查看: 6211|回复: 11
运行virtuoso提示ERROR (LMF-02008):错误
发表于 2023-3-8 13:14:59 | 显示全部楼层 |阅读模式
ERROR (LMF02008): License call failed for feature 111, version 6.180 and quantity 1. The license server search path is defined as /opt/eda/cadence/license/license.dat. The FLEXnet error message is as follows,     FLEXnet ERROR(-8, 0, 0): Invalid (inconsistent) license key.  Run 'lic_error LMF-02008' for more information..
ERROR (ELI-00138) Failed to launch application because license '111' cannot be checked out.
发表于 2023-3-8 14:07:46 | 显示全部楼层
发表于 2023-3-8 14:08:32 | 显示全部楼层
 楼主| 发表于 2023-3-8 14:11:18 | 显示全部楼层
[root@eda-server bin]# ./lic_error LMF-02008
ERROR (LMF-02008): Invalid (inconsistent) license key.
The encryption code in license file is inconsistent.
This error occurs when the license file contains a corrupted FEATURE line for
the requested application. You need a new license file. Reinstall the license
file with Cadence Installation Software or contact Cadence support at
support@cadence.com for further assistance.
 楼主| 发表于 2023-3-8 14:12:20 | 显示全部楼层
cadence_patch.sh /opt/eda/cadence/IC618
 楼主| 发表于 2023-3-8 14:19:34 | 显示全部楼层
我是用的python cdslicgen.py生成的lic的
发表于 2023-8-12 08:49:07 | 显示全部楼层
你好,请问最终怎么解决的?
发表于 2024-4-27 23:51:47 | 显示全部楼层
请问最后怎么解决问题的
发表于 2024-5-31 11:53:20 | 显示全部楼层
请问有效的解决方法是什么
发表于 2025-4-11 20:56:24 | 显示全部楼层
大神们,请问这个有解决办法吗
GMT+8, 2025-12-14 17:01 , Processed in 0.025662 second(s), 3 queries , Gzip On, Redis On.
