查看: 1497|回复: 0
[招聘] 某司,中外合资,背靠大厂,做车规7nm芯片,急招DFT工程师,北/上/中均可
发表于 2023-2-28 11:45:18 | 显示全部楼层 |阅读模式
Mobile:17727983665(微信同号)
Job Description
As part of the ASIC design team, engineer will mainly focus on following areas, but not limited to:
1. Block, IP and SoC level DFT implementation including: RTL coding integration, Mbist insertion/simulation, Scan insertion & compression, Lbist insertion & simulaton, on chip clocking for at-speed test, boundary scan, analog/hard IP test;
2. Block level dft drc check & fix it in RTL/Netlist level;
3. Block level DFT constraint generation, synthesis, STA, ECO and formal check;
4. Test patterns/vectors generation and verification, Fault coverage data collection and improve;
Job Requirement
1. Hand on experience of SoC DFT implementation, Scan Compression logic/MBIST logic/Boundary scan chain insertion, pattern bring up and diagnose;
2. Expertise with Mentor/Synopsys DFT tools;
3. Expertise with DFT advisor tools;
4. Experience in MBIST/SCAN/ATPG Pattern simulation and debug on RTL & Netlist;
5. A high-level of self-motivation and a proactive approach to solving problems.
GMT+8, 2025-12-14 01:39 , Processed in 0.011225 second(s), 4 queries , Gzip On, Redis On.
