查看: 1232|回复: 0
[求助] 如何用CST仿真介质分界面的全反射(临界角)?
发表于 2023-5-24 23:02:57 | 显示全部楼层 |阅读模式
大家好!
自己在用CST建模仿真(unit_cell+open边界)时,发现从介电为5.5的光密介质向介电为1的光疏介质中斜入射时,若入射角超过了临界角,软件会报错“The material in port Zmax corresponds to a scan angle outside the visible space. Please change the background material to the material with the lowest product of relative permeability and relative permittivity (the lowest refraction index), or use periodic boundaries with the phase specified rather than the scan angle”。尝试了很多种方法,但都没有成功。请问大家遇到过类似问题么?应该如何解决呢??万分感谢!!
补充:后来发现HFSS仿真时也有同样问题,但HFSS论坛上有人给出了解决方案(https://forum.ansys.com/forums/t ... oundary-conditions/)。自己验证过,该方法确实有效。但可惜的是CST中修改“background material”的方法并不适用!
GMT+8, 2025-10-1 18:23 , Processed in 0.015852 second(s), 4 queries , Gzip On, Redis On.
