查看: 583|回复: 10
InstallScape 问题
发表于 2025-10-30 00:08:12 | 显示全部楼层 |阅读模式
运行@ICsvr:~/eda/cadence/InstallScape/iscape/bin$ ./iscape.sh  报一下错误 。
Initializing InstallScape using JVM at /home/jacky/eda/cadence/InstallScape/iscape.05.01-p001/runtime/LNX86/bin/java. This might take some time...
Error: Could not find or load main class Files.dotnet.:.mnt.c.Program
Failed with InstallScape JVM.
Now loading System JVM...
Error:
/usr/lib/jvm/java-8-openjdk-amd64/bin/java
Could not use JVM packaged with Installcape. The Java in your path did not work or could not find Java in your path.  Ensure that Java 1.8 or later is in your PATH environment variable and restart InstallScape.
环境是Ubuntu20.04 ,
java -version
openjdk version "1.8.0_452"
OpenJDK Runtime Environment (build 1.8.0_452-8u452-ga~us1-0ubuntu1~20.04-b09)
OpenJDK 64-Bit Server VM (build 25.452-b09, mixed mode)
javac -version
javac 1.8.0_452
就是运行不了cadence的iscape,有哪位大佬知道怎么回事么,求教。
发表于 2025-10-30 07:58:26 | 显示全部楼层
unset CLASSPATH
unset JAVA_TOOL_OPTIONS
unset _JAVA_OPTIONS
unset JDK_JAVA_OPTIONS
export JAVA_HOME="$HOME/eda/cadence/InstallScape/iscape.05.01-p001/runtime/LNX86"
export PATH="$JAVA_HOME/bin:/usr/bin:/bin"
cd ~/eda/cadence/InstallScape/iscape/bin
./iscape.sh
发表于 2025-10-30 11:53:21 | 显示全部楼层
Thanks
 楼主| 发表于 2025-10-30 22:59:19 | 显示全部楼层
ethanchung 发表于 2025-10-30 07:58
unset CLASSPATH
unset _JAVA_OPTIONS
export CADENCE=/home/jacky/eda/cadence
unset CLASSPATH
unset _JAVA_OPTIONS
export JAVA_HOME=${CADENCE}/InstallScape/iscape.05.01-p001/runtime/LNX86
export PATH=$JAVA_HOME/bin:/usr/bin:/bin{PATH}
还是不行
Error:
发表于 2025-10-31 18:56:20 | 显示全部楼层
Do you use WSL?
 楼主| 发表于 2025-10-31 22:56:18 | 显示全部楼层
是的,用的WSL
发表于 2025-11-1 09:24:34 | 显示全部楼层
## WSL (Ubuntu on Windows)
env | grep -i program
env | grep -i dotnet
## if exist /mnt/c/Program Files/dotnet , please reset PATH。
unset PATH
export PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
## then check
## make sure which java you use
which java
./iscape.sh
点评
感谢老哥  发表于 2025-11-1 10:06
 楼主| 发表于 2025-11-1 10:06:07 | 显示全部楼层
打开了安装程序了,用sudo 打开的。不知道目前还不知道安装完能不能用 。
发表于 2025-11-1 11:09:29 | 显示全部楼层
thanks
 楼主| 发表于 2025-11-5 14:26:22 | 显示全部楼层
已解决
GMT+8, 2025-12-14 08:50 , Processed in 0.020798 second(s), 4 queries , Gzip On, Redis On.
