查看: 408|回复: 4
安装vip_amba3_test_suit_svt报错
发表于 2025-11-11 23:32:15 | 显示全部楼层 |阅读模式
悬赏500资产未解决
./vip_amba3_test_suit_svt_X.2025.09.run
已经设置了对应的license变量,但是仍然如下报错。有大佬知道咋整么?
发表于 2025-11-12 07:21:49 | 显示全部楼层
看看license server 日志,是不是feature不支持这么新的版本
发表于 2025-11-12 07:55:47 | 显示全部楼层
安装cxl2025.09 vip'同样的错误:
   Unpacking: cc_vip_cxl_test_suite_svt_W-2024.12.etgz ...
[SCL] SCL trace is enabled.
FlexNet Licensing checkout error: Invalid (inconsistent) license key.
The license key and data for the feature do not match.
This usually happens when a license file has been altered.
Feature:       VIP-TG-CXL2-DEV-CTS-SVT
License path:  27406@icserver:
FlexNet Licensing error:-8,544
license file(s):  27406@icserver
[SCL] 11/12/2025 07:47:05 PID:4328 Client:icserver Authorization failed VIP-TG-CXL2-DEV-CTS-SVT 2024.06
发表于 2025-11-27 21:57:42 来自手机 | 显示全部楼层
run能share吗
发表于 5 小时前 | 显示全部楼层
解决了吗
GMT+8, 2025-12-6 18:02 , Processed in 0.405763 second(s), 4 queries , Gzip On, Redis On.
