查看: 2004|回复: 15
容器内运行S家的SCL v2024 以上
发表于 2025-7-12 02:45:36 | 显示全部楼层 |阅读模式
悬赏300资产已解决
如题!需要详细描述和给个教程。需要成功运行S家v2024.06 (v11.19.6.0) 或以上的SCL在Docker容器里!!!
用上gen-snpslmd-hack.c + v2024.06 (v11.19.6.0), 跑在容器里的话会遇到以下问题:
07/12/2025 02:22:21 (snpslmd) You are attempting to run the license server on a non-privileged domain/zone
07/12/2025 02:22:21 (snpslmd) Synopsys Licensing Server is restricted to run in this zone. Please contact support_center@synopsys.com for help
2:22:21 (lmgrd) snpslmd exited with status 33 (Bad configuration data)
2:22:21 (lmgrd) Please correct problem and restart daemons
只是用 v2024.06 (v11.19.6.0) 跑在容器里的话会遇到以下问题:
2:43:59 (snpslmd) FlexNet Licensing version v11.19.6.0 build 293152 x64_linux
2:43:59 (snpslmd) Cannot open daemon lock file
2:43:59 (snpslmd) EXITING DUE TO SIGNAL 41 Exit reason 9
2:43:59 (lmgrd) snpslmd exited with status 41 (Exited because another server was running)
2:43:59 (lmgrd) MULTIPLE "snpslmd" license server systems running.
2:43:59 (lmgrd) Please kill, and run lmreread
2:43:59 (lmgrd)
2:43:59 (lmgrd) This error probably results from either:
2:43:59 (lmgrd)   1. Another copy of the license server manager (lmgrd) is running.
2:43:59 (lmgrd)   2. A prior license server manager (lmgrd) was killed with "kill -9"
2:43:59 (lmgrd)       (which would leave the vendor daemon running).
2:43:59 (lmgrd) To correct this, do a "ps -ax | grep snpslmd"
2:43:59 (lmgrd)   (or equivalent "ps" command)
2:43:59 (lmgrd) and kill the "snpslmd" process.
现在只有sclv2018.06 (v11.14.1.3) + gen-snpslmd-hack.c 可以在容器内成功跑起来。其他更新的版本一律报错,错误信息如上!
最佳答案
查看完整内容
我给你发了一条消息...
发表于 2025-7-12 02:45:37 | 显示全部楼层
我给你发了一条消息...
发表于 2025-7-12 06:24:38 | 显示全部楼层
可以解决
发表于 2025-7-12 09:42:35 | 显示全部楼层
cyberwillis 发表于 2025-7-12 08:20
我给你发了一条消息...
大佬,给我也发个,同样的问题。万分感谢!
 楼主| 发表于 2025-7-12 11:10:41 | 显示全部楼层
我给你发了一条消息...
回你消息啦。麻烦查看下。
发表于 2025-7-14 00:51:04 | 显示全部楼层
检查项目 3.6
https://zhuanlan.zhihu.com/p/433125915
发表于 2025-7-14 03:12:14 | 显示全部楼层
发表于 2025-7-16 20:13:57 | 显示全部楼层
怎么解决?谁也给我发一条消息~~
发表于 2025-9-11 10:45:39 | 显示全部楼层
同问。。
想在容器里起dc_shell 就得先起license  >>
在容器里起scl 会遇到MULTIPLE "snpslmd" license server systems running. >>
使用gen-snpslmd-hack.c + v2024.06 在容器里跑 跳过了上面的问题 但是会提示You are attempting to run the license server on a non-privileged domain/zone
发表于 2025-9-12 16:57:05 | 显示全部楼层
怎么解决?谁也给我发一条消息~~
GMT+8, 2025-10-19 20:23 , Processed in 0.027387 second(s), 5 queries , Gzip On, Redis On.
