查看: 3571|回复: 1
[求助] 求助一些这个代码击穿电压怎么仿真不出来啊
发表于 2025-3-6 16:15:30 | 显示全部楼层 |阅读模式
go atlas
mesh
x.mesh loc=0.00 spac=0.10
x.mesh loc=1.00 spac=0.10
x.mesh loc=2.00 spac=0.10
x.mesh loc=4.00 spac=0.20
x.mesh loc=6.00 spac=0.20
x.mesh loc=8.00 spac=0.20
x.mesh loc=10.00 spac=0.10
x.mesh loc=12.00 spac=0.10
x.mesh loc=14.00 spac=0.10
y.mesh loc=0.00 spac=0.10
y.mesh loc=1.00 spac=0.20
y.mesh loc=2.00 spac=0.10
y.mesh loc=3.00 spac=0.10
y.mesh loc=4.00 spac=0.20
y.mesh loc=5.00 spac=0.20
y.mesh loc=8.00 spac=0.20
y.mesh loc=20.00 spac=0.20
region number=1 x.min=0 x.max=14 y.min=5 y.max=20 material=4h-sic
region number=2 x.min=0 x.max=14 y.min=2 y.max=5 material=4h-sic
region number=3 x.min=0 x.max=14 y.min=1 y.max=2 material=Silicon
region number=4 x.min=2 x.max=13 y.min=0 y.max=3 material=Oxide
region number=5 x.min=2.3 x.max=3.8 y.min=0.5 y.max=2 material=Poly
region number=6 x.min=0 x.max=2 y.min=0 y.max=1 material=Aluminum
region number=7 x.min=13 x.max=14 y.min=0 y.max=1 material=Aluminum
region number=8 x.min=2.3 x.max=3.8 y.min=0 y.max=0.5 material=Aluminum
electrode reg=6 name=source
electrode reg=7 name=drain
electrode reg=8 name=gate
#n-sic
doping uniform conc=2e15 p.type region=1
doping uniform  conc=7.46e16 n.type region=2
#n-si
doping uniform conc=3e15 n.type x.min=0 x.max=2 y.min=1 y.max=2
doping uniform conc=3e15 n.type x.min=13 x.max=14 y.min=1 y.max=2
#godao
doping uniform conc=2e17 n.type x.min=2 x.max=13 y.min=3 y.max=3.3
doping uniform conc=2e17 n.type x.min=1.7 x.max=2 y.min=2 y.max=3.3
doping uniform conc=2e17 n.type x.min=13 x.max=13.3 y.min=2 y.max=3.3
#p-body
doping uniform conc=4e17 p.type x.min=0 x.max=2 y.min=1 y.max=2
#p+
doping uniform conc=1e18 p.type x.min=0 x.max=1 y.min=1 y.max=1.5
#n+
doping uniform conc=1e19 n.type x.min=1 x.max=2 y.min=1 y.max=1.5
doping uniform conc=1e19 n.type x.min=13 x.max=14 y.min=1 y.max=1.5
save outf=sicsildmos.str
quit
#jichuan
go atlas
mesh infile=sicsildmos.str
models cvt boltzman print temperature=300
log off
solve init
solve vgate=0
log outf=sicsildmos1.log
solve name=drain vdrain=0 vfinal=1500 vstep=50
tonyplot sicsildmos1.log
 楼主| 发表于 2025-3-6 16:24:50 | 显示全部楼层
希望万能的网友帮助一下,很急,谢谢
GMT+8, 2025-10-23 06:40 , Processed in 0.013511 second(s), 4 queries , Gzip On, Redis On.
