查看: 1168|回复: 7
求助:virtual_proto_vU-2023.03-sp1 无法识别安装包所在路径
发表于 2025-2-15 11:43:19 | 显示全部楼层 |阅读模式
在redhat 7.9 虚拟机上安装virtual_proto_vU-2023.03-sp1一直报下面的warning并且无法识别安装包所在的repository。请各位大佬帮帮忙指点一下
[0] Warning: Only C and default locale supported with the posix collation implementation
[5] Warning: Only C and default locale supported with the posix collation implementation
[5] Warning: Case insensitive sorting unsupported in the posix collation implementation
[5] Warning: Numeric mode unsupported in the posix collation implementation
[4271] Warning: Only C and default locale supported with the posix collation implementation
[4271] Warning: Case insensitive sorting unsupported in the posix collation implementation
[4271] Warning: Numeric mode unsupported in the posix collation implementation
[4943] Warning: Only C and default locale supported with the posix collation implementation
[4943] Warning: Case insensitive sorting unsupported in the posix collation implementation
[4943] Warning: Numeric mode unsupported in the posix collation implementation
[4970] Warning: Only C and default locale supported with the posix collation implementation
[4970] W
发表于 2025-2-15 12:42:04 | 显示全部楼层
把这个放到虚拟机里面试试
 楼主| 发表于 2025-2-15 12:44:48 | 显示全部楼层
In-lucky 发表于 2025-2-15 12:42
把这个放到虚拟机里面试试
我试过的,复制到虚拟机也是报相同的warning
发表于 2025-2-15 12:58:52 | 显示全部楼层
或者弄到下一级目录?
 楼主| 发表于 2025-2-15 13:06:31 | 显示全部楼层
In-lucky 发表于 2025-2-15 12:58
或者弄到下一级目录?
尝试过的,不行的
发表于 2025-2-15 19:20:25 | 显示全部楼层
 楼主| 发表于 2025-2-15 19:27:39 | 显示全部楼层
厉害,大佬可以请您指点一下安装步骤吗
发表于 2025-2-15 19:46:20 | 显示全部楼层
Maybe you could consider sharing the software so more people in the forum could take a look and help you
GMT+8, 2025-12-14 22:00 , Processed in 0.030541 second(s), 5 queries , Gzip On, Redis On.
