查看: 4857|回复: 24
[转贴] CMN600
发表于 2023-2-6 16:49:46 | 显示全部楼层 |阅读模式
Design flow
The MMU-600AE is delivered as synthesizable RTL. Before it can be used in a product, it must go
through the following processes:
Implementation
The implementer configures and synthesizes the RTL to produce a hard macrocell. This process
might include integrating RAMs into the design.
Integration
The integrator connects the implemented design into an SoC. Integration includes connecting
the design to a memory system and peripherals.
Programming
The system programmer develops the software to configure and initialize the MMU-600AE, and
tests the required application software.
Each process is separate, and can include implementation and integration choices that affect the behavior
and features of the MMU-600AE.
The operation of the final device depends on:
Build configuration
The implementer chooses the options that affect how the RTL source files are pre-processed.
These options usually include or exclude logic that affects one or more of the following:
发表于 2023-2-6 17:11:29 | 显示全部楼层
thanks
发表于 2023-2-8 13:56:56 | 显示全部楼层
kan kan
发表于 2023-10-13 21:38:01 | 显示全部楼层
好,很好
非常好
发表于 2023-10-13 21:43:56 | 显示全部楼层
好,很好,非常好
发表于 2023-10-13 21:56:58 | 显示全部楼层
thanks
发表于 2023-11-10 17:23:42 | 显示全部楼层
哥 來研究下
发表于 2023-11-11 17:33:46 | 显示全部楼层
什么东西?
发表于 2023-11-19 12:37:14 | 显示全部楼层
谢谢分享
发表于 2023-11-23 14:22:12 | 显示全部楼层
看看,资料哪?
GMT+8, 2025-10-12 04:33 , Processed in 0.019680 second(s), 4 queries , Gzip On, Redis On.
