查看: 1165|回复: 1
A question about the message displayed when running dc_shell 2024.09.
发表于 2024-12-26 17:27:23 | 显示全部楼层 |阅读模式
When running dc_shell, the following message appears:
Info: [VCS_SAVE_RESTORE_INFO] ASLR (Address Space Layout Randomization) is detected on the machine.
To enable $save functionality, ASLR will be switched off and simv re-executed.
Please use '-no_save' simv switch to avoid this.
Could you explain what this message means?
                           Design Compiler Graphical
                                 DC Ultra (TM)
                                  DFTMAX (TM)
                              Power Compiler (TM)
                                 DesignWare (R)
                                 DC Expert (TM)
                               Design Vision (TM)
                               HDL Compiler (TM)
                               VHDL Compiler (TM)
                                  DFT Compiler
                               Design Compiler(R)
                 Version W-2024.09 for linux64 - Aug 27, 2024
                    Copyright (c) 1988 - 2024 Synopsys, Inc.
   This software and the associated documentation are proprietary to Synopsys,
Inc. This software may only be used in accordance with the terms and conditions
of a written license agreement with Synopsys, Inc. All other use, reproduction,
   or distribution of this software is strictly prohibited.  Licensed Products
     communicate with Synopsys servers for the purpose of providing software
    updates, detecting software piracy and verifying that customers are using
    Licensed Products in conformity with the applicable License Key for such
  Licensed Products. Synopsys will use information gathered in connection with
    this process to deliver software updates and pursue software pirates and
                                   infringers.
Inclusivity & Diversity - Visit SolvNetPlus to read the "Synopsys Statement on
            Inclusivity and Diversity" (Refer to article 000036315 at
                        https://solvnetplus.synopsys.com)
Initializing...
Current time:       Thu Dec 26 01:13:57 2024
Hostname:           mm24
CPU Model:          Intel(R) Core(TM) i9-10940X CPU @ 3.30GHz
CPU Details:        Cores = 14 : Sockets = 1 : Cache Size = 19712 KB : Freq = 3.30 GHz
OS:                 Linux 5.14.0-427.13.1.el9_4.x86_64
RAM:                250 GB (Free 238 GB)
Swap:               128 GB (Free 128 GB)
Work Filesystem:    /home mounted to /dev/md1
Tmp Filesystem:     / mounted to /dev/nvme0n1p3
Work Disk:          14305 GB (Free 10285 GB)
Tmp Disk:           316 GB (Free 305 GB)
CPU Load: 1%, Ram Free: 238 GB, Swap Free: 128 GB, Work Disk Free: 10285 GB, Tmp Disk Free: 305 GB
dc_shell>
发表于 2025-4-5 16:33:45 | 显示全部楼层
Try this command: sudo setenforce 0
GMT+8, 2025-12-13 19:00 , Processed in 0.015013 second(s), 4 queries , Gzip On, Redis On.
