楼主: silverstar66
[原创] 【vmware+wsl,CentOS7系统】23最新Cadence虚拟机下载
发表于 2025-6-14 08:30:52 | 显示全部楼层
感谢
发表于 2025-6-14 17:20:17 | 显示全部楼层
abe_00 发表于 2024-11-13 10:16
我用的wsl版本同样有这个问题。
vm版本有这个问题吗?
解决了吗,我也遇到了
发表于 2025-6-18 01:28:31 | 显示全部楼层
BFLV 发表于 2024-12-5 00:23
Thanks for sharing!
我在使用VMware版的cadence IC231时,help文档打不开,请问您这边出现过这样的问题吗 ...
Did you solved?
发表于 2025-6-18 01:33:36 | 显示全部楼层
have a question. thank you for your uploading.
now im installing IC231 / SPECTRE231 / Calibre 2025 into Rocky 8.
C tools almost tested but Calibre aborted by RVE Socket Error.
if i use in .bashrc "MGC_Calibre_schematic_server" "MGC_Calibre_layout_server" = 'hostname':9199, 9189?
i change already  but still aborted with message.
"illegal instruction"
setup
OS Rocky 8.1
Calibre : aoj 2025 + use_calibre_vco=aoj
发表于 2025-6-19 00:10:27 | 显示全部楼层
now im installing IC231 / SPECTRE231 / Calibre 2025 i ...
solved
发表于 2025-6-25 08:50:18 | 显示全部楼层
How can I download it?
发表于 2025-6-25 19:44:08 | 显示全部楼层
Thanks for sharing!
update to IC231 130, it just solved
library browser works well
发表于 2025-6-28 02:11:58 | 显示全部楼层
大佬晚上好,我用的是WSL2的IC618,用的ADE L仿真了一个简单的OTA,结果一直卡在Loading paraplot.cxt,有点不知道该怎么办。但是用AED Explorer仿真就没问题。附上完整的日志:
COPYRIGHT (C) 1992-2020  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
          (C) 1992-2020  UNIX SYSTEMS Laboratories INC.,
                         Reproduced with permission.
This Cadence Design Systems program and online documentation are
proprietary/confidential information and may be disclosed/used only
as authorized in a license agreement controlling such use and disclosure.
          RESTRICTED RIGHTS NOTICE (SHORT FORM)
Use/reproduction/disclosure is subject to restriction
set forth at FAR 1252.227-19 or its equivalent.
Program: @(#)$CDS: virtuoso version 6.1.8-64b 08/04/2020 19:31 (cpgsrv11) $
Sub version: sub-version  IC6.1.8-64b.500.13  (64-bit addresses)
Loading geView.cxt
Loading menuBuilder.cxt
Loading schView.cxt
Loading selectSv.cxt
Loading wireEdit.cxt
Loading pte2.cxt
Loading xlUI.cxt
Loading auCore.cxt
Loading vhdl.cxt
Loading seismic.cxt
Loading ci.cxt
Loading ams.cxt
Loading adexlDM.cxt
Loading cli.cxt
Loading lp.cxt
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.06s.
Successfully checked out 'Virtuoso_MixedSignalOpt_Layout' license.
*WARNING* LIB basic from File /opt/cadence/IC618/tools.lnx86/dfII/etc/cdsDotLibs/composer/cds.lib Line 1 redefines
LIB basic from File /home/meow/PDK/cds.lib
Insert UNDEFINE basic
before DEFINE basic
    in /opt/cadence/IC618/tools.lnx86/dfII/etc/cdsDotLibs/composer/cds.lib
Or remove or comment out DEFINE basic
    in /home/meow/PDK/cds.lib
to suppress this warning message.
*WARNING* LIB US_8ths from File /opt/cadence/IC618/tools.lnx86/dfII/etc/cdsDotLibs/composer/cds.lib Line 2 redefines
LIB US_8ths from File /home/meow/PDK/cds.lib
Insert UNDEFINE US_8ths
before DEFINE US_8ths
Or remove or comment out DEFINE US_8ths
*WARNING* LIB analogLib from File /opt/cadence/IC618/tools.lnx86/dfII/etc/cdsDotLibs/artist/cds.lib Line 1 redefines
LIB analogLib from File /home/meow/PDK/cds.lib
Insert UNDEFINE analogLib
before DEFINE analogLib
    in /opt/cadence/IC618/tools.lnx86/dfII/etc/cdsDotLibs/artist/cds.lib
Or remove or comment out DEFINE analogLib
END OF SITE CUSTOMIZATION
//  Calibre Skill Interface * (v2023.2_16.9) *
//                         Copyright Siemens 1996-2020
//                             All Rights Reserved.
//         THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
//            WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION
//              OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.
Loading oasis.cxt
Loading analog.cxt
Loading asimenv.cxt
Loading spectrei.cxt
Loading dal.cxt
Loading awv.cxt
Loading socket.cxt
Loading par.cxt
Loading alvs.cxt
Loading caa.cxt
Loading amps.cxt
Loading adexlCore.cxt
Loading adexl.cxt
Loading vdsil.cxt
Loading lx.cxt
Loading lce.cxt
Loading le.cxt
Loading rte.cxt
Loading te.cxt
Loading schHDL.cxt
Loading devCheck.cxt
Loading relXpert.cxt
//  Calibre layout-server initialized successfully at socket 9189, host meowu.
//  Calibre v2023.2_16.9    Tue Apr 4 17:40:41 PDT 2023
//                   Copyright Siemens 1996-2023
//  The registered trademark Linux is used pursuant to a sublicense from LMI, the
//  exclusive licensee of Linus Torvalds, owner of the mark on a world-wide basis.
//  Mentor Graphics software executing under x86-64 Linux
Calibre server launched successfully
//  Calibre RealTime: Initialization complete
before DEFINE basic
libManager Qt Warning: QXcbShmImage: shmget() failed (38: Function not implemented) for size 2553248 (1093x584)
before DEFINE basic
Loading gpdk180/libInit.il ...
Loading gpdk180/loadCxt.ile ... done!
Loading context 'gpdk180' from library 'gpdk180' ... done!
Loading context 'pdkUtils' from library 'gpdk180' ... done!
Loading gpdk180/.cdsenv ... done!
Loading gpdk180/display.drf ... done!
Loading gpdk180/libInitCustomExit.il ... Loading hspiceD.cxt
Loading spectreinl.cxt
Loading msgHandler.cxt
Loading UltraSim.cxt
Loading AMSOSS.cxt
Loading AMS.cxt
  *              Cadence Design Systems, Inc.                 *
  *                    Generic 180nm PDK                      *
  *                        (gpdk180)                          *
  *                       Version 3.2                         *
done!
Loaded gpdk180/libInit.il successfully!
Loading schematic.cxt
Loading ddui.cxt
Loading vb.cxt
Loading nt.cxt
Loading oi.cxt
Loading see.cxt
Loading treeAssistant.cxt
Loading asst.cxt
Loading simui.cxt
Loading hsm.cxt
Loading viva.cxt
Loading cdf.cxt
Delete psf data in /home/meow/PDK/tsmc180rf_OA/tsmc18rf/simulation/tb_ota/spectre/schematic/psf.
generate netlist...
Loading genldCpf.cxt
Loading cpf.cxt
Loading seCore.cxt
Begin Incremental Netlisting Jun 28 01:41:10 2025
End netlisting Jun 28 01:41:10 2025
Loading monte.cxt
The netlist is up to date.
Time taken to compare the design with netlist:   0.0s
      ...successful.
compose simulator input file...
      ...successful.
start simulator if needed...
      ...successful.
发表于 2025-6-28 02:24:26 | 显示全部楼层
bxshcc 发表于 2024-6-16 22:24
安装Virtuoso500.22版本
你好,请问如何升级到500.22版本呢
发表于 2025-6-29 14:16:29 | 显示全部楼层
akimoto_ 发表于 2025-6-28 02:24
你好,请问如何升级到500.22版本呢
找教程安装,论坛也有安装包。或者不安装每次打开软件先运行一次ade xl的仿真  再开ade l就可以正常仿真了
GMT+8, 2025-9-16 01:26 , Processed in 0.017963 second(s), 3 queries , Gzip On, Redis On.
