查看: 3587|回复: 6
求助EXT191环境变量怎么设置
发表于 2023-3-17 22:24:45 | 显示全部楼层 |阅读模式
悬赏200资产已解决
小弟我安装完EXT191后,启动时报错
Cadence Quantus Extraction - 64-bit Parasitic Extractor - Version
19.1.0-p139 Tue Jan 15 01:22:17 PST 2019
                                  Copyright 2019 Cadence Design Systems,
Inc.
ERROR (EXTQRCXLOG-115) :  A command file and design data inputs are required for this Quantus
session to proceed.  Type -u or -h for more information on running Quantus.
ERROR (EXTQRCXLOG-113) : This Quantus session could not continue due to previous errors.
Ending at 2023-Mar-17 22:19:55 (2023-Mar-17 14:19:55 GMT).
  Executed by:           wangcy
  Execution host:        zkhx001
  Run duration:          00:00:00 CPU time, 00:00:00 clock time
  Memory used:           168,919,040
  Warning messages:      0
  Error messages:        2
Exit code 2.
Cadence Quantus Extraction exited unsuccessfully.
我的环境变量设置的是
export QRC_HOME=/edatools/cadence/EXT191
export PATH=$PATH:/edatools/cadence/EXT191/bin:/edatools/cadence/EXT191/tools/bin
export QRC_MOS_LW_PRECISION=Y
export QRC_ENABLE_EXTRACTION=t
大佬们帮忙看一看哪里有问题
最佳答案
查看完整内容
后面要跟输入文件,你没有给,单纯输入命令造成的吧?
发表于 2023-3-17 22:24:46 | 显示全部楼层
 楼主| 发表于 2023-3-17 22:26:40 | 显示全部楼层
 楼主| 发表于 2023-3-18 10:55:36 | 显示全部楼层
我到cadence的layout里也没看到QRC
发表于 2023-3-18 23:02:41 | 显示全部楼层
Quantus不就是么?
 楼主| 发表于 2023-3-19 11:13:26 | 显示全部楼层
andyfan 发表于 2023-3-18 23:02
Quantus不就是么?
原来是这样
发表于 2024-3-28 12:39:02 | 显示全部楼层
可以分享一下EXT的安装包吗
GMT+8, 2025-12-25 21:23 , Processed in 0.017506 second(s), 5 queries , Gzip On, Redis On.
