查看: 4218|回复: 13
[资料] Signal Integrity Simulation of PCI Express Gen 2 Channel[Paper]
发表于 2011-4-20 00:51:11 | 显示全部楼层 |阅读模式
Overview
In the electronics industry, there has been an architectural shift over the past
several years from parallel bus interfaces to serial communication links. The benefits
of employing serial links over parallel I/O schemes include fewer device pins,
reduced board space requirements, smaller connectors, easier PCB layouts, and less
susceptibility to noise. However, there are unique challenges associated with serial
link design. The high data rate signals pose challenges previously only familiar to
analog RF and microwave designers. Today, many existing serial I/O standards operate
at multi-Gbps speeds. These standards are evolving, and the next generation
versions of the standards aim to increase (or perhaps even double) the data rates
achievable in a single lane. For example, PCI Express (PCIe) Gen 1 operates at 2.5
GT/s, while PCIe Gen 2 and PCIe Gen 3 are 5.0 GT/s and 8.0 GT/s, respectively. Further
complicating things is the fact that high-speed serial links often require special
data processing, such as SerDes (serializer/deserializer), equalization, and line coding
(i.e. 8B10B or 64B66B). For multi-Gbps serial links, a robust approach to signal
integrity simulation must be followed in order to avoid costly design iterations.
Signal Integrity Simulation of PCI Express Gen 2 Channel.pdf (1.82 MB , 下载次数: 221 )
发表于 2011-4-20 07:16:40 | 显示全部楼层
非常感谢
发表于 2011-4-20 07:20:26 | 显示全部楼层
thanks a lot
发表于 2011-4-21 17:37:51 | 显示全部楼层
Thanks a lot
发表于 2011-4-21 18:28:14 | 显示全部楼层
thanks
发表于 2011-4-21 20:19:22 | 显示全部楼层
Thanks you.
发表于 2011-9-28 09:48:38 | 显示全部楼层
Thanks
发表于 2012-10-1 10:45:34 | 显示全部楼层
回复 1# drjiachen
   GOOD article
发表于 2012-10-1 10:46:37 | 显示全部楼层
回复 1# drjiachen
   Thanks
发表于 2012-11-16 16:09:39 | 显示全部楼层
回复 1# drjiachen
    非常感谢
GMT+8, 2025-10-12 02:21 , Processed in 0.029307 second(s), 7 queries , Gzip On, Redis On.
