查看: 910|回复: 8
$ Tools vV/vW version help
发表于 2025-7-17 12:09:51 | 显示全部楼层 |阅读模式
now i can use vR(2020 release) version in LicGen in this forum.
but vV, vW(2023,2024 release) version can't..
please help. i tried by s monoslayer but doesnt work..
wv vV error log down below.
-------------------------------------error log--------------------------------------------
[SCL] SCL trace is enabled.
FlexNet Licensing checkout error: License server system does not support this version of this feature. (-25,147)
license file(s): 27020@ic23
[SCL] 07/03/2025 13:06:25 PID:3656 Client:ic23 Checkout denied sx_wva 2023.12
[SCL] 07/03/2025 13:06:25 PID:3656 Client:ic23 Checkout denied spice_explorer 2023.12
[SCL] 07/03/2025 13:06:25 PID:3656 Client:ic23 Checkout denied custom_explorer 2023.12
[SCL] 07/03/2025 13:06:25 PID:3656 Client:ic23 Checkout denied cx_ultra 2023.12
-- Custom WaveView License Checkout Error : License server system does not support this version of this feature. (-25,234)
no valid license found
please contact your system administrator
+) if you have p-wave / cc , please share or exchange with my package..
发表于 2025-7-17 14:39:36 | 显示全部楼层
license文件里的feature版本低了吧
点评
how can i upgrade to newer version for that features?  发表于 2025-7-17 14:41
 楼主| 发表于 2025-7-17 15:37:59 | 显示全部楼层
发表于 2025-7-17 15:41:45 | 显示全部楼层
应该用2024或2025的scl吧
 楼主| 发表于 2025-7-17 16:06:27 | 显示全部楼层
skyze 发表于 2025-7-17 15:41
应该用2024或2025的scl吧
i used SCL2025 terrawilly version..
发表于 2025-7-17 22:08:47 | 显示全部楼层
For sure you have problems in your license file.
Before I understood a different situation.
发表于 2025-7-17 22:33:08 | 显示全部楼层
看看许可文件
 楼主| 发表于 2025-8-24 19:01:06 | 显示全部楼层
solved
everything executed well
GMT+8, 2025-11-23 01:00 , Processed in 0.020884 second(s), 7 queries , Gzip On, Redis On.
