楼主: ybhsu2008
Synopsys Tools安装以及License设定
发表于 2010-4-11 21:24:02 | 显示全部楼层
换了个license file 吗? 我也好奇怎么解决的?
发表于 2010-4-12 20:16:04 | 显示全部楼层
怎么解决的?
发表于 2010-4-16 12:07:36 | 显示全部楼层
我也碰到了同样的问题  可否告知如何解决的  谢谢!
发表于 2010-4-16 15:51:24 | 显示全部楼层
顶了。。。。。。
发表于 2010-4-30 16:13:28 | 显示全部楼层
thanks .....~~~
发表于 2010-5-19 15:05:43 | 显示全部楼层
hostid不对应把,应该是
发表于 2010-5-20 01:03:37 | 显示全部楼层
我也碰到了同样的问题
发表于 2010-5-21 16:09:47 | 显示全部楼层
If you need to run ICC,you should get its license featire like Gaxlax-common,etc.
发表于 2010-5-21 16:13:12 | 显示全部楼层
1,first you should confirm the tool that you want to use,such DC or ICC or PrimeTime
2,find the license feature that each tool must need.
3,add all of the features in the SYNOPSYS.SRC file
4,generate the license file with the method with EFA tool
5,start the license file with lmgrd and set the environment file SNPSLMD_LICENSE_FILE as hostname@port
6,set the path environment and start the tool of DC or PT or ICC
发表于 2010-5-26 11:10:23 | 显示全部楼层
希望楼主能够说明解决问题的方法
GMT+8, 2025-11-22 03:34 , Processed in 0.022070 second(s), 5 queries , Gzip On, Redis On.
