在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 706|回复: 1
[help/req] M0nt3r Pr0cisi3n Synth 2002 (Library needed)
发表于 2024-6-13 18:44:13 | 显示全部楼层 |阅读模式
Hello friends,
I am looking for a old version of Precision Synthesis "2002", in order to get a library for Xilinx 5200 family from it.
It was only released from 2002a, 2002b, 2002c, and 2002d from same year, in 2003 it was removed.
Notes: Leonardo libraries crash modern precision, so needs to be the the specific library for Precision to work fine.
If I try to run Leonardo Library it kind of pass but don't work propertly, and in modern precision complete crashes the application, because wasn't ment for precision.
I need the correct compiled precision version to work.
Here is what  it says if I try to run Leonardo library inside Precision:
# Warning, Reading an outdated format 403 of library
# Library version = 2.3
The correct Precision format is 200x.xx format something like that.
If anybody has this program could you share it or the library with me? Here is the files I need.
PS2002\ Mgc_home\ pkgs\ psr\ techlibs\ xi5.ini
PS2002\ Mgc_home\ pkgs\ psr\ techlibs\ xi5.syn
PS2002\ Mgc_home\ pkgs\ psr\ techlibs\ devices.ini
PS2002\ Mgc_home\ pkgs\ psr\ modgen\ xi5.vhd
 楼主| 发表于 2024-6-13 22:31:04 | 显示全部楼层
[SOLVED]
GMT+8, 2025-2-18 12:12 , Processed in 0.014484 second(s), 6 queries , Gzip On, Redis On.
