查看: 1847|回复: 9
许可证错误 S Platform Architect
发表于 2024-8-19 14:19:54 | 显示全部楼层 |阅读模式
我已经按照 https://bbs.eetop.cn/thread-896342-1-1.html 中的说明使用 1patch 对软件进行了修补,但许可证仍然被拒绝。麻烦您查看一下,我还在下面附上了 SCL 日志数据。
 楼主| 发表于 2024-8-19 14:24:09 | 显示全部楼层
dmesg: read kernel buffer failed: Operation not permitted
/home/galactica/EDA/Synopsys/virtual_proto/SLS/linux/common/bin/g++ -fmessage-length=0 -fno-var-tracking-assignments --param inline-unit-growth=300 -Wno-deprecated -g2 -O2 -fPIC -c Debug/ConvergenSC/cwr_simulation_vars.cpp -o Debug/ConvergenSC/cwr_simulation_vars.o
scc +cxx /home/galactica/EDA/Synopsys/virtual_proto/SLS/linux/common/bin/g++ +O1 -fmessage-length=0 -fno-var-tracking-assignments --param inline-unit-growth=300 - Wno-deprecated -g2 -O2 -fPIC -c "display.cpp" -o "Debug/display.o"
scc +cxx /home/galactica/EDA/Synopsys/virtual_proto/SLS/linux/common/bin/g++ +O1 -fmessage-length=0 -fno-var-tracking-assignments --param inline-unit-growth=300 - Wno-deprecated -g2 -O2 -fPIC -c "main.cpp" -o "Debug/main.o"
scc +cxx /home/galactica/EDA/Synopsys/virtual_proto/SLS/linux/common/bin/g++ +O1 -fmessage-length=0 -fno-var-tracking-assignments --param inline-unit-growth=300 - Wno-deprecated -g2 -O2 -fPIC -c "numgen.cpp" -o "Debug/numgen.o"
scc +cxx /home/galactica/EDA/Synopsys/virtual_proto/SLS/linux/common/bin/g++ +O1 -fmessage-length=0 -fno-var-tracking-assignments --param inline-unit-growth=300 - Wno-deprecated -g2 -O2 -fPIC -c "stage1.cpp" -o "Debug/stage1.o"
scc +cxx /home/galactica/EDA/Synopsys/virtual_proto/SLS/linux/common/bin/g++ +O1 -fmessage-length=0 -fno-var-tracking-assignments --param inline-unit-growth=300 - Wno-deprecated -g2 -O2 -fPIC -c "stage2.cpp" -o "Debug/stage2.o"
scc +cxx /home/galactica/EDA/Synopsys/virtual_proto/SLS/linux/common/bin/g++ +O1 -fmessage-length=0 -fno-var-tracking-assignments --param inline-unit-growth=300 - Wno-deprecated -g2 -O2 -fPIC -c "stage3.cpp" -o "Debug/stage3.o"
scc +cxx " /home/galactica/EDA/Synopsys/virtual_proto/SLS/linux/common/bin/g++ " -o Debug/sim-elab Debug/ConvergenSC/cwr_simulation_vars.o Debug/display.o Debug/main.o Debug /numgen.o Debug/stage1.o Debug/stage2.o Debug/stage3.o
/usr/bin/ld: warning: sc_main_hook_dyn_comp.o: requires executable stack (because the .note.GNU-stack section is executable)
scsim +config Debug +elab sim
FlexNet Licensing checkout error: Invalid (inconsistent) license key.
The license key and data for the feature do not match.
This usually happens when a license file has been altered.
Feature: PA-Base-Tool
License path: /home/galactica/EDA/Synopsys/Synopsys.dat:
FlexNet Licensing error:-8,523
license file(s): /home/galactica/EDA/Synopsys/Synopsys.dat
[SCL] 08/19/2024 16:21:26 PID:14534 Client: galactica Checkout denied PA-Base-Tool 2023.03
Error (License Manager): problem while obtaining licenses for tool:
FlexNet Licensing error:-8,234
Aborting.... <licensing_027>
make: *** [Debug/Makefile.sim:109: Debug/ConvergenSC/cwr_simulate.cpp] Error 1
发表于 2024-8-19 15:59:12 | 显示全部楼层
The link below is a verified method and is well-known to most users on eetop.
  https://bbs.eetop.cn/thread-922714-1-3.html
点评
http://bbs.eetop.cn/thread-879031-1-1.html 这个页面删除了,大佬能分享下对应的patch 吗  发表于 2024-8-19 16:47
发表于 2024-8-19 18:00:15 来自手机 | 显示全部楼层
可以解决
发表于 2024-8-19 18:14:16 | 显示全部楼层
You already have it.
Or you could find it easly.
Just search 1 patch. it has "orcad" crack file.
There are pubkey_verify and so on..
 楼主| 发表于 2024-8-19 18:56:13 | 显示全部楼层
I tried your method and it worked but following error still comes:
scc +cxx /home/galactica/EDA/Synopsys/virtual_proto/SLS/linux/common/bin/g++   +O1 -fmessage-length=0 -fno-var-tracking-assignments --param inline-unit-growth=300 -Wno-deprecated  -g2    -O2  -fPIC    -c "display.cpp" -o "Debug/display.o"
scc +cxx /home/galactica/EDA/Synopsys/virtual_proto/SLS/linux/common/bin/g++   +O1 -fmessage-length=0 -fno-var-tracking-assignments --param inline-unit-growth=300 -Wno-deprecated  -g2    -O2  -fPIC    -c "main.cpp" -o "Debug/main.o"
scc +cxx /home/galactica/EDA/Synopsys/virtual_proto/SLS/linux/common/bin/g++   +O1 -fmessage-length=0 -fno-var-tracking-assignments --param inline-unit-growth=300 -Wno-deprecated  -g2    -O2  -fPIC    -c "numgen.cpp" -o "Debug/numgen.o"
scc +cxx /home/galactica/EDA/Synopsys/virtual_proto/SLS/linux/common/bin/g++   +O1 -fmessage-length=0 -fno-var-tracking-assignments --param inline-unit-growth=300 -Wno-deprecated  -g2    -O2  -fPIC    -c "stage1.cpp" -o "Debug/stage1.o"
scc +cxx /home/galactica/EDA/Synopsys/virtual_proto/SLS/linux/common/bin/g++   +O1 -fmessage-length=0 -fno-var-tracking-assignments --param inline-unit-growth=300 -Wno-deprecated  -g2    -O2  -fPIC    -c "stage2.cpp" -o "Debug/stage2.o"
scc +cxx /home/galactica/EDA/Synopsys/virtual_proto/SLS/linux/common/bin/g++   +O1 -fmessage-length=0 -fno-var-tracking-assignments --param inline-unit-growth=300 -Wno-deprecated  -g2    -O2  -fPIC    -c "stage3.cpp" -o "Debug/stage3.o"
scc +cxx "  /home/galactica/EDA/Synopsys/virtual_proto/SLS/linux/common/bin/g++  "   -o Debug/sim-elab Debug/ConvergenSC/cwr_simulation_vars.o Debug/display.o Debug/main.o Debug/numgen.o Debug/stage1.o Debug/stage2.o Debug/stage3.o
[SCL] 08/19/2024 16:21:26 PID:14534 Client:galactica Checkout denied PA-Base-Tool 2023.03
Aborting ....   <licensing_027>
发表于 2024-8-19 19:02:06 | 显示全部楼层
可以解决
发表于 2025-1-15 16:41:31 | 显示全部楼层
问下大佬,这个怎么解决啊
发表于 2025-1-15 20:48:53 | 显示全部楼层
穿了个马甲,脱掉,再穿上
GMT+8, 2025-12-26 12:52 , Processed in 0.028794 second(s), 8 queries , Gzip On, Redis On.
