查看: 4308|回复: 21
tessent2023.1 -shell报license错误
发表于 2024-10-26 00:40:21 | 显示全部楼层 |阅读模式
通过网盘分享的文件:tessent2023.1.tar.gz
链接: https://pan.baidu.com/s/1k5mLc5ZGnWucP0fJP0cSuw 提取码: ihrm
--来自百度网盘超级会员v6的分享
tessent -shell
//  Tessent Shell  2023.1    Fri Feb 17 22:27:00 GMT 2023
//                Unpublished work. Copyright 2023 Siemens
//      This material contains trade secrets or otherwise confidential
//  information owned by Siemens Industry Software Inc. or its affiliates
//   (collectively, "SISW"), or its licensors. Access to and use of this
//     information is strictly limited as set forth in the Customer's
//                   applicable agreements with SISW.
//  Siemens software executing under x86-64 Linux on Sat Oct 26 00:36:30 CST 2024.
//  64 bit version
//  Host: edatools (4 x 3.1 GHz, 7802 MB RAM, 8063 MB Swap)
//  Error: One of the following licenses is required, but none are available:
//         'Scan' (dftadvisor)
//         'FastScan' (mtfastscanf)
//         fastscan
//         mttsmembisr
//         'DesignEditor' (mtdesigneditorf)
//         mtmembisr
//         'Tessent IJTAG' (mtijtagf)
//         'BoundaryScan-TS' (mttsbscanf)
//         'BoundaryScan-LVNS' (mtnsbscanf)
//         'BoundaryScan-LV' (mtboundaryscanf)
//         'ScanPro' (mtscanprof)
//         'SoCScan' (mtsocscanf)
//         'MissionMode' (mtmissionmodef)
//         'PLLTest' (mtplltestf)
//         'MultiDie' (mtmultidief)
//         'MemoryBIST-TS' (mttsmemorybistf)
//         'MemoryBIST-LVNS' (mtnsmemorybistf)
//         'MemoryBIST-LV' (mtmemorybistf)
//         'SiliconInsight' (mtsiliconinsight)
//         'Diagnosis' (yieldascandiag)
//         'SerdesTest' (mtserdestestf)
//         'TestKompress' (testkomp)
//         'LogicBIST-TS' (mttslogicbistf)
//         'LogicBIST-LVNS' (mtnslogicbistf)
//         'LogicBIST-LV' (mtlogicbistf)
发表于 2024-10-26 08:09:31 | 显示全部楼层
Did you use the daemon command of saltd?
发表于 2024-10-26 09:33:02 | 显示全部楼层
没破解吧
发表于 2024-10-26 10:26:35 | 显示全部楼层
patch it first, then make sure point lic path to SALT_LICENSE_SERVER and unset MGLS_LICENSE_FILE
回复 支持 3 反对 0
发表于 2024-10-26 13:36:08 | 显示全部楼层
感谢分享
 楼主| 发表于 2024-10-26 22:59:58 | 显示全部楼层
这个方法,经测试 可行,配置export SALT_LICENSE_SERVER=~/calibre.dat
发表于 2024-10-27 03:49:13 | 显示全部楼层
thanks for confirmation
发表于 2024-10-28 15:40:08 | 显示全部楼层
感谢分享经验
发表于 2024-10-29 17:35:00 | 显示全部楼层
thanks for share
发表于 2024-10-30 23:36:57 | 显示全部楼层
请问我装完,出现下列要如何处理?
//  FLEXlm version of vendor daemon is too old
//  FLEXlm version of the vendor daemon is too old:
//  Error: Failed to acquire licenses ('dftadvisor' or 'mtfastscanf' or 'fastscan' or 'mttsmembisr' or 'mtdesigneditorf' or 'mtmembisr' or 'mtijtagf' or 'mttsbscanf' or 'mtnsbscanf' or 'mtboundaryscanf' or 'mtscanprof' or 'mtsocscanf' or 'mtmissionmodef' or 'mtplltestf' or 'mtmultidief' or 'mttsmemorybistf' or 'mtnsmemorybistf' or 'mtmemorybistf' or 'mtsimemorydtpf' or 'mtsilogicdtpf' or 'mtsimixsigdtpf' or 'mtsiliconinsight' or 'mtsimemoryatef' or 'mtsilogicatef' or 'mtsimixsigatef' or 'yieldascandiag' or 'mtserdestestf' or 'testkomp' or 'mttslogicbistf' or 'mtnslogicbistf' or 'mtlogicbistf').
GMT+8, 2025-12-20 05:43 , Processed in 0.060354 second(s), 3 queries , Gzip On, Redis On.
