查看: 1966|回复: 0
Altair HW FEKO 2022.1.2 x64
发表于 2022-10-15 06:53:58 | 显示全部楼层 |阅读模式
FEKO Suite is a software for analyzing a wide range of electromagnetic disturbances and problems. Its applications include EMC analysis, checking the effect of cables on each other, checking electromagnetic compatibility, antenna design, Microstrip antennas, circuits, scattering analysis, etc. FEKO Suite is very comprehensive and practical and has a wide range of facilities for the analysis of dielectric plates. The numerical methods used in this software are moment and finite difference methods in the time domain.
Finite element techniques, physical optics, radiation scattering in geometrical optics and uniform diffraction theory are used in torque method.   Also, the software uses optimization tools with genetic, bird, linear, and feedback algorithms. The graphic environment of the software uses the most complete design tools and sizes can be controlled in two or three dimensions with the mouse.  Also, the Maxwell solver is controlled by a graphical interface. The light sources of the software consist of electric and magnetic dipoles, plane waves, current or voltage sources, linear currents and adjustable spherical modes. It has very wide facilities for analyzing dielectric plates to perform complex electromagnetic calculations and simulations and enables the user to solve a wide range of electromagnetic problems using FDTD, FEM, and MLFMM calculation methods.
Features and features of FEKO Suite software:
- Determining the position of antennas in large structures such as ships and airplanes and analyzing their radiation patterns
- High frequency components such as waveguides, couplers and filters
- Simulation of types of antennas such as arrays, microstrips, wide band antennas
- Range analysis A wide range of electromagnetic disturbances and problems
- use of finite element techniques, physical optics, radiation scattering in geometrical optics and uniform diffraction theory
- bioelectromagnetism including analysis of homogeneous/heterogeneous organs and star extraction
- investigation of the effect of cables on each other
- investigation of compatibility Electromagnetics, antenna design, antennas, circuits, distribution analysis
- three-dimensional electromagnetic circuits consisting of filters, waveguides
It can be downloaded using the following links:
https://dl3.downloadly.ir/Files/Software/Altair_HW_FEKO_2022.1.0_x64.part1_Downloadly.ir.rar
https://dl3.downloadly.ir/Files/Software/Altair_HW_FEKO_2022.1.0_x64.part2_Downloadly.ir.rar
https://dl3.downloadly.ir/Files/Software/Altair_HW_FEKO_2022.1.0_x64.part3_Downloadly.ir.rar
https://dl3.downloadly.ir/Files/Software/Altair_HW_FEKO_2022.1.2_x64_HotFix_only_Downloadly.ir.rar
For more EDA software like EMPIRE XPU 8.1.3, Remcom XFDTD 7.10.1, Remcom XGTD 3.1.2, Remcom Wireless Insite 3.3.5, Remcom WaveFarer Radar Software 2.1, Sonnet Suite Pro 18.56 and ASN Filter Designer 5.1.1, please contact fast.forever24@gmail.com
GMT+8, 2025-12-25 17:07 , Processed in 0.012011 second(s), 4 queries , Gzip On, Redis On.
