查看: 229|回复: 0
[求助] [CDL导入问题]求大佬帮忙down一篇Cadence论坛的perl脚本和网页文件
发表于 2025-9-28 21:52:34 | 显示全部楼层 |阅读模式
Pin mismatch between Symbols and Schematics - Custom IC Design - Cadence Technology Forums - Cadence Community提到了下面这个解决方案:
The CDL netlist needs to have "PININFO" lines so that the correct pin types (input, output inputOutput) can be created during spice-in. E.g.
.SUBCKT inv1 GND IN<0> OUT VDD
*.PININFO IN<0>:I OUT:O GND:B VDD:B
You can use the perl script in COS article 11693840 to add pin info from the stdcell verilog file.
GMT+8, 2025-10-10 08:45 , Processed in 0.012954 second(s), 3 queries , Gzip On, Redis On.
