查看: 1297|回复: 11
求一个tessent2023的license
发表于 2025-6-13 09:00:02 | 显示全部楼层 |阅读模式
悬赏500资产未解决
发表于 2025-6-13 16:54:57 | 显示全部楼层
export SALT_LICENSE_SERVER=/license/license.dat
license.7z
201.09 KB, 下载次数: 71
 楼主| 发表于 2025-6-13 17:35:57 | 显示全部楼层
我用的是csh,所以环境变量如下配置:
setenv SALT_LICENSE_SERVER "/software/tessent/tessent_2023.3/license/license.dat"
执行tessent,还是报没有license(如下),请问该如何处理?
[panqiang@localhost run]$ tessent -shell
//  Tessent Shell  2023.3    Tue Aug 15 20:24:46 GMT 2023
//                Unpublished work. Copyright 2023 Siemens
//      This material contains trade secrets or otherwise confidential
//  information owned by Siemens Industry Software Inc. or its affiliates
//   (collectively, "SISW"), or its licensors. Access to and use of this
//     information is strictly limited as set forth in the Customer's
//                   applicable agreements with SISW.
//  Siemens software executing under x86-64 Linux on Fri Jun 13 02:17:09 PDT 2025.
//  64 bit version
//  Host: localhost.localdomain (1 x 2.6 GHz, 5786 MB RAM, 2048 MB Swap)
//  License server does not support this feature (dftadvisor)
//  License server does not support this feature (mtfastscanf)
//  License server does not support this feature (fastscan)
//  License server does not support this feature (mttsmembisr)
//  License server does not support this feature (mtdesigneditorf)
//  License server does not support this feature (mtmembisr)
//  License server does not support this feature (mtijtagf)
//  License server does not support this feature (mttsbscanf)
//  License server does not support this feature (mtnsbscanf)
//  License server does not support this feature (mtboundaryscanf)
//  License server does not support this feature (mtscanprof)
发表于 2025-6-13 17:38:27 | 显示全部楼层
panqiang88 发表于 2025-6-13 17:35
我用的是csh,所以环境变量如下配置:
setenv SALT_LICENSE_SERVER "/software/tessent/tessent_2023.3/ ...
你mac地址多少 我帮你重新做一个.   你的mac地址要和这个lic一样
发表于 2025-6-13 17:40:02 | 显示全部楼层
或者给你做lic的脚本,你自己做
发表于 2025-6-13 17:41:03 | 显示全部楼层
你path了没
发表于 2025-6-13 17:42:56 | 显示全部楼层
先path下. 然后用: mgclicgen.py  mac地址
自己做下
 楼主| 发表于 2025-6-13 17:57:24 | 显示全部楼层
自己做下
好的,谢谢!
先path下
     ---- 请问这个是指什么?
 楼主| 发表于 2025-6-13 18:14:20 | 显示全部楼层
自己做下
先path下
----请问这个是指运行下图中的1patch.sh命令吗?  要带什么参数吗?
发表于 2025-6-13 20:40:10 | 显示全部楼层
自己做下
thanks
GMT+8, 2025-10-14 03:41 , Processed in 0.020075 second(s), 4 queries , Gzip On, Redis On.
