查看: 1808|回复: 7
求助: Unable to open -nograph 的错误?
发表于 2024-1-2 21:22:26 | 显示全部楼层 |阅读模式
hello  各位朋友
在安装软件 运行virtuoso -nograph -replay 命令时候 出现下面错误,而且一直解决不了。
请问各位朋友,个人感觉好像是display的问题,有谁有经验可以分享一下j
*WARNING* Unable to open -nograph X Window Display ":95"
*WARNING* (using "exec /opt/Cadence/IC618/tools.lnx86/dfII/../bin/cdsVncserver :95 -co /usr/share/X11/rgb&").
*WARNING* cdsXvnc output may be found in file $HOME/.vnc-cds/ic:95.log
Trying another display...
*WARNING* Unable to open -nograph X Window Display ":96"
*WARNING* (using "exec /opt/Cadence/IC618/tools.lnx86/dfII/../bin/cdsVncserver :96 -co /usr/share/X11/rgb&").
*WARNING* cdsXvnc output may be found in file $HOME/.vnc-cds/ic:96.log
发表于 2024-1-2 22:19:50 | 显示全部楼层
加个环境变量试一下
发表于 2024-1-3 01:04:36 | 显示全部楼层
if higher than isr17 then install xorg-x11-server-Xvfb
 楼主| 发表于 2024-1-3 10:41:35 | 显示全部楼层
krman33 发表于 2024-1-2 22:19
加个环境变量试一下
您好,具体怎么加呢
 楼主| 发表于 2024-1-3 10:44:41 | 显示全部楼层
Do you mean that if the version of the virtuoso is higher than isr17, we should install xorg-x11-server-Xvfb ?
发表于 2024-1-4 21:35:28 | 显示全部楼层
Henry_ 发表于 2024-1-3 10:44
Do you mean that if the version of the virtuoso is higher than isr17, we should install xorg-x11-s ...
yes ,cdsXvnc is removed since isr17 onwards
发表于 2024-5-10 15:57:36 | 显示全部楼层
同样碰到这个问题,楼主解决了吗
发表于 2024-5-10 18:12:55 | 显示全部楼层
good to know, thanks
GMT+8, 2025-12-23 10:00 , Processed in 0.016018 second(s), 3 queries , Gzip On, Redis On.
