查看: 3350|回复: 12
[求助]ICC2启动失败
发表于 2023-7-2 12:21:43 | 显示全部楼层 |阅读模式
vP-2019.03-SP5,SCL2023.03,RHEL7.9
执行icc2_shell -gui后跑出以下错误讯息,请问这该怎么解?
Error:  Onepossible reason for this error is that FLEXlm version of the application ishigher than the license daemon version. If this is the case, please upgrade thelicense daemon to latest version (SCL-602)
[SCL] Error:  One possible reason forthis error is that FLEXlm version of the application is higher than the licensedaemon version. If this is the case, please upgrade the license daemon tolatest version (SCL-602)
Unable to get shell start-up license keys. Cannotinvoke shell. Following license(s) must exist : {ICCompilerII orICCompilerII-NX}.
Maximum memory usage for this session: 90.52 MB
Maximum memory usage for this session includingchild processes: 90.52 MB
CPU usage for this session:     2 seconds (  0.00 hours)
Elapsed time for this session:     2 seconds (  0.00 hours)
Thank you for using IC Compiler II.
补充内容 (2025-4-19 22:51):
已解决
发表于 2023-7-2 21:34:16 | 显示全部楼层
说了版本不对了
 楼主| 发表于 2023-7-2 23:10:39 | 显示全部楼层
krman33 发表于 2023-7-2 21:34
说了版本不对了
感谢您的回覆,但我很确定问题点不是在这方面。
发表于 2023-11-21 00:09:07 | 显示全部楼层
同问楼主,这个问题解决了吗
点评
Yes  发表于 2025-2-23 22:54
发表于 2025-4-7 20:48:19 | 显示全部楼层
楼主怎么解决的??
点评
1patch  发表于 2025-4-7 21:23
发表于 2025-4-8 02:23:38 | 显示全部楼层
发表于 2025-4-8 16:37:59 | 显示全部楼层
林冬一 发表于 2023-11-21 00:09
同问楼主,这个问题解决了吗
我用icc2 2020 1patch 还是不行,同样问题, 看样子要找2019 版本了
发表于 2025-5-8 16:52:43 | 显示全部楼层
楼主如何解决的?
点评
https://bbs.eetop.cn/thread-978013-1-1.html  发表于 2025-5-12 10:29
发表于 2025-6-18 14:32:04 | 显示全部楼层
楼主如何解决的呀
发表于 2025-11-6 11:54:47 | 显示全部楼层
可以share一下icc2的资源吗
GMT+8, 2025-12-30 03:44 , Processed in 0.021145 second(s), 4 queries , Gzip On, Redis On.
