查看: 10439|回复: 37
$YNOPSYS VIP V-2023.12
发表于 2024-2-16 15:29:36 | 显示全部楼层 |阅读模式
I used Synopsys VIP version V-2023.12 and daemon's license version 2023.09 (FlexNet Licensing version v11.19.4.1 build 291070 x64_lsb - Synopsys Corporate Licensing (SCL) Release: version SCL_2023.09). When I run example dfi_svt and ddr_svt, error occured:
In simulation log:
  reporter [LICENSING] Encountered SLI error 'License server system does not support this version of this feature.'
  reporter [LICENSING] License checkout failure. Authorization not granted for suite 'ddr-base'
In License server log:
  DENIED: "vip-DDR5-SVT" - "v2021.06"(License server system does not support this version of this feature. (-25,334))
  DENIED: "vip-soc-library-svt" - "v2021.06"(License server system does not support this version of this feature. (-25,334))
  DENIED: "vip-library-svt" - "v2021.06"(License server system does not support this version of this feature. (-25,334))
  DENIED: "vip-library2019-svt" - "v2021.06"(License server system does not support this version of this feature. (-25,334))
Please help me fix it. Thanks
 楼主| 发表于 2024-2-16 15:51:14 | 显示全部楼层
Help me!!
回复 支持 0 反对 1
发表于 2024-2-16 22:03:49 | 显示全部楼层
提取vip的代码可以用其它工具解出来就好
发表于 2024-2-16 23:08:17 | 显示全部楼层
这个版本一般人都没有用过
发表于 2024-2-18 05:17:17 | 显示全部楼层
Check your license file , it seems that the version in the license file is older or the feature is missing
发表于 2024-2-18 10:31:02 | 显示全部楼层
印象旧版本都是揭秘开sequence item 那个,把报错的行注释了
发表于 2024-2-18 13:04:04 | 显示全部楼层
发来看看
发表于 2024-2-18 16:12:59 | 显示全部楼层
Any progress yet?
 楼主| 发表于 2024-2-19 10:20:39 | 显示全部楼层
I used vcs and questasim, but I received same error.
 楼主| 发表于 2024-2-19 10:23:39 | 显示全部楼层
trashio 发表于 2024-2-18 05:17
Check your license file , it seems that the version in the license file is older or the feature is m ...
Yeah, I think so. I am looking for a license file in version V*.
GMT+8, 2025-10-21 23:27 , Processed in 0.016442 second(s), 3 queries , Gzip On, Redis On.
