求助各位大神:
我安装了redhat8.6 , IC618 , SPECTRE191 ,XCELIUM20,在跑仿真的时候,单独用SPECTRE跑正常跑完,但是用XCELIUM跑就报错:
xrun: *F,FLXDFLT: SPECTRE 19.1 ISR5 or older was found. XCELIUM AMS Flex requires SPECTRE 19.1 ISR6 or greater. The Spectre version may be specified using the '-spectre_path' option or provided via the system PATH. To disable AMS Flex add the '-disable_ams_flex' option. It will not be possible to disable AMS Flex from XCELIUM 21.03-s001.
TOOL: xrun(64) 20.09-s009: Exiting on Dec 12, 2024 at 15:56:44 CST (total: 00:00:01)
哪位大神给指导下,哪里出来问题?
