查看: 2680|回复: 5
仿真软件破译和cpu有关吗
发表于 2023-2-19 12:50:45 | 显示全部楼层 |阅读模式
年底配了一台AMD5600的台式电脑想着研究生跑虚拟机使用,但是过年回来安装虚拟机的时候calibre和synopsys的license一直破译不了显示不可用,于是我使用我刚入学的笔记本i5-9300h重新安装一遍通过,安装流程,安装软件的具体版本都一样,现在怀疑是不同CPU的问题请问是这样嘛?有没有大佬能帮我解答一下,如果真的不可用就只能换板u了。
发表于 2023-2-19 13:17:26 | 显示全部楼层
after copying the virtual machine and opening after that if you selected "Copy" instead of "Move"(when asked) the licenses would disappear. Always select "Move"
发表于 2023-2-19 14:23:14 | 显示全部楼层
Mentor Graphics Calibre required system
Caliber supports x86_64 processors. There are two x86-64 processor products supplied by different vendors, AMD and Intel. The Calibre toolset is supported on computers based on either of these processors. As of the 2013.4 Caliber release, MGC_HOME is packaged as two trees, IXL and AOI. The different executables for IXL and AOI trees are optimized for different Linux distributions. For example, IXL supports RHEL 5 distributions; AOI supports RHEL 6 distributions. If you use both types of Linux distributions on your network, you should download and install both executables into the same target directory. Set the MGC_HOME variable to either the IXL or the AOI tree. When you invoke Caliber, it will automatically detect the operating system and execute it from the correct MGC_HOME tree.
发表于 2023-2-20 09:36:25 | 显示全部楼层
这个每个软件官网都有说的
发表于 2023-2-20 15:49:01 | 显示全部楼层
没啥关系吧,我这面也是amd 5800的,cent82
除了virtuoso费点事情,数字的没有遇到问题
 楼主| 发表于 2023-2-21 13:07:39 | 显示全部楼层
解决了问题,我在虚拟机设置选项虚拟化引擎了intel和amd就完成了软件的正常安装和破译,建议还是用intel 适配好多了
GMT+8, 2025-12-29 23:27 , Processed in 0.017560 second(s), 3 queries , Gzip On, Redis On.
