查看: 1586|回复: 0
[原创] Schlumberger OLGA 2021.1 Full Simulation Features License
发表于 2023-4-5 07:10:44 | 显示全部楼层 |阅读模式
SCHUMBERGER OLGA 2021.1 FULL FEATURES LICENSE
[color=var(--color-light)]This dynamic multiphase flow simulator models time-dependent behaviors, and transient flow, to maximize production potential. Transient modeling is an essential component of feasibility studies and field development design. Investigate transient behavior in pipelines and wellbores.
[color=var(--color-light)]Transient simulation with this simulator provides an added dimension to steady-state analyzes by predicting system dynamics such as time-varying changes in flow rates, fluid compositions, temperature, solids deposition, and operational changes.
[color=var(--color-light)]It includes the updates from the NORSOK M-506 standard, incorporating organic (acetic) acids in the computation of pH. With this, OLGA can now accurately simulate the effects of this on the corrosion rate. It allows users to utilize equation-of- state selections for pressure/enthalpy calculations for single-component systems.
Features of Schlumberger OLGA
  • Dynamic multiphase flow simulator
  • Improved corrosion model
  • Pressure Enthalpy (PH) tables
  • Improved scripting capabilities
  • Achieve higher accuracy when operating around the critical point
  • Enhanced flexibility for high-pressure protection system design
  • Improved functionality for pure CO2
  • Improved handling of low-pressure situations
  • New mass-based option for injection rate calculations
  • More accurate water accumulation
  • Better prediction of pressure drop
NOTE:
If you are interested in the full (activated 'ready to simulate' indicator for designed models) licensed software Schlumberger OLGA 2021.1 with full simulation features, then do well to contact fast.forever24@gmail.com
GMT+8, 2025-9-19 04:14 , Processed in 0.013156 second(s), 4 queries , Gzip On, Redis On.
