查看: 11328|回复: 47
虚拟机安装:基于RHEL系统的Silvaco 2016安装情况
发表于 2022-11-10 11:06:15 | 显示全部楼层 |阅读模式
1、安装好VM,下载RHEL的ISO文件,并安装RHEL虚拟机
2、安装系统所需包和依赖文件
Install Missing Packages and Dependencies (required for all systems)
(RHEL7)
        yum install glibc.i686 libgcc.i686 libstdc++.i686
        yum install zlib.i686
        yum install xorg-x11-fonts-75dpi.noarch xorg-x11-fonts-misc.noarch
(RHEL6)
        yum install compat-libstdc++-33.i686 compat-libstdc++-33.x86_64
        yum install zlib.i686 zlib.x86_64 xorg-x11-fonts-75dpi.noarch
3、解压silvaco安装包
(Extract tar.gz)
        sudo mkdir /opt/silvaco
        cd <TCAD.tar.gz dir>
        sudo tar -xzvf 18391-tcad-2016-00-rh64.tar.gz -C /opt/silvaco
4、替换rpc.sflmserverd.exe
(Replace rpc.sflmserverd.exe)
        cd <rpc.sflmserverd.exe dir>
        sudo cp -i rpc.sflmserverd.exe /opt/silvaco/lib/rpc.sflmserverd/8.2.12.R/x86_64-linux
        cp: overwrite ‘/opt/silvaco/lib/rpc.sflmserverd/8.2.12.R/x86_64-linux/rpc.sflmserverd.exe’?
        y
5、创建有效license
(Create valid license)
        sudo mkdir /opt/silvaco/license
        cd <license.lic dir>
        sudo cp license.lic /opt/silvaco/license
        /opt/silvaco/bin/showid
        eg: MachineID         rhel7-8c20a60a-3c53e1bb
        edit license.lic (replace LM_HOSTIDS with MachineID, change relevant date: MAINTENANCE_DATE & END_DATE)
        use vi, etc
6、安装Portmap
(Install Portmap)
        sudo yum install portmap
        service rpcbind status  (check whether running)
        service rpcbind start
        # service rpcbind stop  (can disable rpcbind after complete installation)
7、安装SFLM服务器
(Install SFLM server)
        sudo /opt/silvaco/bin/sflm -i
        New Password    ?
        Retype password ?
        Preparing to install the SFLM server daemon.
        This procedure will modify or create the following system files:
                /etc/rc.d/init.d/sflm
        Backups will be created in /var/tmp/s_install.bak
        before any files are modified.
        Run '/opt/silvaco/etc/s_install -rm-bak' or '/var/tmp/s_install.bak/remove' to remove backup files.
        Do you wish to proceed? [y|n]
        y
        SFLM installation completed successfully.
8、安装前面创建的license
(Install created license : Require Internet Connection)
        open internet browser
        http://localhost:3162/Admin/Ssmid
        Key in password
        Install new license(s) > Install Saved File > browse to : /opt/silvaco/license/license.lic > open > agree
        SFLM has installed the specified license file "/var/opt/sflm/licenses/Silvaco_2016.lic".
        Silvaco_2016 has licenses for server(s):
9、创建桌面快捷方式
(Create Desktop Shorcut)
        /opt/silvaco/bin/sman
        Products > Add and Manage Updates > Update Shortcuts
10、添加环境配置
(Optional)
        add the follwing line to the file $home/.bashrc  (hidden)
        export PATH=$PATH:/opt/silvaco/bin
至此,基本结束了
silvaco 2016安装包、安装步骤都在下面:
游客 ,如果您要查看本帖隐藏内容请回复
已经安装好的虚拟机在下面:
游客 ,如果您要查看本帖隐藏内容请回复
发表于 2022-11-10 16:01:41 | 显示全部楼层
谢谢分享~
发表于 2022-11-10 16:48:06 | 显示全部楼层
kan e kan
发表于 2022-11-10 16:55:49 | 显示全部楼层
学习一下
发表于 2022-11-10 20:04:02 | 显示全部楼层
多谢分享
发表于 2022-11-10 20:36:49 | 显示全部楼层
虚拟机
发表于 2022-11-10 21:15:01 | 显示全部楼层
good to practice
发表于 2022-11-10 22:40:17 | 显示全部楼层
谢谢分享~
发表于 2022-11-11 09:16:54 | 显示全部楼层
参考学习一下
发表于 2022-11-11 10:06:38 | 显示全部楼层
感谢分享
GMT+8, 2025-12-14 14:08 , Processed in 0.019478 second(s), 4 queries , Gzip On, Redis On.
