查看: 1687|回复: 1
打不开layout问题求助
发表于 2023-6-26 14:47:48 | 显示全部楼层 |阅读模式
问题描述:IC615打开layout文件报错 错误如下:
Load shared object file /opt/cadence/ASSURA615/tools.lnx86/assura/lib/64bit/libavview.so
Version:  @(#)$CDS: libavview.so version av4.1roduction:dfII6.1.5-64b:IC6.1.5-64b.500.10 06/06/12 10:06 (sjfql440) $
rcxui.cxt was successfully loaded
Loading sna.cxt for 6.1.5-64b Cadence version.
*WARNING* Failed to load context file '/opt/cadence/ASSURA615/bin/64bit/etc/context/6.1.5/64bit/sna.cxt'.
*Error* length: argument must be a list or an array - "/opt/mentor/calibre2019/aoi_cal_2019.3_25.15/shared/pkgs/icv/tools/realtime/laker/icon/xpm/run_drc.xpm"
 楼主| 发表于 2023-6-27 15:14:20 | 显示全部楼层
问题已解决:原因是IC615安装时从其他服务器拷贝过来的,重新使用安装包安装打patch就解决了
GMT+8, 2025-12-15 15:47 , Processed in 0.016731 second(s), 4 queries , Gzip On, Redis On.
