楼主: tyt335588
求一个tessent2023的安装包和license
发表于 2025-4-5 21:48:02 | 显示全部楼层
yetping 发表于 2025-3-24 15:55
需要我帮你做一份吗?
有教程吗?能出个教程?就是上面那个压缩包解压后如何使用和安装liscense的教程。悬赏也可以。谢谢。
发表于 2025-4-7 08:15:29 | 显示全部楼层
将压缩包上传服务器,解压以后里面有个bin文件夹,把这个文件夹添加到用户的环境变量里面即可启动
发表于 2025-4-7 18:01:18 | 显示全部楼层
tessent -shell
//  Tessent Shell  2023.1    Fri Feb 17 22:27:00 GMT 2023
//                Unpublished work. Copyright 2023 Siemens
//      This material contains trade secrets or otherwise confidential
//  information owned by Siemens Industry Software Inc. or its affiliates
//   (collectively, "SISW"), or its licensors. Access to and use of this
//     information is strictly limited as set forth in the Customer's
//                   applicable agreements with SISW.
//  Siemens software executing under x86-64 Linux on Mon Apr 07 18:00:29 CST 2025.
//  64 bit version
//  Host: Banana (32 x 2.5 GHz, 31779 MB RAM, 4096 MB Swap)
//  Error: One of the following licenses is required, but none are available:
//         'Scan' (dftadvisor)
//         'FastScan' (mtfastscanf)
//         fastscan
//         mttsmembisr
//         'DesignEditor' (mtdesigneditorf)
//         mtmembisr
//         'Tessent IJTAG' (mtijtagf)
//         'BoundaryScan-TS' (mttsbscanf)
//         'BoundaryScan-LVNS' (mtnsbscanf)
//         'BoundaryScan-LV' (mtboundaryscanf)
//         'ScanPro' (mtscanprof)
//         'SoCScan' (mtsocscanf)
//         'MissionMode' (mtmissionmodef)
//         'PLLTest' (mtplltestf)
//         'MultiDie' (mtmultidief)
//         'MemoryBIST-TS' (mttsmemorybistf)
//         'MemoryBIST-LVNS' (mtnsmemorybistf)
//         'MemoryBIST-LV' (mtmemorybistf)
//         'SiliconInsight' (mtsiliconinsight)
//         'Diagnosis' (yieldascandiag)
//         'SerdesTest' (mtserdestestf)
//         'TestKompress' (testkomp)
//         'LogicBIST-TS' (mttslogicbistf)
//         'LogicBIST-LVNS' (mtnslogicbistf)
//         'LogicBIST-LV' (mtlogicbistf)
发表于 2025-4-9 17:24:07 | 显示全部楼层
pantengyun 发表于 2025-4-7 18:01
tessent -shell
//                Unpubli ...
缺少license
发表于 2025-4-23 09:21:00 | 显示全部楼层
谢谢分享
发表于 2025-6-5 17:15:24 | 显示全部楼层
yetping 发表于 2025-3-21 10:27
通过网盘分享的文件:tessent_2023_cracked.tar.gz
链接: https://pan.baidu.com/s/1PjwAbqxI3C4xuCwMTCi0 ...
大佬,可以分下lic工具吗
发表于 2025-6-5 18:37:00 | 显示全部楼层
感谢分享
发表于 2025-6-7 21:54:49 | 显示全部楼层
感谢分享
发表于 2025-6-8 04:38:00 | 显示全部楼层
Thanks for the sharing!
发表于 2025-6-12 23:23:01 | 显示全部楼层
感谢分享
GMT+8, 2025-10-19 05:32 , Processed in 0.018210 second(s), 3 queries , Gzip On, Redis On.
