楼主: chenxinkai
用WSL2安装$家2022 EDA工具过程分享
发表于 2024-12-27 23:33:22 | 显示全部楼层
mark了
发表于 2024-12-28 01:14:38 | 显示全部楼层
hummmm......
发表于 2025-1-3 08:39:35 | 显示全部楼层
首先感谢楼主的分享,
其他tool还没有尝试
socrates启动后crash,按照出错log的提示安装了很多依赖或者关联的软件,还是启动后软件崩溃,还是不能用
发表于 2025-1-3 09:14:11 | 显示全部楼层
anonymous_es 发表于 2025-1-3 08:39
首先感谢楼主的分享,
其他tool还没有尝试
socrates启动后crash,按照出错log的提示安装了很多依赖或者关联 ...
补充状况,电脑x1,系统win11,wsl2
发表于 2025-1-3 17:22:12 | 显示全部楼层
DVT IDE for Verilog/System Verilog 这个好像要license,怎么解决?
发表于 2025-1-12 11:23:33 | 显示全部楼层
我试了2023,2024版的dc会崩溃,2022的版本可以
发表于 2025-1-12 21:32:13 | 显示全部楼层
The 2023 version starts compiling slowly and always freezes for several seconds to over 10 seconds. It can run without errors, but it affects efficiency. This should be a license format issue and may require a license with a legal SIGN field.
The execution delay problem is not due to the license file issue. It is because the binary fetch was only processed for l_pubkey_verify and not for scl_lc_checkout, which only prevents checksum errors, causing snpslmd to proceed with license checkout through reread processing during execution. This is because it checks out using the very last condition among various checkout conditions. This is due to continuous repeated comparisons, and despite no specific errors (because l_pubkey_verify was fetched), it fails to receive the return value for the scl_lc_checkout condition.
Therefore, even if the return value for the scl_lc_checkout condition is not received, if there is no error in l_pubkey_verify, time is consumed while comparing the checkout mode conditions, and it waits until a connection failure is confirmed after attempting to connect to the internet and being blocked.
Consequently, if scl_lc_checkout is fetched, it executes immediately. Additionally, processing this eliminates the need to run the daemon.
发表于 2025-1-13 13:34:37 | 显示全部楼层
Helpful, many thanks
 楼主| 发表于 2025-1-13 15:09:49 | 显示全部楼层
joshua2784920 发表于 2025-1-12 21:32
The 2023 version starts compiling slowly and always freezes for several seconds to over 10 seconds.  ...
了解了, 现在有没有办法解决这个问题呢?
发表于 2025-1-13 17:07:10 | 显示全部楼层
To disassemble all executable binary files in the installed directory, locate the l_pubkey_verify and scl_lc_checkout routines, extract a fixed length of approximately 120 bytes as ASCII, and edit the replacement binary so that the first code becomes a ret:
:#  cl_lc_checkout_example
:binary
/5589e5575653e8322873ff81c309f18f0081ec8c0100008b7d088db5e8feffffc744245c97000000c7442458c4000000c7442454c3000000c7442450/
31c0c3575653e8322873ff81c309f18f0081ec8c0100008b7d088db5e8feffffc744245c97000000c7442458c4000000c7442454c3000000c7442450/.
Change 55 to 31 in the pattern and use the sfk program to perform the replacement.
GMT+8, 2025-11-3 12:08 , Processed in 0.017489 second(s), 4 queries , Gzip On, Redis On.
