查看: 3480|回复: 22
$ynop$ rtl arch
发表于 2024-8-20 09:58:43 | 显示全部楼层 |阅读模式
Because the article is google drive .
Some one can not download so I upload to Baidu.
Because joshua2784920 said this way is not morality. So I decided to remove the link of this.
发表于 2024-8-20 10:11:19 | 显示全部楼层
这个方便
发表于 2024-8-20 10:23:37 | 显示全部楼层
感谢分享
发表于 2024-8-20 10:24:44 | 显示全部楼层
谢谢
发表于 2024-8-20 11:33:51 | 显示全部楼层
多谢费心。
发表于 2024-8-20 11:43:38 | 显示全部楼层
thanks
发表于 2024-8-20 14:08:54 | 显示全部楼层
Isn't it unethical to share it like this? If a file cannot be downloaded from Google Drive, you should provide a solution for that. Is there no sense of courtesy here?  If the intent was simply to help with downloading from Google Drive, then the price should have been minimal. If this place operates in this manner, I won't be able to continue sharing here anymore...
发表于 2024-8-20 15:10:19 | 显示全部楼层
thanks
发表于 2024-8-20 15:14:19 | 显示全部楼层
duoxie fenxiang
发表于 2024-8-20 15:58:50 | 显示全部楼层
joshua2784920 发表于 2024-8-20 14:08
Isn't it unethical to share it like this? If a file cannot be downloaded from Google Drive, you shou ...
take it easy
GMT+8, 2025-11-25 00:04 , Processed in 0.020869 second(s), 3 queries , Gzip On, Redis On.
