查看: 1995|回复: 1
[原创] PVCAD Mega Bundle 29.1.1 x64
发表于 2023-6-16 23:46:11 | 显示全部楼层 |阅读模式
PVCAD Mega
Multiple-megawatt layouts on complex terrain. Precise solar engineering built on Autodesk technology.
Quickly completes site capacity layouts for utility-scale projects of any size using click-and-drag control and place tracker blocks on any angle within the project site.
Lightning Fast Automated Layouts
Quickly complete site capacity layouts for utility-scale projects of any size using click-and-drag control and place tracker blocks at any angle within the project site.
·        Auto placement of partial tracker rows
·        Place access roads & equipment pads
·        Finish in 5 mins or less
Advanced Topology Analysis
Perform more accurate site assessments in less time by analyzing piers, verifying that trackers can be deployed to specification.
·        Import USGS, Google Earth, custom data
·        Avoid false positives from limited pier data
·        Improve cost control
Side-by-Side Comparisons
Eliminate guesswork and see how modifying structural and electrical components affect system design and performance estimates.
·        Compare fixed tilt & single-axis trackers
·        Thin-film vs crystalline silicon modules
·        GCR, Output capacity & production values
Pier & Top-of-Pile Plans
Generate automatic pier plans with pier locations, corresponding surface altitude, and top-of-pile reports for leading tracker systems, including Nextracker and Array Technologies.
  • ·        Calculate pier data for trackers or fixed tilt tables
·        Specify pier location, surface altitude, reveals, top of pile
·        Export CSV files for data portability
Export to PVSyst
Easily export your design to PVSyst for bankable energy yield modeling
  • Automatically  generate a PVSyst shade scene (.SHD) file
  • Also generates a project file (.PRJ) and meteo file (.MET)
  • Open the files in PVSyst to model the energy yield including topography effects
fFoFor more information about PVCAD Mega, please contact fast.forever24@gmail.com
发表于 2024-4-28 23:55:31 | 显示全部楼层
GMT+8, 2025-12-12 04:45 , Processed in 0.011246 second(s), 3 queries , Gzip On, Redis On.
