查看: 4032|回复: 22
arteris noc 能不能在端口上插上axi pipeline(full/rev/fwd)?
发表于 2024-7-4 19:36:42 | 显示全部楼层 |阅读模式
例如:可以定义插入5级,6级等。如何操作?
谢谢
发表于 2024-7-5 02:16:30 | 显示全部楼层
You can configure in NIU two fwd/bwd on request/transport each and two fwd response/transport and one bwd transport
Go to architecture/datapath transport/topology
right click in topo window and choose add pipes or configure view/pipe/edit
if you need more pipes you can add links on the path and configure fwd/bwd pipes in links
发表于 2024-7-5 22:25:13 | 显示全部楼层
那要看你说的端口在哪里了, 如果是符合AXI协议的端口处, 应该没有问题。
如果端口处并不是AXI协议, 不确定,(毕竟, NOC是定义了一个基于内定的网络package协议的传输方式)
 楼主| 发表于 2024-7-6 08:23:42 | 显示全部楼层
tracy6969 发表于 2024-7-5 02:16
You can configure in NIU two fwd/bwd on request/transport each and two fwd response/transport and on ...
是不是选中蓝色三角形变黄,然后按右下角的apply就添加pipe了?
发表于 2024-7-6 09:24:59 | 显示全部楼层
Yes, grey means it can be selected/enabled.
When it turns green it is enabled.
Black means it can't be disabled given by Fl*xN*c design dependencies/requirements.
Btw, a faster way to enable/disable a pipe is to double-click the grey/green triangle instead of selecting and pressing apply button.
Just saw that I wasn't correct with the available pipes as I just displayed pipes.
In pipe editing mode much more pipe stages can be configured.
 楼主| 发表于 2024-7-8 19:54:59 | 显示全部楼层
Black means it can' ...
(1)原来是灰色的,后来变成了绿色的。是不是意味着pipeline被成功插入了?
(2)一组背靠背的三角符号是表示一组axi的req/rsp吗?
谢谢
发表于 2024-7-9 03:15:35 | 显示全部楼层
(2)一组背靠背的三角符号是 ...
(1) yes, you successfully inserted pipe stages
(2) No, back-to-back triangle means forward/backward. On the left you see request and on the right response path.
 楼主| 发表于 2024-7-13 10:42:47 | 显示全部楼层
(2) No, back-to-back triangle means forward/backwa ...
你好,再请教个问题。
  如何在一个noc pdd里连接2个subsys(例如:modem、media)的noc?
这2个subsys noc可以是2个pdd也可以只是2个本地noc
谢谢
发表于 2024-7-13 12:06:58 | 显示全部楼层
You keep the NOCs to be connected in one pdd.
Then you create a NOC composition where you define socket and port connectivity.
 楼主| 发表于 2024-8-6 07:39:02 | 显示全部楼层
Then you create a NOC composition where you define soc ...
请问这一块的描述在哪个doc里?我仔细看一下,谢谢
GMT+8, 2025-12-26 02:58 , Processed in 0.049008 second(s), 3 queries , Gzip On, Redis On.
