查看: 513|回复: 1
Hexagon CAESAR II 2025 v15.0
发表于 2025-10-19 11:18:07 | 显示全部楼层 |阅读模式
CAESAR II is the industry standard for pipe stress analysis, letting you build, assess and report on piping systems of any size or complexity in accordance to more than 35 international piping code standards with multiple editions and alternative calculations as well as many environmental and equipment guidelines. Integration with CAD design packages lets you quickly import models, reducing risk for errors and costly iteration time between CAD and Stress Analysis divisions.
Available versions: 15.x , 14.x , 13.x ,…
Hexagon CAESAR II 2024 v14.0 Tested Picture
Features & BenefitsCatalog of Industry Codes and Standards
CAESAR II offers more than 50 international piping codes and calculational variants with multiple editions, in addition to many environmental and equipment guidelines.
Powerful Integrations
CAESAR II integrates with Hexagon’s design tools and other analysis products, saving significant costs by eliminating rework and fostering collaboration.
Robust Load Case Definitions/Manipulation
Easily import or export customized load case definitions using a template. Bypass or exclude cases to speed up analysis and focus on high-priority tasks.
Advanced Analysis and Reporting
CAESAR II allows you to analyze and report on your piping systems and how each reacts to static loads, dynamic loads and more. Create output reports in the file format of your choice.
有需要联系 1400155802@qq.com
发表于 2025-10-19 22:23:07 | 显示全部楼层
thanks
GMT+8, 2025-12-19 09:14 , Processed in 0.021558 second(s), 4 queries , Gzip On, Redis On.
