2 SNR and Noise Figure . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
2.2.3 Impedance Matching, Power Matching, Noise Matching . . . . . . . . . 12
2.2.4 Transducer Power Gain, Operating Power Gain and Available Power Gain 13
2.2.5 Intermodulation Distortion . . . . . . . . . . . . . . . . . . . . . . . . . 15
2.3 The Deep Sub-Micron MOS Transistor at Radio Frequencies . . . . . . . . . . . 17
2.3.1 MOS Model for Hand Calculations . . . . . . . . . . . . . . . . . . . . 17
2.3.2 Linearity of the short-channel MOS transistor . . . . . . . . . . . . . . . 18
2.3.3 Non-Quasi Static Model . . . . . . . . . . . . . . . . . . . . . . . . . . 19
2.3.4 Extended MOS Model for Simulation . . . . . . . . . . . . . . . . . . . 21
2.4 The Origin of Noise . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22
2.4.1 Resistor Thermal Noise . . . . . . . . . . . . . . . . . . . . . . . . . . . 22
2.4.2 Thermal Noise in MOS transistors . . . . . . . . . . . . . . . . . . . . . 22
2.4.2.1 Classical MOS Channel Noise . . . . . . . . . . . . . . . . . 22
2.4.2.2 Induced Gate Noise . . . . . . . . . . . . . . . . . . . . . . . 23
2.4.3 1/f Noise . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24
2.4.4 Shot Noise . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24
2.5 The LNA in the Receiver Chain . . . . . . . . . . . . . . . . . . . . . . . . . . 25
2.5.1 Cascading Non-Ideal Building Blocks . . . . . . . . . . . . . . . . . . . 25
2.5.1.1 Noise in a Cascade . . . . . . . . . . . . . . . . . . . . . . . . 25
2.5.1.2 IIV3 of a Cascade . . . . . . . . . . . . . . . . . . . . . . . . 26
2.5.2 Wireless Receiver Architectures . . . . . . . . . . . . . . . . . . . . . . 27
2.5.3 LNA Requirements . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28
2.5.3.1 Matching . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28
2.5.3.2 Noise Figure . . . . . . . . . . . . . . . . . . . . . . . . . . . 29
2.5.3.3 Voltage Gain or Power Gain . . . . . . . . . . . . . . . . . . . 29
2.5.3.4 Intermodulation Distortion . . . . . . . . . . . . . . . . . . . 31
2.5.3.5 Reverse Isolation . . . . . . . . . . . . . . . . . . . . . . . . 31
2.5.3.6 Stability . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 32
2.5.3.7 Single-ended vs. Differential . . . . . . . . . . . . . . . . . . 32
2.6 Topologies for Low-Noise Amplifiers . . . . . . . . . . . . . . . . . . . . . . . 33
2.6.1 The Inductively Degenerated Common Source LNA . . . . . . . . . . . 33
2.6.1.1 From Basic Common-Source Amplifier to Inductively Degenerated
Common-Source LNA . . . . . . . . . . . . . . . . . . 33
2.6.1.2 Power Gain . . . . . . . . . . . . . . . . . . . . . . . . . . . 37
2.6.1.3 Noise Figure . . . . . . . . . . . . . . . . . . . . . . . . . . . 39
2.6.1.4 Linearity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 42
2.6.2 The Common-Gate LNA . . . . . . . . . . . . . . . . . . . . . . . . . . 43
2.6.2.1 Input Matching . . . . . . . . . . . . . . . . . . . . . . . . . 44
2.6.2.2 Power Gain . . . . . . . . . . . . . . . . . . . . . . . . . . . 46
2.6.2.3 Noise Figure . . . . . . . . . . . . . . . . . . . . . . . . . . . 46
2.6.2.4 Linearity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 47
2.6.3 Shunt-Feedback Amplifier . . . . . . . . . . . . . . . . . . . . . . . . . 48
2.6.4 Image Reject LNA’s . . . . . . . . . . . . . . . . . . . . . . . . . . . . 50
2.6.5 Highly Linear Feedforward LNA . . . . . . . . . . . . . . . . . . . . . 51
2.6.6 The Noise-Cancelling Wide-band LNA . . . . . . . . . . . . . . . . . . 52
2.6.7 Current Reuse LNA with Interstage Resonance . . . . . . . . . . . . . . 52
2.6.8 Transformer Feedback LNA . . . . . . . . . . . . . . . . . . . . . . . . 53
2.7 Conclusion . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 54
3 ESD Protection in CMOS 55
3.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 55
3.2 ESD Tests and Standards . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 56
3.2.1 Human Body Model . . . . . . . . . . . . . . . . . . . . . . . . . . . . 56
3.2.2 Machine Model . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 57
3.2.3 Charged Device Model . . . . . . . . . . . . . . . . . . . . . . . . . . . 58
3.2.4 Transmission Line Pulsing . . . . . . . . . . . . . . . . . . . . . . . . . 59
3.3 ESD-Protection in CMOS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 62
3.3.1 ESD-Protection Devices . . . . . . . . . . . . . . . . . . . . . . . . . . 62
3.3.1.1 Diode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 62
3.3.1.2 Grounded-Gate NMOS . . . . . . . . . . . . . . . . . . . . . 63
3.3.1.3 Gate-Coupled NMOS . . . . . . . . . . . . . . . . . . . . . . 66
3.3.1.4 Silicon-Controlled Rectifier . . . . . . . . . . . . . . . . . . . 66
3.3.2 ESD-Protection Topologies . . . . . . . . . . . . . . . . . . . . . . . . 68
3.3.2.1 I/O Pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 68
3.3.2.2 Power Supply Clamping . . . . . . . . . . . . . . . . . . . . . 69
3.4 Conclusion . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 72
4 Detailed Study of the Common-Source LNA with Inductive Degeneration 73
4.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 73
4.2 The Non-Quasi Static Gate Resistance . . . . . . . . . . . . . . . . . . . . . . . 73
4.2.1 Influence of rg,NQS on Zin, GT and IIP3 . . . . . . . . . . . . . . . . . . 74
4.2.2 Influence of rg,NQS on the Noise Figure . . . . . . . . . . . . . . . . . . 75
4.3 Parasitic Input Capacitance . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 78
4.3.1 Impact of Cp . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 79
4.3.1.1 Influence of Cp on Input Matching . . . . . . . . . . . . . . . 80
4.3.1.2 Influence of Cp on Power Gain, Noise Figure and IIP3 . . . . . 82
4.3.2 Impact of Cp Non-Linearity . . . . . . . . . . . . . . . . . . . . . . . . 85
4.3.3 Impact of the Finite Q of Cp . . . . . . . . . . . . . . . . . . . . . . . . 88
4.4 Miller Capacitance . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 89
4.5 Optimization of the Cascode Transistor . . . . . . . . . . . . . . . . . . . . . . 91
4.6 Output Capacitance Non-Linearity . . . . . . . . . . . . . . . . . . . . . . . . . 92
4.7 Impact of a Non-Zero S11 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 95
4.8 Output Considerations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 96
4.8.1 Load Impedance Constraints . . . . . . . . . . . . . . . . . . . . . . . . 96
4.8.2 Output Matching . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 98
4.9 LNA Bandwidth . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 100
4.10 Layout Aspects . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 101
4.10.1 RF Bonding Pads . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 101
4.10.2 On-Chip Inductors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 102
4.10.2.1 Modelling . . . . . . . . . . . . . . . . . . . . . . . . . . . . 102
4.10.2.2 Patterned Ground Shields . . . . . . . . . . . . . . . . . . . . 103
4.10.3 The Amplifying Transistor . . . . . . . . . . . . . . . . . . . . . . . . . 104
4.10.4 The Cascode Transistor . . . . . . . . . . . . . . . . . . . . . . . . . . . 105
4.11 The Common-Gate LNA Revisited . . . . . . . . . . . . . . . . . . . . . . . . . 105
4.12 Conclusion . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 109
5 RF-ESD Co-Design for CMOS LNA’s 111
5.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 111
5.2 ESD-protection within an L-Type Matching Network . . . . . . . . . . . . . . . 112
5.2.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 112
5.2.2 General Performance . . . . . . . . . . . . . . . . . . . . . . . . . . . . 113
5.2.3 Design and Layout of the ESD Protection Diodes . . . . . . . . . . . . . 115
5.2.4 Non-Linearity of Input ESD Protection Diodes . . . . . . . . . . . . . . 116
5.2.5 Conclusion . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 119
5.3 ESD-Protection within a Π-Type Matching Network . . . . . . . . . . . . . . . . 119
5.4 Inductive ESD-Protection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 123
5.5 Comparison . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 126
5.6 Other ESD-Protection Strategies . . . . . . . . . . . . . . . . . . . . . . . . . . 128
5.6.1 Distributed ESD-Protection . . . . . . . . . . . . . . . . . . . . . . . . 128
5.6.2 ESD-Protection with T-Coils . . . . . . . . . . . . . . . . . . . . . . . . 130
5.7 ESD-Protection for the Common-GateLNA . . . . . . . . . . . . . . . . . . . . 130
5.8 Conclusion . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 130
6 Integrated CMOS Low-Noise Amplifiers 133
6.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 133
6.2 A 0.8 dB NF ESD-Protected 9 mW CMOS LNA . . . . . . . . . . . . . . . . . 133
6.2.1 The GPS Power Levels . . . . . . . . . . . . . . . . . . . . . . . . . . . 133
6.2.2 Topology . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 134
6.2.3 Design . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 135
6.2.4 Layout . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 139
6.2.5 Experimental Results . . . . . . . . . . . . . . . . . . . . . . . . . . . . 141
6.2.6 Discussion and Comparison . . . . . . . . . . . . . . . . . . . . . . . . 144
6.2.7 Conclusion . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 147
6.3 A 1.3 dB NF CMOS LNA for GPS with 3 kV HBM ESD-Protection . . . . . . . 147
6.3.1 The Complete GPS Receiver Front-End . . . . . . . . . . . . . . . . . . 147
6.3.1.1 Architecture . . . . . . . . . . . . . . . . . . . . . . . . . . . 147
6.3.1.2 Low-Noise Amplifier . . . . . . . . . . . . . . . . . . . . . . 148
6.3.1.3 Quadrature, Direct Digital Downconversion . . . . . . . . . . 148
6.3.1.4 PLL Frequency Synthesizer . . . . . . . . . . . . . . . . . . . 149
6.3.2 The Low Noise Amplifier . . . . . . . . . . . . . . . . . . . . . . . . . 150
6.3.3 Results . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 153
6.3.4 Conclusion . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 158
6.4 A 5 GHz LNA with Inductive ESD-Protection Exceeding 3 kV HBM . . . . . . . 159
6.4.1 5 GHz Wireless LAN . . . . . . . . . . . . . . . . . . . . . . . . . . . . 159
6.4.2 Design . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 160
6.4.3 Results . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 165
6.4.4 Conclusion . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 169
6.5 Conclusion . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 169
7 Conclusions 171
A Fundamentals of Two-Port Noise Theory 173
Index 175
[ 本帖最后由 asic_ant 于 2007-11-1 11:12 编辑 ]
LNA-ESD Co-Design for Fully Integrated CMOS Wireless Receivers.part1.rar
1.81 MB, 下载次数: 1947 , 下载积分: 资产 -2 信元, 下载支出 2 信元
LNA-ESD Co-Design for Fully Integrated CMOS Wireless Receivers.part2.rar
1.81 MB, 下载次数: 1030 , 下载积分: 资产 -2 信元, 下载支出 2 信元
CMOS Current-Mode Circuits for Data Communications.part3.rar
1.81 MB, 下载次数: 526 , 下载积分: 资产 -2 信元, 下载支出 2 信元
LNA-ESD Co-Design for Fully Integrated CMOS Wireless Receivers.part3.rar
1.81 MB, 下载次数: 1148 , 下载积分: 资产 -2 信元, 下载支出 2 信元
LNA-ESD Co-Design for Fully Integrated CMOS Wireless Receivers.part4.rar
1.81 MB, 下载次数: 1058 , 下载积分: 资产 -2 信元, 下载支出 2 信元
LNA-ESD Co-Design for Fully Integrated CMOS Wireless Receivers.part5.rar
1.28 MB, 下载次数: 1008 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-11-1 11:09:42 | 显示全部楼层
发错了一个包
[ 本帖最后由 asic_ant 于 2007-11-1 11:13 编辑 ]
发表于 2007-11-5 23:10:31 | 显示全部楼层
不错,谢谢楼主的分享
发表于 2007-11-5 23:12:05 | 显示全部楼层
害的我下错了一个包
发表于 2007-11-15 11:21:14 | 显示全部楼层
非常感谢
发表于 2007-11-21 13:16:02 | 显示全部楼层
发表于 2007-11-21 13:17:09 | 显示全部楼层
have a look
发表于 2007-11-21 21:25:43 | 显示全部楼层
good!
发表于 2007-11-22 10:50:37 | 显示全部楼层
好啊!谢谢了啊!
发表于 2007-11-22 23:24:47 | 显示全部楼层
interesting. good.
GMT+8, 2025-11-8 14:41 , Processed in 0.023027 second(s), 6 queries , Gzip On, Redis On.
