查看: 3423|回复: 8
SKM Power Tools 10 and SKM GroundMat 2.0.2
发表于 2023-9-5 22:01:51 | 显示全部楼层 |阅读模式
SKM is probably the most widely used software package in the industry, providing a complete line of electrical engineering software that includes SKM Power Tools for Windows and Arc Flash Hazard Analysis. As with any software or tool, it is only as good as the operator and information put in. Our engineers have received extensive training and have the field experience to get the job done accurately and correctly. We also have years of experience the allow us to look at the results from the software and recognize when those results do not match expectations SKM has proven, time and again, it is reliable with an extensive library, and a great customer support team for those times we need them.
Quite simply, Power*Tools for Windows is the Gold Standard to which all other software packages must be compared. No other software can match SKM Power*Tools for project analysis flexibility, speed, or database integration
  • Design safer power systems by quickly and easily evaluating all devices for proper short circuit levels, and application within acceptable voltage ratings.
  • Save time with automatic TCC drawing and associated one-line creation from the main one-line diagram interface.
  • Create and design efficiently by using CAPTOR's clone command to copy individual components, one-line diagrams, and TCC drawings.
  • Increase efficiency with fully customizable output organized to locate and interpret results quickly.
  • Eliminate errors by keeping all input data, one-line diagrams, TCC's and study results in a single project database.
  • Communicate designs effectively with high quality graphical output and custom formats.
Features:
  • Use the branch fault current protective devices at a single user defined fault location to automatically terminate the curves and simulate sequential protection operations.
  • Search across all TCCs or one-lines to identify which documents contain a specific device.
  • Globally turn on/off device labels, short circuit flags, and datablocks for all TCCs in the project.
  • Continuous display of TCC drawings with real-time graphical editing of device settings.
  • An extensive library including thousands of protective devices created and validated by electrical engineers.
  • A flexible library for adding new device entries makes it easy to add new devices and to match setting descriptions.
  • Custom output layout s to position TCC, one-line, setting sheet, and company logo on a single page, and option to group print all TCCs in a single action to printer, clipboard, Metafile, or PDF.
  • Full control over colors, fill patterns, line weights, grid density, fonts, data display, and axis scales, for high quality output.
  • TCC Drawings and the associated one-lines are generated automatically from the main one-line or manually by adding new devices to a TCC.
  • Plot multifunction relays and store both 'as-found' and 'recommend' settings, or 'phase' and 'ground' settings, and multiple protection functions in the same TCC.
  • An on-screen locator to quickly display and evaluate clearing times between devices.
  • Adjust device settings graphically by dragging curve segments on the TCC drawing with your mouse (movement is restricted to valid device settings).
  • Display one-lines next to TCC drawings and apply different datablocks in both areas.
  • Export multiple TCCs to DXF or AutoCAD Xrefs.
SKM GroundMat
SKM GroundMat is a program for substation ground grid design and analysis. It is designed to help optimize grid design or reinforce existing grids of any shape. It uses a general-purpose finite element algorithm for potential analysis and graphical facilities to valid ate ground system efficiency.
Benefits:
  • Design safer and more cost effective ground grids.
  • Save time with graphical entry and display.
  • Communicate designs more easily with professional reports and graphs.
  • Evaluate alternatives quickly and easily to establish an optimal design.
  • Save time with design wizard capabilities.
  • PTW GroundMat is an important tool every power system engineer should have.
Solution Algorithms:
  • Finite element analysis of the ground conductors.
  • Finite element analysis of the ground rods.
  • Grid conductor current displacement using Matrix analysis.
Analysis Options:
  • Earth model analysis from field measurements.
  • User specified fault current.
  • Grid and Ground potential analysis.
  • Ability to analyze multiple ground systems.
  • Ability to analyze the potential rise for each grounding system including neighboring passive grids or rods.
  • Safety analysis including surface materials, based on body weight and exposure time.
  • Option to use IEEE Std. 80 or IEC Std. 479 for safety analysis.
  • Calculation of maximum permissible touch and step voltages.
  • Comprehensive report for grid and rod configuration.
  • Comprehensive report for surface potential analysis featuring station data and currents diffused to ground by the grid elements.
  • Danger point evaluation.
  • Touch voltage, step voltage, and earth potential analysis.
Interface Options:
  • Create and store alternative designs with a simple copy/paste.
  • Data entry for grid and rods in spreadsheet format.
  • Data entry for earth model in spreadsheet format.
  • Grid/rod/profile wizards to setup initial system.
  • 3D/2D representation of grid and rod configuration.
  • 3D display of touch voltage, step voltage, and earth potential plots.
  • Report viewer for text reports.
  • Cut, copy and paste grid/rod segments in spreadsheet.
  • Range-checking for simulation parameters.
  • User-defined thresholds for danger area evaluation.
  • User-defined color coding for graphical safety analysis.
  • Metric and English units.
  • Group print function.
Project setup Options:
  • Stores multiple study revisions for each project.
  • Expanding tree structure to manage project revisions.
  • Input data and output results saved for each study.
  • Copy, paste and rename study revisions to compare alternative designs.
  • Run studies for multiple study revisions as a single action.
For more information about SKM Power Tools 10 and GroundMat 2.0.2, please contact  fast.forever24@gmail.com
发表于 2023-9-6 04:25:18 | 显示全部楼层
thanks
发表于 2023-9-6 17:03:53 | 显示全部楼层
这个工具能干嘛啊?看起来好炫酷啊
发表于 2023-9-7 09:45:35 | 显示全部楼层
发广告的是不是该禁掉?
发表于 2023-9-7 11:09:51 | 显示全部楼层
謝謝您的分享
发表于 2023-9-7 11:18:54 | 显示全部楼层
thanks
发表于 2023-9-7 11:20:38 | 显示全部楼层
在哪下?
发表于 2023-9-12 14:56:08 | 显示全部楼层
在哪下?
发表于 2024-7-25 16:16:30 | 显示全部楼层
联系 3766906032@qq.com 获取
GMT+8, 2025-12-26 08:16 , Processed in 0.021570 second(s), 4 queries , Gzip On, Redis On.
