Kluwer - CMOS cellular receiver front-ends
一本关于接收机前端设计的经典好书,此书在接收机系统架构和指标分解方面讲解非常透彻全面。然后从芯片设计到layout都深入较深入,对做接收机前端设计的人应该很有参考价值
目录:
1 INTRODUCTION 1 52RD.com]
1.1 Current State of the Art 3 52RD.com]
2 RECEIVER SYSTEM DESIGN 7 52RD.com]
2.1 Frequency Planning 7 52RD.com]
2.1.1 Blockers 8 52RD.com]
2.1.2 Spurs and Desensing 10 52RD.com]
2.1.3 Transmitter Leakage 10 52RD.com]
2.1.4 LO Leakage and Interference 11 52RD.com]
2.1.5 Image 13 52RD.com]
2.1.6 Half IF 13 52RD.com]
2.2 Link Budget Analysis 14 52RD.com]
2.2.1 Linearity 15 52RD.com]
2.2.2 Noise 16 52RD.com]
2.2.3 Signal-to-Noise Ratio 19 52RD.com]
2.2.4 Receiver Gain 20 52RD.com]
2.3 Propagation Effects 21 52RD.com]
2.3.1 Path Loss 22 52RD.com]
2.3.2 Multipath and Fading 23 52RD.com]
2.3.3 Equalization 24 52RD.com]
2.3.4 Diversity 24 52RD.com]
2.3.5 Coding 24 52RD.com]
2.4 Interface Planning 25 52RD.com]
2.5 Conclusion 25 52RD.com]
3 REVIEW OF RECEIVER ARCHITECTURES 27 52RD.com]
3.1 Heterodyne Receivers 28 52RD.com]
3.2 Image Reject Receivers 30 52RD.com]
3.2.1 Hartley Architecture 31 52RD.com]
3.2.2 Weaver Architecture 32 52RD.com]
3.3 Zero IF Receivers 32 52RD.com]
3.4 Low IF Receivers 34 52RD.com]
3.5 Issues in Direct Conversion Receivers 34 52RD.com]
3.5.1 Noise 38 52RD.com]
3.5.2 LO Leakage and Radiation 38 52RD.com]
3.5.3 Phase and Amplitude Imbalance 38 52RD.com]
3.5.4 DC Offset 39 52RD.com]
3.5.5 Intermodulations 41 52RD.com]
3.6 Architecture Comparison and Trade-off 43 52RD.com]
3.7 Conclusion 43 52RD.com]
4 SILICON-BASED RECEIVER DESIGN 47 52RD.com]
4.1 Receiver Architecture and Design 48 52RD.com]
4.1.1 System Description and Calculations 48 52RD.com]
4.1.2 Basics of OFDM 48 52RD.com]
4.1.3 System Architectures 50 52RD.com]
4.1.4 System Calculations 52 52RD.com]
4.2 Circuit Design 54 52RD.com]
4.2.1 SiGe BiCMOS Process Technology 54 52RD.com]
4.2.2 LNA 55 52RD.com]
4.2.3 Mixer 57 52RD.com]
4.2.4 Frequency Divider 61 52RD.com]
4.3 Receiver Design Steps 61 52RD.com]
4.3.1 Design and Integration of Building Blocks 62 52RD.com]
4.3.2 DC Conditions 62 52RD.com]
4.3.3 Scattering Parameters 62 52RD.com]
4.3.4 Small-Signal Performance 63 52RD.com]
4.3.5 Transient Performance 64 52RD.com]
4.3.6 Noise Performance 64 52RD.com]
4.3.7 Linearity Performance 65 52RD.com]
4.3.8 Parasitic Effects 68 52RD.com]
4.3.9 Process Variation 68 52RD.com]
4.3.10 50-[ and Non-50-[ Receivers 68 52RD.com]
4.4 Layout Considerations 52RD.com]
4.5 Characterization of Receiver Front-Ends 70 52RD.com]
4.5.1 DC Test 71 52RD.com]
4.5.2 Functionality Test 71 52RD.com]
4.5.3 S-Parameter Test 71 52RD.com]
4.5.4 Conversion Gain Test 73 52RD.com]
4.5.5 Linearity Test 74 52RD.com]
4.5.6 Noise Figure Test 74 52RD.com]
4.5.7 I/Q Imbalance 74 52RD.com]
4.5.8 DC Offset 74 52RD.com]
4.6 Measurement Results and Discussions 76 52RD.com]
4.6.1 Close Examination of Noise Figure and I/Q Imbalance 79 52RD.com]
4.6.2 Comments on I/Q Imbalance 79 52RD.com]
4.7 Conclusion 80 52RD.com]
5 SUBHARMONIC RECEIVER DESIGNS 83 52RD.com]
5.1 Illustration of Subharmonic Techniques 84 52RD.com]
5.2 Mixing Using Antisymmetric I–V Characteristics 85 52RD.com]
5.3 Impact of Mismatch Effects 89 52RD.com]
5.4 DC Offset Cancellation Mechanisms 92 52RD.com]
5.4.1 Intrinsic DC Offset Cancellation 92 52RD.com]
5.4.2 Extrinsic DC Offset Cancellation 93 52RD.com]
5.5 Experimental Verification of DC Offset 94 52RD.com]
5.6 Waveform Shaping Before Mixing 98 52RD.com]
5.6.1 Theory and Analysis 101 52RD.com]
5.6.2 Experimental Verification on GaAs MESFET APDP 102 52RD.com]
5.6.3 Implementation in Silicon 106 52RD.com]
5.7 Design Steps for APDP-Based Receivers 109 52RD.com]
5.8 Architectural Illustration 111 52RD.com]
5.9 Fully Monolithic Receiver Design Using Passive APDP Cores 112 52RD.com]
5.9.1 Integrated Direct Conversion Receiver MMIC’s 112 52RD.com]
5.9.2 Receiver Blocks 113 52RD.com]
5.9.3 Additional Receiver Blocks 121 52RD.com]
5.10 Reconfigurable Multiband Subharmonic Front-Ends 124 52RD.com]
5.11 Conclusion 125 52RD.com]
6 ACTIVE SUBHARMONIC RECEIVER DESIGNS 127 52RD.com]
6.1 Stacking of Switching Cores 128 52RD.com]
6.1.1 Description and Principles 128 52RD.com]
6.1.2 Subharmonic Receiver Architecture 131 52RD.com]
6.2 Parallel Transistor Stacks 132 52RD.com]
6.2.1 Active Mixer 132 52RD.com]
6.2.2 Receiver Architecture 134 52RD.com]
6.2.3 Extension to Passive Mixers 137 52RD.com]
6.3 Extension to Higher-Order LO Subharmonic 52RD.com]
6.4 Multiple Phase Signal Generation from Oscillators 139 52RD.com]
6.5 Future Direction and Conclusion 140 52RD.com]
7 DESIGN AND INTEGRATION OF PASSIVE COMPONENTS 143 52RD.com]
7.1 System on Package (SoP) 144 52RD.com]
7.1.1 Multilayer Bandpass Filter 146 52RD.com]
7.1.2 Multilayer Balun Structure 148 52RD.com]
7.1.3 Module-Integrable Antennaw 149 52RD.com]
7.1.4 Fully Integrated SoP Module 149 52RD.com]
7.2 On-Chip Inductors 152 52RD.com]
7.2.1 Inductor Modeling 153 52RD.com]
7.2.2 Inductor Parameters 157 52RD.com]
7.2.3 Application in Circuits 158 52RD.com]
7.3 Capacitors 159 52RD.com]
7.4 Differentially Driven Inductors 163 52RD.com]
7.5 Transformers 166 52RD.com]
7.5.1 Electrical Parameters 166 52RD.com]
7.5.2 Physical Construction 168 52RD.com]
7.5.3 Electrical Models 168 52RD.com]
7.5.4 Frequency Response of Transformers 172 52RD.com]
7.5.5 Step-Up/Step-Down Transformers and 176 52RD.com]
Circuit Applications 52RD.com]
7.6 On-Chip Filters 177 52RD.com]
7.6.1 Filters Using Bond Wires 179 52RD.com]
7.6.2 Active Filters 179 52RD.com]
7.7 On-Wafer Antennas 185 52RD.com]
7.8 Wafer-Level Packaging 187 52RD.com]
7.9 Conclusion 188 52RD.com]
8 DESIGN FOR INTEGRATION 191 52RD.com]
8.1 System Design Considerations 191 52RD.com]
8.1.1 I/O Counts 191 52RD.com]
8.1.2 Cross-Talk 192 52RD.com]
8.1.3 Digital Circuitry Noise 193 52RD.com]
8.2 IC Floor Plan 193 52RD.com]
8.2.1 Signal Flow and Substrate Coupling 196 52RD.com]
8.2.2 Grounding 196 52RD.com]
8.2.3 Isolation 197 52RD.com]
8.3 Packaging Considerations 198 52RD.com]
8.3.1 Package Modeling 199 52RD.com]
8.3.2 Bonding Limitation 200 52RD.com]
8.4 Conclusion 200 52RD.com]
9 FUTURE TRENDS 203 52RD.com]
9.1 CMOS Cellphones 52RD.com]
9.2 Multiband, Multimode Wireless Solutions 204 52RD.com]
9.3 60 GHz Subsystems in Silicon! 205 52RD.com]
9.4 Interchip Communications 206 52RD.com]
9.5 Ultrawideband Communication Technology 210 52RD.com]
9.6 Diversity Techniques 211 52RD.com]
9.7 Conclusion 52RD.com] |
