查看: 9058|回复: 17
[求助] 关于slew rate boost的问题
发表于 2011-2-23 12:56:53 | 显示全部楼层 |阅读模式
SR_BOOST
SR_BOOST
找了相应的Patent看了,但是还是没弄明白左边的曲线是如何得到的。只能定性的知道电流会大,但是为啥会和输入压差是线性关系就不知道了!望用过这种结构高人们指点!!
发表于 2011-2-23 13:28:07 | 显示全部楼层
这个有意思,把专利贴上来先。。。
 楼主| 发表于 2011-2-23 14:11:16 | 显示全部楼层
US6359512.pdf (161.74 KB , 下载次数: 130 ) 回复 2# goodsilicon
here it is!!!!!
发表于 2011-2-23 14:18:40 | 显示全部楼层
我看过这个专利,没看懂
 楼主| 发表于 2011-2-23 14:26:01 | 显示全部楼层
that's why I post this thread, dude
发表于 2011-2-23 17:44:32 | 显示全部楼层
slew rate boost一般不都是要用交叉的结构吗?
发表于 2011-2-24 07:52:40 | 显示全部楼层
The unbalanced differential pair senses the input, and provides a peak current to charge the output transistors, if the difference is larger than a certain value (such as 30mV).
 楼主| 发表于 2011-2-24 09:09:44 | 显示全部楼层
回复 7# sdmout
thank you for your reply
I see this in principle and my question is why the gm is constant ( it could be seen the from the left plot).
 楼主| 发表于 2011-2-25 10:31:34 | 显示全部楼层
hope someone could help me ~~~
发表于 2011-11-18 08:01:09 | 显示全部楼层
very good.
GMT+8, 2025-11-8 16:30 , Processed in 0.027039 second(s), 8 queries , Gzip On, Redis On.
