查看: 604|回复: 4
scl_keygen生成的license无法启动
发表于 2025-11-5 15:47:52 | 显示全部楼层 |阅读模式
2:43:22 (snpslmd) License server system started on localhost.localdomain
2:43:22 (snpslmd) No features to serve, exiting
2:43:22 (snpslmd) EXITING DUE TO SIGNAL 36 Exit reason 4
2:43:23 (lmgrd) snpslmd exited with status 36 (No features to serve)
2:43:23 (lmgrd) snpslmd daemon found no features.  Please correct
2:43:23 (lmgrd) license file and re-start daemons.
2:43:23 (lmgrd)
2:43:23 (lmgrd) This may be due to the fact that you are using
2:43:23 (lmgrd) a different license file from the one you expect.
2:43:23 (lmgrd) Check to make sure that:
2:43:23 (lmgrd) Synopsys.dat
2:43:23 (lmgrd) is the license file you want to use.
发表于 2025-11-5 16:58:50 | 显示全部楼层
分享出来,帮你看看
发表于 2025-11-6 11:32:14 | 显示全部楼层
1.Copy this folder into windows.
2.Double click scl_keygen.exe
3.Enter your hostid and hostname.
4.click generate, you will get a Synopsys.dat file.
5.Use PowerShell run:.\fix.bat Synopsys.dat
6.Modify the seconf line to syecify the snpslmd path.
like below:
SERVER myserver myhostid 2700
DAEMON snpslmd /software/ocad/tools/licsrv/bin/bin.syn/snpslmd
7.copy the license file as
?/ocad/tools/licsrv/licenses/syn.license.dat
8.Start license server as:
?/ocad/tools/licsrv/bin/licsrv-start
or
?/ocad/tools/licsrv/bin/bin.syn/lmgrd -c ?/ocad/tools/licsrv/licenses/syn.license.dat
     若缺少fix.bat文件,论坛里换个版本
发表于 2025-11-9 05:50:06 | 显示全部楼层
Thanks it was really help full
发表于 2025-11-9 07:54:53 | 显示全部楼层
thanks
GMT+8, 2025-12-18 03:48 , Processed in 0.017366 second(s), 4 queries , Gzip On, Redis On.
