查看: 170|回复: 1
Introducing Ranplan Professional/Academic 7.2
发表于 4 天前 | 显示全部楼层 |阅读模式
Elevating Wi-Fi 7 Simulation, Enhanced 3D Precision, and Intelligent Planning Workflows
As Wi-Fi 7 and next-generation networks introduce new levels of complexity, planners require tools that deliver not just performance, but true design intelligence. This release enhances how users simulate, visualize, and validate network behaviour across multi-band environments, while streamlining data management and 3D modelling workflows. Ranplan 7.2 empowers engineers to design with greater insight, precision, and efficiency across every stage of the planning process.
Evaluate Wi-Fi 7 Network Designs with Multi-Band Precision
Full Multi-Link Operation (MLO) analysis enables planners to simulate Wi-Fi 7 networks across multiple frequency bands with greater accuracy.
  • Multi-Band Simulation: Model 2.4, 5, and 6 GHz links simultaneously to understand the combined network performance and interactions.
  • Throughput and Reliability Analysis: Evaluate throughput with Simultaneous Transmit and Receive (STR) mode and reliability with Multi-Link Single Radio (MLSR) mode.
  • Capacity, Latency, and Robustness Insights: Gain deeper insight into how MLO affects performance to plan Wi-Fi networks that deliver consistent connectivity under variable conditions.
Measurement Data Usability and Performance Improvements
Enhanced measurement data handling streamlines validation workflows and increases simulation accuracy.
  • Floor-Linked Measurements: Ensure measurement data corresponds precisely to physical locations for accurate spatial analysis.
  • 3D Interpolation Mapping: Generate heat maps alongside predictions for realistic coverage visualization.
  • Enhanced Data Import: User-friendly feedback simplifies IBX imports and troubleshooting.
  • Optimized Large Dataset Handling: Experience faster processing and smoother performance for complex projects.
Simplified RF Calculation Region Generation
New tools reduce calculation setup time for irregular or multi-surface environments, such as tunnels, underground facilities, or industrial sites.
  • Orientation-Based Filtering: Automatically remove unwanted surfaces during region creation.
  • Colour-Coded Previews: Instantly visualize and verify surfaces before generation.
  • Z+ Axis Offset Control: Adjust region height for precise simulation coverage.
  • Smart Region Creation: Automatically generate accurate and efficient calculation regions for complex structures.
Enhanced Network Design Efficiency and Visualization
Improved project organization and clarity make managing, reviewing, and presenting complex network layouts more efficient.
  • Network System Design (NSD) Organizer: Keep network designs structured for faster navigation and management.
  • Pictogram Icons in Floor Layout Display (FLD): Instantly identify devices and systems through visual cues.
  • Updated Device Templates: Access modern templates that reflect current technologies and design practices.
Broader Building Model Support with Optimized 3D Performance.
Enhanced interoperability between architectural and network design workflows with expanded import options and improved memory management for smoother workflows of large 3D projects.
  • FBX, glTF, and GLB Support: Import models from a wider range of architectural and design tools.
  • Import Progress Tracking: Monitor large file imports with a clear progress indicator.
  • Optimized Memory Management: Experience faster rendering and improved responsiveness when working with projects containing large mesh data.
Accelerate Complex Building Model Preparation
Aligning walls within complex 3D environments, such as stadiums or sloped venues, is now simple and precise.
  • Automatic Wall Alignment: Snap vertical walls to inclined or horizontal surfaces.
  • Configurable Alignment Points: Choose top or bottom alignment for greater structural accuracy.
  • Reduced Manual Tasks: Minimize repetitive adjustments during building model preparation.
Interactive 3D Network Editing
A new immersive and responsive 3D planning experience enhances visualization, interactivity, and design control.
  • Interactive 3D Editing: Select and highlight network elements with synchronized 2D views, and modify properties directly via the property grid.
  • Wireframe and Edge Rendering: Gain sharper spatial understanding of building geometry and network layout.
  • Customizable Display Options: Adjust antenna arrows, enable always-on-top network device view, and scale device icons and labels to fit your workspace.
  • Improved Navigation and Rendering Control: Adjustable rendering quality, look-around navigation, and keyboard shortcuts deliver smoother, faster planning interactions.
Streamlined Access with Single Sign-On
Access Ranplan’s cloud applications — including Project Management, Device Hub (D-Hub), and Intelligent Floor Recognition (IFR) — quickly and securely through a unified login. The new single sign-on system lets users move seamlessly between platforms while maintaining high authentication standards.
  • Unified Login: One secure set of credentials for all Ranplan cloud services.
  • Enhanced Security: Enjoy a safer, more consistent experience across platforms.
发表于 4 天前 | 显示全部楼层
thanks
GMT+8, 2025-11-8 03:56 , Processed in 0.015469 second(s), 4 queries , Gzip On, Redis On.
