查看: 1344|回复: 2
ERROR
发表于 2024-7-25 13:58:36 | 显示全部楼层 |阅读模式
ERROR (SFE-1997): "input.scs" 30: I65.I66.NM1: parameter `m': Cannot run the simulation because parameter 'M_cm' has been used but no value has been assigned to it. Assign a value to the parameter and rerun the simulation.
发表于 2024-7-25 14:17:58 | 显示全部楼层
应该是你变量里用了m吧,这种容易和系统变量发生冲突,换个命名就好了
发表于 2024-7-25 14:20:26 | 显示全部楼层
变量M_cm没有赋值
GMT+8, 2025-12-19 11:55 , Processed in 0.015057 second(s), 3 queries , Gzip On, Redis On.
