查看: 4887|回复: 12
论坛的下载的SCL2024.06版本,license启动报错,hspice2024.09启动报错
发表于 2024-9-21 00:22:24 | 显示全部楼层 |阅读模式
https://bbs.eetop.cn/thread-971025-1-1.html
09/21/2024 00:18:13 (snpslmd) Checking the integrity of the license file...
09/21/2024 00:18:13 (snpslmd) Valid SSS feature found.
09/21/2024 00:18:13 (snpslmd) The feature is needed to enable the other keys in your license file.
09/21/2024 00:18:13 (snpslmd) Siteid: 26356, Server Hostid: 000c29ce5e56, Issued on: 1/8/2014
09/21/2024 00:18:13 (snpslmd) ------------------------------------------------------------------
09/21/2024 00:18:13 (snpslmd) You are attempting to run the license server on a non-privileged domain/zone
09/21/2024 00:18:13 (snpslmd) Synopsys Licensing Server is restricted to run in this zone. Please contact support_center@synopsys.com for help
0:18:13 (lmgrd) snpslmd exited with status 33 (Bad configuration data)
0:18:13 (lmgrd) Please correct problem and restart daemons
[eda@eda ~]$ hspice -i /soft/synopsys/hspice/W-2024.09/hspice/demo/hspice/bjt/bjtbeta.sp -o bjtbeta.lis
Using: /soft/synopsys/hspice/W-2024.09/hspice/linux64/hspice  -i '/soft/synopsys/hspice/W-2024.09/hspice/demo/hspice/bjt/bjtbeta.sp' -o 'bjtbeta.lis'
  **error** simulation was stopped by signal = 6
查看bjtbeta.lis文件, Abnormal status returned from SCL Server是hspice没有破解完成吗,license是有正常输出的
18:23:06 (snpslmd) OUT: "hspice" eda@eda  [J3_7f0100_8988_PrimeSim_HSPICE_1]
18:23:15 (snpslmd) IN: "hspice" eda@eda  [J3_7f0100_8988_PrimeSim_HSPICE_1]
[eda@eda ~]$ cat bjtbeta.lis
****** PrimeSim HSPICE -- W-2024.09 linux64 (Aug 27 2024 9174816) ******
  Copyright (c) 1986 - 2024 by Synopsys, Inc. All Rights Reserved.
  This software and the associated documentation are proprietary
  to Synopsys, Inc. This software may only be used in accordance
  with the terms and conditions of a written license agreement with
  Synopsys, Inc. All other use, reproduction, or distribution of
  this software is strictly prohibited.
  Input File: /soft/synopsys/hspice/W-2024.09/hspice/demo/hspice/bjt/bjtbeta.sp
  Command line options: /soft/synopsys/hspice/W-2024.09/hspice/linux64/hspice -i /soft/synopsys/hspice/W-2024.09/hspice/demo/hspice/bjt/bjtbeta.sp -o bjtbeta.lis
  Start time: Sat Sep 21 18:23:06 2024
lic:
lic: FLEXlm: SDK_14.2
lic: USER:   eda                  HOSTNAME: eda
lic: HOSTID: 7f0100               PID:      8988
lic: Abnormal status returned from SCL Server; please contact with Synopsys for support.
1****** PrimeSim HSPICE -- W-2024.09 linux64 (Aug 27 2024 9174816) ******
****** job statistics summary tnom=   0.000 temp=   0.000 ******
发表于 2024-9-21 08:04:36 | 显示全部楼层
不能用root启动,换个普通用户试试?
 楼主| 发表于 2024-9-21 18:25:09 | 显示全部楼层
hitzhabc 发表于 2024-9-21 08:04
不能用root启动,换个普通用户试试?
使用普通用户启动license可以正常启动
17:57:50 (snpslmd) (@snpslmd-SLOG@) === Host Info ===
17:57:50 (snpslmd) (@snpslmd-SLOG@) Host used in license file: eda
17:57:50 (snpslmd) (@snpslmd-SLOG@) HostID node-locked in license file: 000c29ce5e56
17:57:50 (snpslmd) (@snpslmd-SLOG@) HostID of the License Server: 000c29ce5e56
17:57:50 (snpslmd) (@snpslmd-SLOG@) Running on Hypervisor: Unknown Hypervisor
17:57:50 (snpslmd) (@snpslmd-SLOG@) ===============================================
17:57:50 (snpslmd) Ecomms: Encrypted Communication disabled
17:57:50 (snpslmd) TCP_NODELAY NOT enabled
17:57:50 (snpslmd) Listener Thread: running
17:58:09 (snpslmd) OUT: "sx_wva" eda@eda
17:58:25 (snpslmd) IN: "sx_wva" eda@eda
18:00:15 (snpslmd) OUT: "hspice" eda@eda  [J3_7f0100_8216_PrimeSim_HSPICE_1]
18:00:29 (snpslmd) IN: "hspice" eda@eda  [J3_7f0100_8216_PrimeSim_HSPICE_1]
18:21:27 (snpslmd) OUT: "sx_wva" eda@eda
18:21:42 (snpslmd) IN: "sx_wva" eda@eda
发表于 2024-9-22 04:23:26 | 显示全部楼层
thanks, good to know
发表于 2024-9-22 09:07:43 | 显示全部楼层
不能用root启动,换个普通用户试试?
Noted, many thanks
发表于 2024-9-25 17:01:29 | 显示全部楼层
哈罗,能分享你的hspice 24吗
发表于 2024-12-25 18:16:23 | 显示全部楼层
这玩意咋用?
发表于 2024-12-26 01:43:30 | 显示全部楼层
OK, Thanks
发表于 2024-12-26 01:54:32 | 显示全部楼层
Could you share your license with me, please!
发表于 2025-1-8 16:41:28 | 显示全部楼层
你好,能加好友,分享下2024的版本吗
GMT+8, 2025-10-15 04:04 , Processed in 0.017640 second(s), 3 queries , Gzip On, Redis On.
